I was going to install my lift this weekend, however, no alignment shops will be open until Monday. If I install at my cousin's house, who has a 2 post lift and fully stocked garage, I'll have to drive 30 miles to get back home and then roughly 45 miles on Monday to the alignment shop.
I'm wondering if it should be okay for that drive without an alignment?
Dobinsons 2.5/1.5 and I am currently running stock size Falcon Wildpeaks. I will be keeping stock UCAs.
2017 Barcelona Red SR5 4WD - Dobinsons 2.5/1.5, ToyTec 1/4" top spacers, JBA UCAs, Konig Countersteer Type X, 285/70 Toyo AT3s.
You definitely want to drive 50-100 miles before the alignment. Otherwise you will likely be off as there is a lot of settling the first several dozen miles and 48hr.
__________________ 2018 TRD OP non-kdss, well armored, well used
