03-27-2019, 11:30 PM
#16
Originally Posted by Bayou_Pro
Wet sanding will get most I if not all of those out. Just remember you only get so many times to sand it though. I scratched the crap out of the wife's 18 Pro when it was 2 weeks old. Tried full out rubbing compound but no luck. I had to wet sand it but it came out looking better then the rest of the panels.
Wow! You ARE good!
You also beat me to the scratches. Mine had 3 weeks, you managed in 2!
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
03-28-2019, 05:49 AM
#17
Originally Posted by MAST4R
Wow! You ARE good!
LOL Thanks!!
Also managed to rip the running boards off on the same trip. Needed sliders anyway right?!?!
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
03-28-2019, 09:44 AM
#18
Real Name: GD
Real Name: GD
We have thin clear coats, it really helps to get someone to put on a good sealer once a year.
'16 SR5 Premium
03-28-2019, 12:22 PM
#19
Dont even go near a high speed buffer unless you have done this type of work before. One slip or to much pressure and you will burn through the the clear and likely the basecoat and maybe even hit primer..
03-28-2019, 12:41 PM
#20
the thin clear coats are why i haven't buffed out my scratches, i don't think the clear coat is thick enough to do it too many times so I'll wait until the day I want to sell it and do it once.
although some of mine is deep enough to scratch into the plastic on the pillars so it's definitely through the clear coat anyways
I like the meguiar's ultimate compound for light scratch removal
03-28-2019, 12:53 PM
#21
Trail rash is a badge of honor. I shake my head at all those heavily modified 5th gens without a single nick on their steel bumpers.
03-28-2019, 02:44 PM
#22
Absolutely, and the same thing goes for wet sanding.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
03-28-2019, 03:23 PM
#23
It just depends on what you will be using your 4runner for. IF you're going out on a monthly basis, you're going to wear down your clear coat every time you polish or buff out the tiny scratches. I used to be like that until I knew how I use the 4runner. Chalk it up to badges of honor.
My black paint is scratched from nose to tail, but every couple of months I wax it. It helps hide some of the scratches, but there are still visible scratches. First couple of times on some trails, there are branches and brush that make the trail tight. I went through so slow. Now that I know how I like to wheel, I just go through them not really worrying about it. Obviously, I wont intentionally mow through it, but trail scars arent that big of a deal anymore.
2016 Trail + KDSS | Kings 2.5 w. Adj + Ext Travel Front & Rear - JBA High Caster UCA - Icon 3" "Overland" Springs - Proline 4x4 Rear Elite Dual Swingout Bumper - Demello Offroad X-Wing Sliders - SCS Ray 10 - Falken Wildpeak MT01 285/70/17 - Dirty Pants
03-28-2019, 04:41 PM
#24
After the first day on the trail I had been broken in so to speak in regards to the horrid sounds of the branches scraping the truck from front to end even though I was doing my best to avoid them and taking it slow in hopes of reducing the damage lol. On day two I was a little more lax about it and while it still sucked to hear I was over the damage at that point. It sucks, but it is what it is and if you want to actually take your vehicle places and see these amazing views and locations then it's just part of the experience. I know they can be buffed out if not wet sanded, I will get around to it in time, but until then I'll likely add more.
03-28-2019, 06:54 PM
#25
I always carry tree pruners with me to cut away the big branches. It takes time but it is worth it to me. If the trail has a lot of brush I do not go there. That is what my atv is for.
03-28-2019, 07:33 PM
#26
You wouldn't make it more than 500 yds in on the loops in Big Bend if you did that, we covered 140 miles from Terlingua in, there's simply no way to avoid the brush and what fun would that be even if you could trim it back? You'd need weeks to widen the trails.
