Old 03-25-2019, 01:45 AM #1
bapsdds bapsdds is offline
bapsdds is on a distinguished road
how much transmission fluid needed to flush and replace
Hey folks,
my 2011 4runner just turned over 100 k would like to do a transmission flush and fluid replacement.
how much toyota WF should I get for this project?
thx
BK
bapsdds is offline   Reply With QuoteReply With Quote
Old 03-25-2019, 03:52 PM #2
mwebster22 mwebster22 is offline
mwebster22 is on a distinguished road
I used 13 qts.
2012 4Runner Limited 2WD
2006 4Runner Sport 4WD
2006 4Runner Sport 2WD
mwebster22 is offline   Reply With QuoteReply With Quote
Old 03-25-2019, 03:54 PM #3
Whippersnapper02's Avatar
I used about 14 quarts on my Tacoma with the OEM external oil cooler.
Old 03-25-2019, 05:32 PM #4
QwikKotaTx's Avatar
QwikKotaTx QwikKotaTx is offline
QwikKotaTx is on a distinguished road
QwikKotaTx's Avatar
I only needed about 4 quarts to do a simple pan drain and fill. I did not want to mess with the complicated procedure that is required to get the right amount back in when doing a full drain/flush. It's pretty involved to do it correctly.
QwikKotaTx is offline   Reply With QuoteReply With Quote
Old 03-25-2019, 06:05 PM #5
It's not that bad. I feared screwing something up but I used my scangauge to read temp before opening the check plug.
Old 03-26-2019, 09:36 AM #6
QwikKotaTx's Avatar
QwikKotaTx's Avatar
I can get temps with a simple OBD to bluetooth adapter, correct?
Old 03-26-2019, 11:13 AM #7
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
For the purpose of setting correct ATF fluid level, you can also use a small paper clip. Documented in FSM. Toyota shows a "special tool" for this which is nothing more than a jumper wire which is what a paper clip is.
Works like a charm.
ATF Fluid capacity for many 5th Gen 4Rs is 11.3 qts.
Some extra may be needed for a "flush". More than one transmission tech claims the flushing method used by many DIY types actually inter-mixes old and new fluid during the process. I suppose if you spin enough new fluid through you'll eventually end up with fresh ATF.
Pointer to owners manuals follow if you need to determine your 4Rs ATF(and other) fluid capacity:
Owners Manuals/Warranty Info/Etc. 2010-2019
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 03-26-2019, 03:10 PM #8
QwikKotaTx's Avatar
QwikKotaTx's Avatar
Works like a charm.
Oh right, I forgot about that. It's a jumper between pins 4 and 13 on the OBD-II port, correct? I will get one of the port readers as they are cheap on eBay.
The service manual excerpt states 1.8 qts for pain drain refill. I could have sworn I used nearly 4 quarts when I did ours but I have slept and drank since then.
Old 03-26-2019, 03:30 PM #9
You will drain 3 qts. if the system is cold and properly filled. You might drain more if you drain hot.
You can also get an extra qt. out if you elevate the front of the vehicle as high as you can get it with a floor jack.
Old 03-27-2019, 10:13 AM #10
QwikKotaTx's Avatar
QwikKotaTx's Avatar
I had it on jack stands at the front and it's always hot in Houston. Engine was probably cold though. I will work on the proper procedure soon. I accidentally drained a little ATF out disconnecting the cooler lines instead of the power steering lines the other day, damnit.
Old 03-27-2019, 12:16 PM #11
As long as it can read tranny temp.
Old 08-18-2020, 10:39 PM #12
DougEFresh2 DougEFresh2 is offline
DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough
Beginner Fluid Maintenance
Here's a guide you can follow so you can do all the basic fluid maintenance with EVERYTHING you could ever need or want.
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual: https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
DougEFresh2 is offline   Reply With QuoteReply With Quote
fluid , flush , replacement , toyota , transmission
Transmission flush vs. transmission fluid drain and refill... Bad_Influence 5th gen T4Rs 18 03-08-2022 12:03 AM
New Radiator with Coolant Flush? Power Steering Fluid Flush, and Brake Fluid Flush? jdotlim 4th Gen T4Rs 4 09-17-2017 07:52 PM
anyone done a tranny fluid flush/replace through front cooler keakar 4th Gen T4Rs 27 09-17-2017 08:35 AM
As if you REALLY needed a reason to flush your brake fluid!!! MrBobDobalina 3rd gen T4Rs 12 05-16-2011 05:41 PM
Is a transmission fluid flush bad? kcyota 3rd gen T4Rs 6 06-30-2009 08:45 AM
