12-12-2020, 08:41 PM
#31
Banned
Real Name: Tobias Fünke
Banned
Originally Posted by rochmpr
Seriously, cut that bastard off already.
Also, for everyone, bash the crap out of that pinch weld with a 5 lbs. sledge til it's flat, but don't stop there, continue with the whole back of the wheel well so it deform the floor boards. Spray with 3M rubber crap.
Either commit or run 33's!
Sent from my SM-T290 using Tapatalk
Smashed, cut, and packed the seams with jb weld. I’ll let it cure. Finish up tomorrow.
12-12-2020, 08:58 PM
#32
thats a ton of cutting!
must be wheeling really hard!
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
12-13-2020, 02:05 PM
#33
Banned
Banned
Sanded / scotched everything. Scrubbed the wells with a brush and simple green. Flushed it with more green and wiped clean with micro fibers. Took a heat gun and dried it all. Acetone wipe, more heat to the panels, applied 3m undercoat which had been warming in front of a heater vent inside.
Looks great.
Letting it cure then I have to figure out how to afix the fender.
12-13-2020, 06:28 PM
#34
Banned
Banned
Cut up one of the glove box shelves I wasn’t using to shim the fender. Fender gap is near perfect but I need some slightly longer screws for another shim.
Overall pleased with the results. Time will tell if there is still rub but it should be mostly sorted.
12-13-2020, 06:37 PM
#35
Banned
Banned
Off to finish the other side. Hope this helps others.
12-13-2020, 08:50 PM
#36
Banned
Banned
Finished the drivers side. Jobs done.
Fender spacing and maybe making the passenger plastics look as clean as the drivers side is all that’s left.
Took my first rub free drive. Picked up a well deserved 12 pack. Idk how many days of labor I have into this truck but it’s a lot.
12-14-2020, 11:55 AM
#37
Looks amazing! You've done a far better job than I did for sure.
Thanks for documenting this will definitely be helpful to many
12-14-2020, 02:30 PM
#38
Banned
Banned
Clean them, spray with rubberized undercoating on the side you will be folding over. Fold over, spray rubberized undercoat over the whole pinch weld to seal it from the elements.
I did the above, i used a Small dead blow hammer
12-14-2020, 04:12 PM
#39
Great job...and yes sir, thanks for the pictures and documentation!
2017 4Runner TRD Pro - Cement Icon RR CDCV (700 lb) w/ Icon Delta Joint UCA's/Billet Rear Link Arms || Icon Overland 3'' Rear Springs+Dobinson's 15mm spacers on top || C4 Fab Sliders || CBI Front Bumper || Shrockworks Rear Bumper || Gobi Stealth Rack/Ladder || Baja Designs & Rigid Lighting || 285/75r17 Toyo MT's (34") || Safari Snorkel || ARB Diff. Breather Kit || Spidertrax || ARB Awning 2000 || Maxtrax || XD Philips 4300K HID's || Warn Winch/Factor 55 || IKamper Skycamp 2.0 4X || SCS Ray10's || Durobumps
2015 4Runner TRD Pro - Super White (Wife's) Icon Stage 2 w/ Icon UCA's || Toytec Superflex HD Rear Springs || Expedition One Sliders || 285/70r17 BFG KO2's || Gobi Stealth Rack/Ladder || 40" Rigid Radiance || Spidertrax || XD Philips 4300K HID's || Philips Yellow LED Fogs
12-14-2020, 07:55 PM
#40
Real Name: Krister
Real Name: Krister
Get yourself a can or two of this to spray the wheel wells with.
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
12-14-2020, 11:37 PM
#41
Banned
Banned
Way ahead of you lol. You can see the results above.
01-28-2021, 11:36 PM
#42
Bfh
After a year and a half of rubbing at full lock and articulation, I decided to take the leap on my 4runner and do the "BFH Mod". I cut a bunch of sheet metal and plastic and did the big "SMASH!, SMASH!, SMASH!" on the pinch welds. I decided to bend the welds outward into the recess to maximize the space. I covered the entire bent over pinch weld with 3M seam sealer and then sprayed 3M rubberized undercoating. I gained a ton of space and can finally take advantage of my BMC. I feel like I can make the jump from my 195/70/R17 Toyo M/T's to 185/75/R17 without much issue. Time to test.
2019 TRD ORP with stuff bolted to it and my Alaskan Malamute benevolent overlord, Farley. KN6HZJ
05-17-2021, 01:15 PM
#43
Very clean looking. Going to get on the 3M coating for the whole area!
04-20-2022, 11:59 PM
#44
For the seam sealer that you used. Was it brush on, or from a tube?
2005 4R V8 4x
04-21-2022, 01:46 PM
#45
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
