Old 03-30-2019, 11:55 AM #16
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Originally Posted by jhguth View Post
On a gravel FS road just drop your pressure a little, reducing 5psi should make the ride comfortable
Originally Posted by calcrc View Post
I hear you guys, 20 psi seems to be the sweet spot.
I will be driving around 45 miles/hour most of the trip. Give or take
Thanks for the fast replies.
Originally Posted by Olddudesrule View Post
What is the condition of the forest road? If it's anything like ours here in AZ, I wouldn't air down at all. Waste of time and effort on a well maintained, flat, relatively smooth dirt/gravel road. Also, if you do air down, do you have a way to air up before you travel distance on hardball road or is there a gas station near the end of the forest road?
That ^
It really does not matter for forest roads.
Most importantly, most people forget that it all depends on P vs LT in harsher terrain.
YOU DON'T WANT TO AIR DOWN P-METRIC AT TIRES FOR ANYTHING BUT DEEP SOFT STUFF.
1/ They have plenty of flex at street pressures.
2/ They are plenty comfortable at street pressures.
I run Backaway to Crown King, Broken Arrow, Crapshoot, and every other low-end difficult, moderate, or easy trail in AZ or UT at 33 psi.
AIRING DOWN P-METRIC IN HARSH TERRAIN=TROUBLE with sidewalls.
On the other hand, LT tires especially E-load are worthless at street pressure in harsh terrain. At street pressures, they have no flex, and thus have poor traction and they will also rattle your teeth. They must be aired down to around 20 psi or less to perform properly in harsh terrain. At 18-20 they should have great traction and ride very smooth as well.
But, again, on a forest road, the only issue would be comfort.
Old 03-30-2019, 09:11 PM #17
SwayzeExpress's Avatar
SwayzeExpress SwayzeExpress is offline
SwayzeExpress is on a distinguished road
Originally Posted by MAST4R View Post
That ^
If you mean harsh as high friction, I agree, if you mean harsh as questionable sometimes cutting through a soft layer to solid bed is worth some psi...
I deal with a lot of ruts and mud in the midwest, fully understand that geography is the decision maker
SwayzeExpress is offline   Reply With QuoteReply With Quote
Old 03-30-2019, 09:24 PM #18
MAST4R's Avatar
MAST4R's Avatar
Sorry for the generic expression!
The typical Southern AZ terrain, mile per mile, is the same from easy to very difficult trails, aside from the obstacles. It consists of extended sections of broken sharp rock and constant wash crossings and drainages running across the trail. In these conditions, a P-metric tire will expose its sidewalls too much and would also risk a pinch puncture though I am not very familiar with the latter and unsure if it applies to P more than to LT.
Say, Southern Utah terrain can on occasion be similar to Southern AZ but normally you get a lot less broken loose sharp rock to deal with. In SW Colorado, there is a lot of broken rock, too, but the sections are at least very short and very slow speed.
I saw nothing like this in Montana where we drove more than two dozen dirt roads and trails. We did two rocky trails, but the rocks were well-rounded, like riverbed rocks, not sharp rocks. We went through a lot of fallen branches though, at street pressures, and had no issues. So I guess that is the mountain equivalent of the desert sharp rock!
Old 03-30-2019, 11:41 PM #19
mcox522's Avatar
mcox522 mcox522 is offline
mcox522 is on a distinguished road
mcox522's Avatar
I explore in the Phoenix area
2016 trail with KDSS
265 KO2 C rated
38 psi street
~28 psi forest roads and smoother dirt roads and depending on outside temperature.
That's what works for me, try things out and see what works.
If you have P rated tires, do yourself a favor and get something else.
Sent from my SM-N960U using Tapatalk
mcox522 is offline   Reply With QuoteReply With Quote
Old 03-30-2019, 11:48 PM #20
Lucky dog! Its wild how lacking the midwest is with true open lands. Have fun and any dont think about your tires so much unless you feel they could be better. I guess I'm saying you may prefer feeling the road more where someone else may want to float all over lol
Personally I'd head out and see then air down after enough time to feel the difference. It will make future decisions easier. I only air down for muddy hills
Old 03-31-2019, 12:41 AM #21
MAST4R's Avatar
MAST4R's Avatar
265 KO2 C rated
38 psi street
You didn't read my posts above, did you? They work just fine at street pressures. However, if I stayed only in AZ, then probably I would be using something else.
Lucky dog! Its wild how lacking the midwest is with true open lands. s
That's true, open in all sorts of ways. In Montana, we explored a lot and it is fun because the dirt roads there are narrow so they feel like easy trails but fast. But the downside is that you are normally just in a forest. SO you may think you are on the Upper Peninsula. I like forests a great deal, but I would not normally want to drive an actual 4x4 trail in a forest, only once in a while for the heck of it. Forest trails where I can be slow but do not have to be slow, that's fun.
By contrast, AZ, UT, CO offer so much both in terms of public land and in terms of open vistas. So do SE California and NV though I find them a lot less appealing, especially NV.
Old 03-31-2019, 01:08 AM #22
mcox522's Avatar
mcox522's Avatar
Well....seing as you're not the OP of this thread and I replied to the thread, then no I was not responding to you. Just because I posted after you doesn't mean it was directed at you, I would have replied to you quote if I was.
But I agree with your idea of P vs LT tires. At minimum C or LT is the way to go if doing any kind of offroading.
Old 03-31-2019, 11:56 AM #23
Tejas Tejas is offline
Tejas is a jewel in the rough Tejas is a jewel in the rough Tejas is a jewel in the rough
I almost always drop to 20psi, I run 275/70 KO2's on the Pro wheels. I would go lower but haven't yet felt the need. Without beadlocks I see no reason to go lower than 15psi, YMMV.
Tejas is offline   Reply With QuoteReply With Quote
Old 04-01-2019, 04:04 AM #24
samster747 samster747 is offline
samster747 is on a distinguished road
white rim trail on bfg ko2 c?
samster747 is offline   Reply With QuoteReply With Quote
Old 04-01-2019, 07:50 AM #25
calcrc's Avatar
calcrc calcrc is offline
Real Name: Sebastian
calcrc is on a distinguished road
calcrc's Avatar
I have LT Duratracs load range D.
2011 4RUNNER TRAIL KDSS
SHROCKWORKS Front Bumper - Rugged Ridge Winch 9500lbs - PIAA Lights - Hella Horns - SpiderTrax 1.25" - Airlift 1000 - 285/70R17 Duratracs - Borla Exhaust System - Wirthco Dual Battery setup - Deep Cycle AUX - Front OME Heavy Duty 2.5" Coils + NITROCHARGERS - Rear OME 3" Coils + NITROCHARGERS
calcrc is offline   Reply With QuoteReply With Quote
air , forest , guys , question , road
Quick question tundra fabtech dirt logic question Diggo 3rd gen T4Rs 3 06-09-2016 02:33 PM
Question about 2013 Limited vs SR5 rim & tire question? duckman06 5th gen T4Rs 21 01-09-2013 07:06 AM
2003 V8 90k Maint. Question + Steering Question zerowkul98 Maintenance/Detailing 1 10-21-2010 07:35 AM
Pro Comp Light Bar Question- Tire Rim Question rngesci 3rd gen T4Rs 1 10-25-2008 03:04 PM
