Old 02-26-2020, 07:40 PM #31
msquared msquared is offline
msquared is on a distinguished road
For sure, I kept gradually trying to upgrade my headlights every year and finally pulled the trigger on a retrofit. I think its also safe to factor in what you have available. I actually had a hard time finding IS projectors for a while so I just went with what the best projectors were at the moment. Now I have too many extra headlight accessories.
The warranty on my MLED 2.0 are good for 5 years, which I think I will outlast my needs if I don't get an itch to upgrade again.
Heads up I did buy everything at 20% as I waited for the holiday sale earlier this month.
1) I did buy the Morimoto retro-quik brackets. The $24 was worth it for me. I seen Biggu's post on his DIY retrofit (2014-2017 HID Projector Retrofit DIY) and I decided I did not want to spend more time on them if I could help it.
I do want to say I did make the mounting holes larger to make my horizontal plane a 100% for micro-adjustments. I did spend like 5-10 minutes modifying.
2.) What other wiring adapters did you need?
Depending on what system, HID/LED you go with, I just had to buy headlight socket adapters (H11 male ->9006 female) and high beam splitters. Which I see is question #4. That's it. The socket adapters may have been just for my application so I highly suggest you reach out to these headlight guys to ensure the materials and build sounds solid before you dive in. Caesar @ Lightwerkz or Matt @ TRS are who have helped me before.
3.) Did you use a shroud to cover the sides of the projector and which one did you use?
I didn't use a shroud. I don't think a shroud may fit around it. Stock projectors are 3", so are the MLED series and IS 350 ones. There is about a 1/8 inch gap around the 3" projector. Just test fit your lens since the stock shroud is mounted on the lens. I did have to adjust the height higher a couple times since it sat on the bottom of the stock shroud lens when test fitted. I must say I do see a little bit of the CNC stainless steel housing if I look really hard but other than that I could of sprayed it black if it really bugged me.
4.) Did you use anything for the factory high beams?
I bought high beam 9005 cable splitters for like $4. My projectors were bi-xenon so I was able to keep the stock 9005 socket with upgraded Silverstars for keeping DRL's on. I did attempt LED light bulbs but they do not dim like halogen bulbs. So I have x2 high beams, stock + bi-xenon shield down which is nice.
This is my first time with LED projectors so I need more drive time with them. I do enjoy the ease of less wires and 'plug n play' for this build.
Here's a run down of what I bought while using the stock headlights:
-MLED 2.0 Projectors
-2x H11 headlight socket adapters
-2x 9005 high beam splitters
-Retro rubber butyl sealant.
My grand total was ~$330 and about 12 hours from bumper removal to complete assembly & driving. I felt half the time was spent opening and cleaning the permaseal. TYC should be way easier though.
msquared is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 12:36 PM #32
uh0h50 uh0h50 is offline
uh0h50 has a spectacular aura about uh0h50 has a spectacular aura about uh0h50 has a spectacular aura about
Originally Posted by msquared View Post
This is the latest thread I'm seeing regarding headlight upgrades. I have a 2017 T4R here.
I've put different bulbs (Sylvannia SilverStars, 2Stroke LED bulbs, Phillips XTR HIDs) in my stock headlights before finally retrofitting projectors.
As of Feb 2020, the best and simplest retrofit I could find browsing & after talking with Caesar from Lightwerkz was the new Morimoto Bi-LED M LED 2.0. I was planning to retrofit some Lexus IS/GS350 projectors with DS2 HID kit but turns out these new LED projectors are brighter and wider than a D2S with 50w ballast. Output wise, lux is 471 a bulb? but I think the practical measured units for actual use are Candela at 73,000 for low beams.
Anyways, I'll let the pictures speak for themselves.
Baseline wall:
Stock halogen headlights with stock bulbs:
Stock headlights with HID kit:
Morimoto HID H11 kit: 35W Ballast // Upgraded Phillips XTR HID 4300k bulbs
(I realized upgrading bulbs and ballast output was a waste of $$ at this point after plateauing my output. Real increase needed to change out projectors)
Retrofit projectors: (Morimoto Bi-LED MLED 2.0)
I gotta say that it was a PITA and took me a full day to complete with experience. That permaseal Toyota uses to seal headlights is no joke.
Couple links I could find regarding them.
YouTube
YouTube
Pic is right before I retrofitted the MLED 2.0 projectors. Running HID system in the stock headlights. Never had any blinding people problems as I made sure to aim my pattern lower than usual.
Overall, I still need to do more driving with the MLED 2.0 projectors but happy with the output and width. The cutoff is so clean that I do miss the little upward glare from the stock projector for long drives
Nicely done!
lll 2016 SR5P MGM lll OEM TRD Pro Matte Black Wheels w/ Falken Wildpeak LT255/80 17 "Pizza Cutters" l Bilstein 5100 F+R set at 1.75F + 1" Cornfed Rear Spacers l OEM TRD F+R Lower Valances l Prinsu Non-Drill Full Length Roof Rack l Shrockworks Sliders l RCI Steel Skid Plate l OEM bi-LED Headlights l DD SS3 Sport Amber Fogs l
My 3rd Row Delete Thread
uh0h50 is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 09:07 PM #33
ride16734 ride16734 is offline
ride16734 is on a distinguished road
I installed Nineo H11 along with dual color switch backs in fog light housing.
cutoff is great with no glare to traffic.
Headlight and Fog Light Upgrade Suggestions-headlight-jpg  Headlight and Fog Light Upgrade Suggestions-headlight2-jpg
91 SR5 4runner, 97 SR5 4runner, 06 Sport 4runner,
18 TRD Pro 4runner Cavalry Blue(Toytec pro lift, Nitto Ridge Grappler 285/70r17, Rigid D-SS on Rago ditch bracket, RSG angled slider, Blackout emblems, led interior, fog and h11)
ride16734 is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 11:59 PM #34
Jonny_04's Avatar
Jonny_04 Jonny_04 is offline
Jonny_04 is on a distinguished road
Jonny_04's Avatar
Originally Posted by hrantvarozian View Post
We often drive from LA to Kern River on Friday night so upgrading my headlights will make a drastic difference on visibility during the drive.
I want to focus on making the high-beams and the fog lights really bright. I wouldn't mind upgrading the headlights but I don't want to put anything in that will blind normal car drivers when my headlights are in their rear-view mirrors.
I was contemplating putting in a light bar but I just won't use it enough. I have a 3 year old so any off-roading I do is during the day.
Any suggestions would be most appreciated.
Cheers.
i drive on hwy 395 about 15-30 times a year and haven't had any issues with the lights I'm running; go with HID for your low beam and LED for your high beam. i went with 35w 5500k morimoto H11 elite HID system and 2.0 LED bulbs
'19 TRD Off Road Premium w/kdss| King shocks 2.5 w/adjusters| Total Chaos uca| Icon 2" rear coil| Nitto Ridge Grapplers 305/70/17| stealth custom series Ray 10 17x9 -38| Rigid Industries D-series amber fog lights| Morimoto HID & LED| Outgear Solutions full roof rack| Outgear Solutions rock sliders| RCI Steel Skid Plate| Drawer System
Jonny_04 is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 03:23 PM #35
atsprink atsprink is offline
atsprink is on a distinguished road
Alpharex series thoughts?
Hey all,
Been a lurker for awhile reading the different threads on headlight upgrades. I was wondering if anyone has experience with the “AlphaRex 2014-202 Toyota 4Runner NOVA-Series LED Projector Headlights”? I did like the look of the Morimoto XB led ones but after reading about the issues I no longer want those. Living in Colorado driving through the mountains in the rain/snow I definitely need better headlight options. Thanks in advance for the help/suggestions.
atsprink is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 09:21 PM #36
NB17Limited's Avatar
NB17Limited NB17Limited is offline
NB17Limited will become famous soon enough NB17Limited will become famous soon enough
Originally Posted by atsprink View Post
Hey all,
I have the Alpharex Luxx and just recently went on a ~3k mile round trip on the east coast. Encountered rain storms that were causing people to pull off the road and wait. The Luxx still lit up enough of the road I could see and keep driving. Occasionally had to turn on the BD squadron sport fogs to see well but I would not hesitate to put both those on a 4R again. IMO, save the few hundred from "downgrading" from the Novas to the Luxxs and spend that on not strictly street legal fogs.
NB17Limited is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 11:21 PM #37
dajosh dajosh is offline
dajosh is a jewel in the rough dajosh is a jewel in the rough dajosh is a jewel in the rough
I went with Kustom54 AB6’s with the Morimoto MLEDs BiLED projectors. It lights up the road really well by itself. I also upgraded the fogs with Toyota OEM LED fogs (replaced BD Squadrons which I didn’t use much). The combination is amazing.
Headlight and Fog Light Upgrade Suggestions-cf85bdd9-6abf-4945-a9a8-4ad3d3d61c37-jpg
dajosh is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 12:09 AM #38
mbm112 mbm112 is offline
mbm112 has a spectacular aura about mbm112 has a spectacular aura about mbm112 has a spectacular aura about
Hey all,
I'm literally driving to Colorado right now for my vacation. I have the Alpharex Luxx's and they've been fantastic so far. Just went through a torrential storm in western Illinois that reportedly had 70 mph winds and had no trouble cutting through the rain combined with the newer style OEM LED fog lights.
I came out of a 2018 IS350 and I would say these are pretty comparable in performance. The output is nice and even and has pretty good width. My only complaint is the cutoff is a little sharper and deeper than I'd like so I had to raise them to cover more on the left.
OEM fogs add a TON of width and good foreground light. I tend to keep the fogs off when I'm on the highway to cut down on foreground glare and preserve distance vision.
Headlight and Fog Light Upgrade Suggestions-img_20200711_230200-jpgHeadlight and Fog Light Upgrade Suggestions-img_20200702_212052-jpg
Sent from my Pixel 4 XL using Tapatalk
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
mbm112 is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 03:13 PM #39
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
Long read but interesting and valid.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 08-22-2020, 12:31 PM #40
Those look nice. I also upgraded the fog lights with the OEM LED ones as well. Thanks for the suggestion. I’m going to look at these.
Old 08-22-2020, 07:02 PM #41
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
I can't speak to an upgrade to the high beams, as my 30" dual row bar in the bumper takes care of that, but I could not be happier with these fog lights from Diode Dynamics. Absolutely outstanding. I got pro level, and never get blinked at, so not sure if they aren't a problem for oncoming traffic, or people just are blinded too much to reach for their high beam...lol
https://www.diodedynamics.com/stage-...light-kit.html
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 08-22-2020, 07:24 PM #42
miamiman miamiman is offline
miamiman is on a distinguished road
Attachment 365313Attachment 365314
I was gonna ask if this works on the limited till I saw the front end. I have a nightshade and want this same exact setup! Thx
miamiman is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 01:08 AM #43
NaiveTurtle NaiveTurtle is offline
NaiveTurtle is on a distinguished road
The Xenon Depot HID kit has been great for the low beams as a drop in retrofit.
For fogs, you gotta go with Diode Dynamics and their SS3 pods. Even the SS3 Sports are crazy bright and throw light way down the road in a nice wide pattern. They truly have a square cutoff which will keep oncoming traffic from flashing you. I compared to a Squadron Sport wide cornering (their typical fog) and the squadron was bright but threw light everywhere making it more of a flood and rather unusable. The SS3 put light right where it needed to be.
NaiveTurtle is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 04:44 AM #44
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
Originally Posted by mrblah View Post
running HID's for low beams
2 IN 1 LEDS for fogs
switch back LED's for corners
PIAA hyper yellow halogens for Hi beams
I'm very happy with this combo.
And now this is my combo haha and I'm very happy with it.
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 01:34 PM #45
sandcrawler's Avatar
sandcrawler sandcrawler is offline
sandcrawler has a spectacular aura about sandcrawler has a spectacular aura about
Originally Posted by cb1111 View Post
yes. this.
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
sandcrawler is offline   Reply With QuoteReply With Quote
fog , headlights , light , suggestions , upgrading
Headlight upgrade suggestions? T-Bruff 4th Gen T4Rs 24 01-14-2021 06:45 PM
LED headlight and fog light upgrade / replacement Adoniram 5th gen T4Rs 1 05-15-2018 04:04 PM
1st Gen Brake upgrade suggestions? Griswald Classic T4Rs 15 04-30-2016 11:28 AM
Speaker upgrade, suggestions.... stream4r Engines / Suspension / Wheels / Tires / Audio / Accessories 1 05-31-2006 12:41 PM
