Old 03-26-2019, 04:09 PM #1
68Yenko 68Yenko is offline
68Yenko is on a distinguished road
Steering wheel wobble question
Has anyone who has/had the steering wheel wobble issue checked out or replaced their Track Bar Bushings, or Tie Rod Bushings?? Were they the culprit?
Thanks!
68Yenko is offline   Reply With QuoteReply With Quote
Old 03-26-2019, 05:16 PM #2
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
Thanks!
It's typically wheels that have been balanced by the wrong machine. Google around for t4r search results and you will find some discussions.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 03-26-2019, 07:23 PM #3
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
It's either bad balance, bad tires, or combination of both.
Don't bother with replacing bushing, steering racks, or other parts.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 03:34 PM #4
axel1's Avatar
axel1 axel1 is offline
axel1 is on a distinguished road
axel1's Avatar
Sorry to bump an older thread, but I'm struggling with steering wheel wobble as well with my '14 SR5. I've had the tires (Wildpeaks) road-force balanced and rotated three times now and the problem has remained the same. The first time I had them balanced it got slightly better but came back within a few days. This most recent shop (Discount Tire where I originally bought the tires) said that all four were basically perfect on the machine.
Every time I've had them balanced they've been rotated and the problem has stayed the same which leads me to believe it's something besides tire balance. Anybody who's had this wobble problem found another culprit? I'm beginning to think it's possibly a warped rotor because I also have a slight pulsating in my brakes when stopping, and I'd imagine a slightly warped rotor would be enough to cause steering wheel shake at speed.
I've been fighting this for months now. It only happens between 55-65 mph so it wasn't a huge problem until recently where my new commute has me going that speed for a decent chunk of time.
'14 SR5 in Classic Silver, Wilpeak AT3Ws, miscellaneous electrical odds and ends.
axel1 is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 04:32 PM #5
Banned
Banned
Never ending ordeal
Old 07-07-2019, 05:03 PM #6
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
From what I have seen, it means trade in the vic or part it out.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 07:01 PM #7
axel1's Avatar
axel1's Avatar
I'll have to try upping the PSI a bit. I'm still running at stock 32PSI right now and BCM in that thread said that fixed his issue. Might go up to 35 and see how that feels.
I'm definitely not trading it in. If I can make it better that's all I need. A little wobble is fine but what I've got is the wheel moving a good 1-2 degrees in each direction at around 60mph.
Old 07-07-2019, 09:03 PM #8
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
I don’t know if it you checked around but when Road Force balancing make sure that the place doing it has a calibrated (some don’t calibrate correctly) Hunter Road Force balance machine. These tend to give better results.
With this and the correct equal tire pressure mine went from annoying to not noticeable.
I found the sweet spot with my LT tires is between 42-44 psi depending on load. I think your choice of trying 35-36 psi is a good starting point for something different.
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 07-08-2019, 11:54 AM #9
axel1's Avatar
axel1's Avatar
I'm fairly confident discount tires all use Hunter machines. I've been to two separate locations and they've both said the balance looked good so for now I trust them. I'm running Wildpeak AT3's in the OEM size so I think 42 is a bit overkill. We'll see how upping the pressure a bit helps (or hurts).
Old 08-07-2019, 09:00 PM #10
rics97toy's Avatar
rics97toy rics97toy is offline
Real Name: Rick
rics97toy is on a distinguished road
rics97toy's Avatar
Real Name: Rick
I wanted to ask if you have fixed the problem because my wife’s 2012 limited 4Runner had the same problem.
rics97toy is offline   Reply With QuoteReply With Quote
Old 08-09-2019, 10:59 PM #11
axel1's Avatar
axel1's Avatar
That's a negative. I've been somewhat busy with work but the problem is still there after airing up. It's livable since it only happens between 55-65mph but still very annoying when I have to commute at that speed for ten minutes or so.
At some point in the near future I'll probably be going to the local dealership to get the airbag recall done, so I might have them take a look at the frontend and see if there's anything strange or loose. Maybe check the alignment too.
Old 08-11-2019, 12:30 PM #12
rics97toy's Avatar
Real Name: Rick
rics97toy's Avatar
Real Name: Rick
I wanted ask you when was the brakes replaced because my wife’s 2012 Limited 4Runner was doing the same thing. So a weekend I was free I decided to look at the front brakes because where I was getting the death wobble around 55-75 mph. After my inspection I found that both inner calipers has seized pistons and when I inspected the rear calipers they were also seized.
This was sad to hear especially we just purchased the 4Runner less that 8 months and have complained several time at the dealership we purchased from and they stated that their was nothing wrong with the brakes.
So I decided to inspect to find that front, back, and e-brakes had to be replaced. I just completed cleaning ,painting and rebuilding the calipers. Today I just finished installing the Power Stop kit front and back with stainless steel front brake lines and the car drives without the death wobble.
So if you need any help let me know.
Rich
Old 08-12-2019, 02:08 PM #13
axel1's Avatar
axel1's Avatar
Originally Posted by MAST4R View Post
The problem seems to be that you went LTE over P. Usually people who complain use LTE tires (or grossly oversized tires on Jeeps).
Another possibility I read about in 4WD magazine is if your tires cool down and develop flat spots between the time you arrive at the shop and the time they get balanced. Then balancing accounts for the flat spots and you are back to vibrations on the highway. Again, the heavy weight/grossly oversized tires/very stiff sidewall tires are where that happens.
As for psi, to be on par with P-metric tires in terms of load capacity, LT tires must be run at very different pressures, normally 42-44 for a 4Runner. That almost nobody likes doing that is another story.
Here in the desert, I can see the LT argument and I might move to an LTC eventually (though I survive just fine on P). In the Midwest (or Northwest) I would not run an LT.
What makes you say they're LT? As far as I can tell the LT A/T3W's have a separate part number and I definitely went with the standard non-LT 265/70R17.
Old 08-13-2019, 09:51 AM #14
axel1's Avatar
axel1's Avatar
Rich
I will definitely try this out. Not having a place to work on a vehicle makes it tough, but my brakes definitely need a bit of love. I think this thing sat on the lot for a decent amount of time before I got it, so I wouldn't be surprised if there was a seized caliper or two. I do have a bit of pulsating when I brake so if nothing else there's at least a warped rotor or something.
Old 08-23-2019, 02:44 PM #15
rics97toy's Avatar
Real Name: Rick
rics97toy's Avatar
Real Name: Rick
Let me know if you need some assistance and I recommend the front Power Stop brake kit. I think Amazon has the best price and free shipping.
bushings , steering , track , wheel , wobble
Wheel wobble and steering off mendozer 3rd gen T4Rs 0 04-04-2016 03:00 PM
Fix for steering wheel wobble Ron4RNevada 5th gen T4Rs 5 10-25-2015 12:16 AM
Steering Wheel Wobble Deadly_Scionide 5th gen T4Rs 13 05-18-2012 03:27 PM
steering wheel wobble Cox 4th Gen T4Rs 7 05-09-2011 01:29 PM
Steering Wheel Wobble adamg32 3rd gen T4Rs 19 05-01-2010 12:23 PM
