Old 03-30-2019, 05:22 PM #1
HunterQc HunterQc is offline
HunterQc is on a distinguished road
Rear window problem
Hi Guys!
I’m in the middle of a road trip with my 4Runner, it's snowing as hell and my rear windows jamed half open! When I try to close it with the switch next to the driver's seat, I hear a sound, probably the rear window motor, but nothing happening. The window stay open. Any ideas how to fix this?
Thanks for your help!
David
HunterQc is offline   Reply With QuoteReply With Quote
Old 03-30-2019, 05:31 PM #2
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
I'd pull the rear panel so you could get in there and try and help it up. At least you might have a shot of getting it to go up as a temp fix.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 03-30-2019, 05:38 PM #3
Thanks for your help! Do you mean the little panel 2’’ x 4’’ in the middle? I opened it but I saw nothing?
Old 03-30-2019, 05:48 PM #4
Redsoxx1918 Redsoxx1918 is offline
Redsoxx1918 is a jewel in the rough Redsoxx1918 is a jewel in the rough Redsoxx1918 is a jewel in the rough Redsoxx1918 is a jewel in the rough
Originally Posted by HunterQc View Post
Hi Guys!
David
If you don’t have any tools, large clear plastic garbage bag and some duct tape until you get somewhere you can work on it.
Redsoxx1918 is offline   Reply With QuoteReply With Quote
Old 03-30-2019, 05:52 PM #5
Yeah, good idea. Mission impossible in a Mcdo parking with no tools. First I thought the wiper was not in the right place but it looks fine.
Old 03-30-2019, 07:47 PM #6
Bayou_Pro's Avatar
Bayou_Pro's Avatar
No I meant the whole back panel. All you'd need would be a 10mm socket and ratchet.
Paul
Old 03-30-2019, 07:58 PM #7
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Look at the glass and see if it is even (same distance up on each side) and if it looks like it's still in the track. You may be able to help it up by pulling up on the glass while someone operates the switch. It may help to go down a little first - then up. Also check to see tracks are clear - don't force things.
Old 03-31-2019, 11:03 AM #8
Thanks, it was exactly like that. I’m not sure the distance is the same each side but I pulled up the glass, insert 3 credit cards to prevent him from going down and I ram to my truck to operate de switch. Instead of 1 foot it is now 3 inch.
The problem is the glass not in the track?
Old 03-31-2019, 02:21 PM #9
I found this video! I think it will be very usefull and I hope I will have fewer parts to remove.
I think I need to:
1- Open a beer, just one
2- Remove the ruber pieces around the glass
3- Remove the glass.
4- Open the rear panel, the speaker and maybe few other parts
5- Check the rails and the mechanisms, clean them if necessary.
6- Re-install the glass
7- Check the rails and the mechanisms to be sure the glass is at the right place
8- Not sur at this time if I will be able to test if I can pull up the glass with the switch but I will try.
9- Re-install parts, panel, ruber
10 Try the switch, enjoy the view of my glass pulling up, shed a tear and open a beer.
Old 10-24-2021, 02:01 PM #10
4runnerbry 4runnerbry is offline
4runnerbry is on a distinguished road
Rear window rust defrost
Hi , I’m new here and hope someone can help.
My rear window mechanism rusted out and the window won’t go back up on its own. I forced it up and clamped it there but now my rear defrost won’t work (neither does the wiper). Does anyone know how to make the defrost work? I’m not too concerned about the window going up and down at this point.
I took the cover off hoping to find some sort of switch but….
2010 4Runner
4runnerbry is offline   Reply With QuoteReply With Quote
Old 10-24-2021, 03:07 PM #11
flyrv9's Avatar
flyrv9's Avatar
There is a switch that is closed by the window when it's all the way up. The closing of this switch is what allows the rear wiper to work. The window can appear to be all the way up; but not be. There have been a few threads about this; as the switch is pretty sensitive. The defroster function may also be tied to this as well.
Old 01-12-2022, 11:07 AM #12
RaceAddict's Avatar
RaceAddict RaceAddict is offline
Real Name: Kevin
RaceAddict is on a distinguished road
RaceAddict's Avatar
Real Name: Kevin
Seems like I'm in this same boat with my 2016.
The rear window has always been slow in the winter, but over the past year or so it's been somewhat sluggish even in the summer. This morning though (-17ºC here) I accidentally hit the down button while driving and it wouldn't go back up. Tried from inside and outside, no luck. The only way I could get it to roll back up was pull the button on the console, it moved an inch or so... wait 2-3 minutes, pull the button again... another inch or so... wait...
I'm guessing the grease on the mechanism is frozen, or at the very least thickened up, to a point that prevents it from moving correctly. I'll have to get it into my shop garage as soon as possible and pull the rear panel, clean up the mechanism, maybe re-grease it with something very light and temperature resistant?
2016 TRAIL - MGM
C4 Bumper - WARN VR10S
OME Lift - Prinsu Rack
Adventure Index DIY Storage System
Summer: Falken A/T3W (Winter: Nokian Hakkapeliitta 8 SUV)
RaceAddict is offline   Reply With QuoteReply With Quote
Old 05-07-2022, 02:38 PM #13
troutscout31 troutscout31 is offline
troutscout31 is on a distinguished road
Replace the motor/regulator?
Anyone have insights on replacing the motor or regulator on the rear lift gate? The cables on mine seem to have gotten bound around the motor and the rest of it is pretty heavily rusted. Figure if I’m going to dissect it, might as well replace it.
troutscout31 is offline   Reply With QuoteReply With Quote
Old 05-07-2022, 03:30 PM #14
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
It's not horrible to do, you can either tape the glass in the Up position after you unbolt it from the regulator; though if I remember right I ended up having to remove it completely to get enough room to work in the door last one I did (it's been a year or so). Removing the glass will require unbolting the spoiler assembly from the door and removing the plastic trim on the left and right side of the door, it's a bit of a tedious affair, but doable.
As for the regulator itself, it's not clearly stated in the instructions, but you have to kinda fold and unfold it in and out of the hatch opening to get it to go in properly; it's a bit of trial and error so take a picture before you remove it so you can get a rough idea how it goes back together.
I would also make sure you have a new regulator and a motor, it's possible the cables could have burned out the motor or shortened it's life by overheating it (should be protected, but old vehicles and all that). I would also highly recommend replacing at least the exterior belt moulding that goes on the hatch and seals with window and interior of the rear hatch as that will lessen the likelihood of debris, moisture, and such getting in and gumming up your cables again (at least for a while... it's an often overlooked item that I am sure is very brittle/poorly sealing on many 4Runners after a while).
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 05-08-2022, 02:05 PM #15
jhebert9 jhebert9 is offline
jhebert9 is on a distinguished road
Rear window
Be careful with duct tape. My wife broke ours and I taped plastic over it. When i removed the tape it left a mark on the facing.
jhebert9 is offline   Reply With QuoteReply With Quote
open , rear , seat , stay , window
Another rear window problem ampant Classic T4Rs 3 12-29-2014 09:59 AM
Rear window problem - 1990 4Runner - motor works but window wont move mike_hill2107 Classic T4Rs 3 12-12-2011 08:13 PM
rear window problem runnerguy 4th Gen T4Rs 5 03-06-2010 09:16 PM
92--Rear window problem stcwll Classic T4Rs 4 02-24-2008 08:41 PM
Another rear window problem 1fastrunner Problems & Warranty Issues 2 08-22-2007 04:51 PM
