03-29-2019, 03:54 PM
Real Name: Sebastian
Question about air down.
Hi guys, I just wanted to ask your advice. We will be going on a fishing trip late May and we will be doing around one hour and a half at least of forest road.
What tire pressure you guys recommend we should air down to ?
Thanks in advance.
2011 4RUNNER TRAIL KDSS
SHROCKWORKS Front Bumper - Rugged Ridge Winch 9500lbs - PIAA Lights - Hella Horns - SpiderTrax 1.25" - Airlift 1000 - 285/70R17 Duratracs - Borla Exhaust System - Wirthco Dual Battery setup - Deep Cycle AUX - Front OME Heavy Duty 2.5" Coils + NITROCHARGERS - Rear OME 3" Coils + NITROCHARGERS
03-29-2019, 03:59 PM
Thanks in advance.
20 PSI is a conservative number.
I air down between 20-15 depending on the terrain.
03-29-2019, 04:00 PM
@ calcrc
the sweet spot will depend on the terrain, your tires, and how fast you want to go, but I usually drop down to 20 or so as a starting point. Have fun!
03-29-2019, 04:29 PM
Real Name: Chris
Real Name: Chris
I typically air down to 15 in most cases, and further to 10 in special cases (deep or icy packed snow).
It depends on the tire, but the lower you go, the slower you should go. Speed creates more heat and friction in the make up of the tire and can compromise the integrity of them.
2018 TRD ORP w/ KDSS: King extended travel coilovers & shocks w/ adjusters - Icon tubular Delta Joint UCAs - Icon 2" rear springs - 17x9 -38 offset Stealth Custom Series stealth blue F5 wheels - 305/70R17 Nitto Ridge Grappler tires - C4 Fab Lo-Pro bumper - Baja Designs 30" S8 - Baja Designs Squadron Sport fogs - TRD Pro grille and rear bumper valance - Full custom audio system w/ CarPlay - URD MAF calibrator - Sprint Booster - RCI skid plate - Shrockworks angled sliders - Front Runner roof rack and Maxtrax mount - Xenon Depot Xtreme HID Philips 4300K low beams - ARB on-board air compressor w/ Rago Fab mount - Wifey 4-corner air system - Warn VR10-S winch w/ Factor 55 fairlead and Ultrahook - Odyssey 34R-PC1500T battery - Voltage booster - T4RPAM with Yaesu FTM-400XDR radio and Android tablet running Backcountry Navigator and APRSdroid
03-29-2019, 04:32 PM
Real Name: Jeremy
Real Name: Jeremy
you shouldn't have any issues on the forest road running regular tire pressure..if you were going to be in soft sand or conditions where a lot of tire patch is necessary I wouldn't hesitate to go as low as 15..I run down to 12 on my off-road rig.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
03-29-2019, 05:37 PM
true, but that long on a gravel road, running aired down is usually a nicer ride.
id think 20 would be a good number.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
03-29-2019, 05:54 PM
Are running d or e rated duratracs?
Either way I'd save the time of airing up and down on forest roads and spend it catching fish
03-29-2019, 05:55 PM
I won't do any less than 15 lbs since I don't have beadlocks. On that road you are talking about, yea probably 20 to 25.
And on another note, Stauns deflators are amazing. More expensive than the cheap ones on Amazon, but I think the quality will keep these working for a long time. Screw them on each wheel and wait until they stop, easy as that. I think they are supposed to be factory set to 18 lbs, mine stopped at 15 which was fine. You can adjust them to any setting you want. I got the standard duty 6-30.
Staun Deflators
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
03-29-2019, 06:17 PM
I have staun deflators set at 18 and since I"m lazy, thats the number i deflate to regardless of where I go.
03-29-2019, 06:43 PM
Real Name: BobH
Real Name: BobH
I do 15 for soft sand and 18 to 20 for trails. Sofens the ride, easier on ball joints, wheel bearings and you.
03-29-2019, 06:51 PM
I air down between 15-20 usually on forest roads.
IG: ksotrdpro
2015 Inferno Red TRD Pro | Piaa Platinum LED Headlights | Shrockworks Dual Battery Relocator | National Luna Dual Battery Kit | Optima Yellow Top | SPOD SE | ARB Air Compressor | Rago MSP | Expedition Essentials T4RPAM | C4 Fab Rock Sliders | C4 Fab Dual Swing Rear Bumper | Frontrunner Slimline II Rack | KC C-Series Lightbar | Cooper Discoverer STT Pro 285/70/17 | Dobinson C59-701V | Fox 2.5 Shocks with Remote Resi and DSC | ProComp 2.25" Front Spacer
03-29-2019, 07:10 PM
I've gone to 8-10psi for years in the sand, I am carefull about not pulling the bead off the rim and I wasn't easy on the throttle either. For hard pack, it depends on the tire. I'd say start 15psi or when the tire visually starts to bulge out.
2005 4R V8 4x
03-29-2019, 07:42 PM
On a gravel FS road just drop your pressure a little, reducing 5psi should make the ride comfortable
03-29-2019, 07:48 PM
I hear you guys, 20 psi seems to be the sweet spot.
I will be driving around 45 miles/hour most of the trip. Give or take
Thanks for the fast replies.
03-30-2019, 11:48 AM
What is the condition of the forest road? If it's anything like ours here in AZ, I wouldn't air down at all. Waste of time and effort on a well maintained, flat, relatively smooth dirt/gravel road. Also, if you do air down, do you have a way to air up before you travel distance on hardball road or is there a gas station near the end of the forest road?
