Old 03-25-2019, 11:25 PM #1
4Running22 4Running22 is offline
4Running22 is on a distinguished road
LED Headlights H11
Any of you guys installed an LED headlights that fits inside the headlight housing without having to drill a hole on the dust cover to pass the wires? If so what brands are you guys using?
I’ve called Precision LED and they said that their LED are small enough that they fit inside the housing. There just a bit pricey though and I don’t know too much about this company and if there even good.
4Running22 is offline   Reply With QuoteReply With Quote
Old 03-26-2019, 12:09 AM #2
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
Search is your friend. There are ton of threads on this already.
I run the Morimotos is mine and everything fits behind the covers just fine. Good luck.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 03-26-2019, 12:28 AM #3
mlnhtrang's Avatar
mlnhtrang mlnhtrang is offline
mlnhtrang is on a distinguished road
mlnhtrang's Avatar
yea, morimoto 2 stroke will fit with no problems. ive also tried jdm astar 8 gen and the fit as well. good luck
2018 T4R TRD Off-Road Premium w/ KDSS - Super White
mlnhtrang is offline   Reply With QuoteReply With Quote
Old 03-26-2019, 12:40 AM #4
mswaz mswaz is offline
mswaz is on a distinguished road
did you have to use the anti flicker adapter and if so does that fit in there as well?
mswaz is offline   Reply With QuoteReply With Quote
Old 03-26-2019, 12:50 AM #5
That’s my next question. On the High Beams/DRL do we need an anti flicker?
Old 03-26-2019, 12:53 AM #6
Bayou_Pro's Avatar
Bayou_Pro's Avatar
Not needed for the H-11 Low Beams. I disabled my DRLs so I didn't need anything for my High Beams either. Otherwise yes you will need one.
Paul
Old 03-26-2019, 12:53 AM #7
mr.walleye mr.walleye is offline
mr.walleye will become famous soon enough
I too run Morimoto (highs and lows). I love em' and didn't even need to adjust the beams. I'm getting ready to order their fog assemble next week.
mr.walleye is offline   Reply With QuoteReply With Quote
Old 03-26-2019, 12:54 AM #8
Yeah what I meant is do you need the antiflicker for the H11 low beams? The 9005 high beams don't sit inside a dust cover so would assume you need the antiflicker and mount it someplace?
Old 03-26-2019, 12:57 AM #9
Bayou_Pro's Avatar
Bayou_Pro's Avatar
You'll love the Fogs!!! You will need to modify the tabs where they go into the factory slots toward the inside. It's just a matter of cutting off a little bit to make it narrower to fit into the bumper slot. Takes just a couple of minutes a side.
Paul
Old 03-26-2019, 01:02 AM #10
Bayou_Pro's Avatar
Bayou_Pro's Avatar
See my reply above if you missed it.
Paul
Old 03-26-2019, 01:05 AM #11
Saw that, thank you.
Old 03-26-2019, 11:28 AM #12
Lhshockey24's Avatar
Lhshockey24 Lhshockey24 is offline
Lhshockey24 is on a distinguished road
Adding on here:
I just switched from the XenonDepot LEDs to the Morimotos. MUCH happier with the change. I can already tell after one night of driving the beam reaches much farther down the road.
Lhshockey24 is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 07:49 PM #13
PaulB-2006 T4R's Avatar
PaulB-2006 T4R PaulB-2006 T4R is offline
Real Name: Paul
PaulB-2006 T4R will become famous soon enough
Real Name: Paul
I have the Hikari LED Thunder in my low beams. I had no issues putting them inside the housing (I did not even remove the battery), the light output way better than high end halogens and love the look. I have Cougar Motor LED DRL/high beams. For the DRL the light is very consistent, no flicker and high beams are crazy bright. Each set are $37 each on Amazon.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
https://www.amazon.com/Cougar-Motor-...s%2C174&sr=8-3
2016 Trail MGM. P265 70/17 Falken Wildpeak AT3W. Matte Black TRD Wheels. Leveled with 2" spacer. Heated Front Seats. All LED interior. Mud flaps deleted. TRD Air & Oil Filter. TRD Oil Cap. FJC Shifter. Subaru Kicker tweeters. Hikari LED Low Beam. Cougar Motor LED DRL/High beam. Hood "scoop" and lower door wrap.
2006 SR5 4WD V6 - Owned from July 2009 with 38,200 miles to March 2017 with 150,100 miles.
PaulB-2006 T4R is offline   Reply With QuoteReply With Quote
Old 03-28-2019, 06:55 PM #14
TRUSTYAXE's Avatar
TRUSTYAXE TRUSTYAXE is offline
TRUSTYAXE will become famous soon enough TRUSTYAXE will become famous soon enough
TRUSTYAXE's Avatar
Did you clock the low beams when installing?
2015 TRDPRO SUPER WHITE ~ ROOF RACK DELETE ~ REAR SEAT DELETE ~ LED ANYTIME FOGS ~ DRL DISABLE ~ DOMETIC CFX-28 ~ BORLA CAT BACK ~ SPRINT BOOSTER V2 ~ aFe MOMENTUM GT INTAKE ~ OTHER JUNK N STUFF
TRUSTYAXE is offline   Reply With QuoteReply With Quote
Old 03-29-2019, 08:33 PM #15
Real Name: Paul
Real Name: Paul
Yes, placed the wire at 6 o'clock, it clearly focused the beam. This was one of the reasons I bought the Hikaris.
guys , headlights , housing , inside , led
2005 4Runner headlights to 2006 headlights bizkd 4th Gen T4Rs 1 10-06-2015 08:03 AM
GX470 headlights=4Runner headlights? ssmumich00 Engines / Suspension / Wheels / Tires / Audio / Accessories 17 10-18-2013 06:54 PM
tacoma headlights = 4runner headlights calithirteen 3rd gen T4Rs 6 06-26-2013 05:09 PM
Anyone have these projector headlights or crystal clear headlights?? afdj006 3rd gen T4Rs 12 10-30-2007 12:16 AM
