Old 04-05-2019, 06:51 PM #16
TRUSTYAXE's Avatar
TRUSTYAXE TRUSTYAXE is offline
TRUSTYAXE will become famous soon enough TRUSTYAXE will become famous soon enough
TRUSTYAXE's Avatar
So I went ahead and installed the Hikari low beams. First impressions are great, nice output with a cut off that resembles the Camry’s factory leds. The cooling fans kinda freak me out but time will tell. Still have saber pro 40w highs, love em.
2015 TRDPRO SUPER WHITE ~ ROOF RACK DELETE ~ REAR SEAT DELETE ~ LED ANYTIME FOGS ~ DRL DISABLE ~ DOMETIC CFX-28 ~ BORLA CAT BACK ~ SPRINT BOOSTER V2 ~ aFe MOMENTUM GT INTAKE ~ OTHER JUNK N STUFF
TRUSTYAXE is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 10:37 PM #17
DeserT4R DeserT4R is offline
DeserT4R is on a distinguished road
Originally Posted by PaulB-2006 T4R View Post
I have the Hikari LED Thunder in my low beams. I had no issues putting them inside the housing (I did not even remove the battery), the light output way better than high end halogens and love the look. I have Cougar Motor LED DRL/high beams. For the DRL the light is very consistent, no flicker and high beams are crazy bright. Each set are $37 each on Amazon.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
https://www.amazon.com/Cougar-Motor-...s%2C174&sr=8-3
Did you do LED fogs too? If so, which route did you go?
DeserT4R is offline   Reply With QuoteReply With Quote
Old 04-14-2019, 09:05 PM #18
PaulB-2006 T4R's Avatar
PaulB-2006 T4R PaulB-2006 T4R is offline
Real Name: Paul
PaulB-2006 T4R will become famous soon enough
Real Name: Paul
No, I have a set of halogen PIAA Plasma Ion Yellow H16 bulbs.
2016 Trail MGM. P265 70/17 Falken Wildpeak AT3W. Matte Black TRD Wheels. Leveled with 2" spacer. Heated Front Seats. All LED interior. Mud flaps deleted. TRD Air & Oil Filter. TRD Oil Cap. FJC Shifter. Subaru Kicker tweeters. Hikari LED Low Beam. Cougar Motor LED DRL/High beam. Hood "scoop" and lower door wrap.
2006 SR5 4WD V6 - Owned from July 2009 with 38,200 miles to March 2017 with 150,100 miles.
PaulB-2006 T4R is offline   Reply With QuoteReply With Quote
Old 04-15-2019, 04:25 AM #19
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
I've been on these since 2016 - no issues and work great:
Fog lights:
H16 JDM ASTAR 2400 lumens
Front lights (high/ low beams):
Xprite A1 series 9005 (HB3)
Xprite A1 series H11
The fog lights are bright, but would keep the stock ones if I lived in a really foggy area..
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 04-26-2019, 12:38 AM #20
I ended up going with the LED fogs of the ‘19s, direct swap with the stock fogs on my ‘17.
Old 04-30-2019, 04:38 PM #21
mswaz mswaz is offline
mswaz is on a distinguished road
Tried the install of the Morimoto H11's I also purchased the 9005 and anti flicker bus's for the high beam from Morimoto but never got to install the high beam setups. These are a joke. The fans are so loud they can be heard over the engine and the slightest movement of them causes serious vibration issues. The light is a great color but the light distribution from them in the reflector are worse than OEM or a good halogen bulb. Huge black spots for 25 feet in front of car as well as no light up on the sides. Thank goodness for the OEM LED fogs on the pro. People said don't use LED's in the projectors I completely get it now. If I upgrade guess I am going with HID's
mswaz is offline   Reply With QuoteReply With Quote
Old 04-30-2019, 04:43 PM #22
Jimmie48 Jimmie48 is offline
Jimmie48 is on a distinguished road
Installed the cougar motor 9005's in the highs last night. Mainly wanted the puke yellow to go away from the DRL's and these were the only ones I could find that had the attached power management system that dont flicker without an additional attachment. (feel free to tell me of others) So far I like them but have not driven at night yet with the highs on. Initially they are a little loose in the housing, more than I like but the color is great with the DRL. I am taking them on a long trip tomorrow so we will see how they do.
Jimmie48 is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 04:21 PM #23
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
I was very unhappy with them. The lights aren’t adjustable so however they fit that’s what you get. Mine were pointed straight down. I returned them and went with the katana led lights. Ordered the DDM tuning for the DRL/high beam and should have those by next week
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 12:39 PM #24
hsl11 hsl11 is offline
hsl11 is on a distinguished road
Recently installed gtr lighting csp mini from headlight revolution for my low beams. Took less than 10 minutes to install. Huge improvement over stock!
hsl11 is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 01:32 PM #25
ADT_192 ADT_192 is offline
ADT_192 is on a distinguished road
Also running the Katanas for low beams. Running the KASO RX6 for the fog lights. So far so good.
2014 Trail || Grabber AT2s
ADT_192 is offline   Reply With QuoteReply With Quote
Old 09-30-2019, 10:59 PM #26
GiGi's 1996's Avatar
GiGi's 1996 GiGi's 1996 is offline
Real Name: Christine
GiGi's 1996 is on a distinguished road
THANK YOU for this post. I ordered the low beam lights from your link and followed your example. These lights work perfect and look sooooo much better than the stock yellow-y dim lights.
Thank you for including the exact description and link to buy. So many of these threads have fancy code word names for lights they are using. Makes it impossible for non-tech person like myself to understand or decifer.
I just ordered the high beams from Amazon tonight. I am sure they will work and install as nice as the low beams did.
2016 TEP
Shrockwork Sliders, RCI skids
ICON with Air-Lift air bags
Cooper ST MAXX 255/80R17 on SCS Ray 10s
GiGi's 1996 is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 02:28 AM #27
Vultradamus Vultradamus is offline
Vultradamus is on a distinguished road
Originally Posted by Bayou_Pro View Post
Search is your friend. There are ton of threads on this already.
I run the Morimotos is mine and everything fits behind the covers just fine. Good luck.
Dang, I was really interested in going through Headlight Revolution and getting their SV.4 Lows / Highs (Unsure what to do about the Fogs)
But you've turned me on to the Morimoto 2 Strokes... Gonna have to do some more research, but I'm assuming you can get both Lows / Highs / and Fogs all through the same brand/company?
Vultradamus is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 03:16 AM #28
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold
Here's what I picked, with justification for each one:
Morimoto 2stroke 2.0 low beams
Xenon Depot Pro high beams with DRL mode drivers (the only LED bulb/driver I know of that offers full DRL functionality)
Philips 12793UNIX2 yellow fogs
I wanted bulbs that dropped in with zero modification to housings or dust caps. The Morimotos have a fan and that's fine with me, as they're protected behind the dust cap. The XD highs have passive fin radiators, and the DRL drivers are stuck under the plastic engine bay sills with 3M double-sides tape. The Philips fogs are the most exposed to the dirt and elements, so I think it's good that they have more robust machined heatsinks. Can't drive them as hard but I'm less worried about gunk hurting them. I would NOT run a bulb with a fan or delicate fins in this location if you do any offroading.
I'm happy with the light quality from all three sets. The lows are a marked improvement over halogen bulbs and maintain factory beam pattern, hotspot, and cutoff. The highs are very bright and the DRL functions perfectly at about 15% of full brightness. There is a tiny amount of observable flicker remaining- I'd compare it to the hum of a fluorescent light- very hard to distinguish unless you're looking for it. The fogs offer great contrast, are much brighter and wider, and blend the area immediately in front of the truck into the bottom of the headlight beams.
I am curious about the Supernova V.4 bulbs, they seem confident that their bulbs are the brightest LED available while maintaining good optics and cutoff. Headlight Revolution has also reviewed the Morimoto 2-stroke favorably, though I haven't seen a direct comparison between the two.
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 07:43 AM #29
CMS516 CMS516 is offline
CMS516 is on a distinguished road
Headlight Revolution tested 105 bulbs(there's a youtube video) for the 4runner and narrowed it down to the 2 that they sell for the headlights. One is the 'mini' that I have and the other one is a bit bigger, not sure if the dust cover needs to be drilled out for the larger one.
Anyway, very happy with the light output and quality. It's not scattered or aiming up at the trees. Huge improvement over stock and I haven't been flashed by oncoming traffic.
CMS516 is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 09:47 AM #30
jkim2001 jkim2001 is offline
jkim2001 is on a distinguished road
Those Hikaris are not great. I already had 2 replaced under their 2 yr warranty. Their lumen output is slightly better than halogens but their are NOT comparable to OEM factory LEDs....way dimmer then OEM.
jkim2001 is offline   Reply With QuoteReply With Quote
guys , headlights , housing , inside , led
2005 4Runner headlights to 2006 headlights bizkd 4th Gen T4Rs 1 10-06-2015 08:03 AM
GX470 headlights=4Runner headlights? ssmumich00 Engines / Suspension / Wheels / Tires / Audio / Accessories 17 10-18-2013 06:54 PM
tacoma headlights = 4runner headlights calithirteen 3rd gen T4Rs 6 06-26-2013 05:09 PM
Anyone have these projector headlights or crystal clear headlights?? afdj006 3rd gen T4Rs 12 10-30-2007 12:16 AM
