Old 05-09-2022, 05:06 PM #16
rcb22 rcb22 is offline
rcb22 is on a distinguished road
My rear window was smashed in by some a*hole who stole my wife's bags last week. Safelite repaired the window but now it goes up really slowly and sometimes will drop down a few inches before going back up. The installer managed to mess up the bolt for the wiper so I have to go back in once they get the replacement for that. Hopefully they'll figure out why it is going up slowly.
rcb22 is offline   Reply With QuoteReply With Quote
Old 05-09-2022, 09:41 PM #17
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I would have them inspect the regulator assembly carefully and the attachment point on the glass. Either a bolt fell out or the glued on mount pulled off would be my first two guesses after the regulator not being reinstalled right. (Can you grab the glass and move it up or down any significant amount if the window is like half way open? )
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 03-07-2023, 07:54 PM #18
Jon S Jon S is offline
Jon S is on a distinguished road
Originally Posted by RaceAddict View Post
Seems like I'm in this same boat with my 2016.
The rear window has always been slow in the winter, but over the past year or so it's been somewhat sluggish even in the summer. This morning though (-17ºC here) I accidentally hit the down button while driving and it wouldn't go back up. Tried from inside and outside, no luck. The only way I could get it to roll back up was pull the button on the console, it moved an inch or so... wait 2-3 minutes, pull the button again... another inch or so... wait...
I'm guessing the grease on the mechanism is frozen, or at the very least thickened up, to a point that prevents it from moving correctly. I'll have to get it into my shop garage as soon as possible and pull the rear panel, clean up the mechanism, maybe re-grease it with something very light and temperature resistant?
Mine has been slow recently, last night I rolled it down 14" or so and then it did as RaceAdddict's did, would go up with help from me about an inch or so, wait, etc. Took about 10 minutes to get it all the way up.
Motor, grease?? Seals? Appears door is on the track as it's level.
Jon S is offline   Reply With QuoteReply With Quote
Old 03-08-2023, 12:32 PM #19
Humble Leader's Avatar
I replaced the motor and regulator a few months ago. had the slow window in the cold weather and kept getting slower. you can try greasing the tracks, silicone lube, etc. but that will only be temporary. the regulator and/or motor are going bad. there's a very small chance the issue you are having is old grease build up but if it's 5+ years old and you've used that window a lot it's time to replace parts
after new motor and regulator that window flies up and down. even well below freezing the window moves fast like new. parts are expensive and the labor is a few hours if you bring it to toyota, but if you use the back window a lot it's a repair you're going to have to do at some point. my advice is if you're going to open up that back panel yourself of pay someone to do it might as well do motor and regulator at the same time if they are original and your rig is on the older side. my factory rear motor and regulator lasted 11 years... not too bad, and I think the motor was fine, just the regulator had enough
Old 03-09-2023, 01:09 AM #20
Thanks, guess I’ll try and pull it apart and grease and inspect and replace stuff. Are there any good videos tha anyone recommends watching to see what to send not to do?
Thanks,
Jon
Old 03-09-2023, 10:16 AM #21
Thanks,
Jon
there are tons of 5th gen rear panel removal videos but not many 5th gen regulator and motor replacement videos (I couldn't find any when I was looking into this repair). there are some for 4th gens on youtube. I wouldn't say it's hard but it's definitely helpful to have 2 people and it's a weird working angle, you're looking up the whole time unless you remove the lift gate. I had toyota do this for me, not something I wanted to attempt
Old 03-21-2023, 08:17 PM #22
Took the rear panel off and window is up. Suspecting I will need to lower it to see the motor and regulator.
The blue film that is there was completely removed except at the bottom, the tar like substance was removed from most of it, betting I know who did that, think that had any impact on it?
Where is the motor back there?
I also see 6 bolts holding a speaker in on driver side and two white push pins made of plastic. Feels like a point on the back? I'd love to take some of those off as it appears they would provide me much greater access.
How does one get those out, I could take a pic, but betting someone knows, they are in a slot on opposite ends, preventing it from moving while bolts are detached.
Thanks
Old 03-22-2023, 09:40 AM #23
Thanks
check this video, it's for a 4th gen but process will be similar
https://www.youtube.com/watch?v=iUl-k57Gm2Q
Old 04-23-2023, 06:12 PM #24
Darn if I didn’t get it all out and had the wrong Dorman motor.
742-600 and 742-601
Both have a star wheel type drive. Mine has a square drive with round hole in it.
Pics to follow
The one in my 4r is
85720-35160
Any leads on those at something significantly less than $300? Auto zone, Napa have nothing, or that’s what they say.
Can’t locate one at rock auto.com.
Looks like 85720-35161 might replace mine.
Any help,is appreciated, got all the dust and 1/2” of caked on kid out of the bottom of the door panel and would love to put it back together and have window operable for less than $100 if possible.
Thanks,
Jon
open , rear , seat , stay , window
Another rear window problem ampant Classic T4Rs 3 12-29-2014 09:59 AM
Rear window problem - 1990 4Runner - motor works but window wont move mike_hill2107 Classic T4Rs 3 12-12-2011 08:13 PM
rear window problem runnerguy 4th Gen T4Rs 5 03-06-2010 09:16 PM
92--Rear window problem stcwll Classic T4Rs 4 02-24-2008 08:41 PM
Another rear window problem 1fastrunner Problems & Warranty Issues 2 08-22-2007 04:51 PM
