Old 03-31-2019, 12:30 PM #1
kdub351's Avatar
kdub351 kdub351 is offline
kdub351 is on a distinguished road
kdub351's Avatar
Help! Lean has me baffled...
2016 SR5 non kdss
4wd
Running dobinsons c59-675v in the rear with 59-575 shocks
All other suspension parts stock
The truck is leaning on the drivers side rear something fierce! Dobinsons even sent me another rear coil free of charge, I swapped it and got the same amount of lean. I have even went as far as disconnecting the sway bar, seeing how much tension the stock links were under.... but still no effect on lean.
Fender to ground
Rear passenger: 41.5 inches
Rear driver: 37.5 inches
Any ideas?
2016 SR5 4wd... bone stock for now. wheel what you got...
kdub351 is offline   Reply With QuoteReply With Quote
Old 03-31-2019, 12:41 PM #2
Grape Ape Grape Ape is offline
Grape Ape will become famous soon enough
That seems really off...Try moving it to another spot and see if it was due to uneven ground. Also, how much gas weight is in there right now?
Grape Ape is offline   Reply With QuoteReply With Quote
Old 03-31-2019, 12:47 PM #3
kdub351's Avatar
kdub351's Avatar
Half tank
Yes I’ve moved it around and measured, same issue.
I’m kind of at my wits end
Old 03-31-2019, 02:12 PM #4
Hydguy's Avatar
Hydguy Hydguy is offline
Hydguy will become famous soon enough Hydguy will become famous soon enough
Hydguy's Avatar
Was it leaning like that before the lift?
Hydguy is offline   Reply With QuoteReply With Quote
Old 03-31-2019, 02:20 PM #5
kdub351's Avatar
kdub351's Avatar
Not at all.
Old 03-31-2019, 02:40 PM #6
hwnrunner's Avatar
hwnrunner hwnrunner is offline
hwnrunner will become famous soon enough hwnrunner will become famous soon enough
hwnrunner's Avatar
Have u tried switching the dob spring from left to right or putting the stock spring back to see if lean is still present?
2019 SR5 Premium 2WD - TRD PRO Front Struts & Coils w/ Toytec 1" Perch Spacer / Dobinson's C59-505 Rear Springs / ICON VS 2.0 Rear Shocks / TRD PRO Grill & Valences/ TRD CAI /URD MAF Calibrator / TRD PRO Wheels / BFG KO2 275 70 17
hwnrunner is offline   Reply With QuoteReply With Quote
Old 03-31-2019, 02:47 PM #7
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light
official vendor
Get it on a lift, loosen all the suspension related bolts and re-torque them to factory spec at full droop.
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
Old 03-31-2019, 03:34 PM #8
kdub351's Avatar
kdub351's Avatar
Is this a common install issue that causes this?
At this point I’m willing to try anything
Old 03-31-2019, 04:11 PM #9
yardsale's Avatar
yardsale yardsale is offline
yardsale will become famous soon enough
yardsale's Avatar
Are you missing that cone shaped bumper that goes on top of the spring from the low side? Are the installed springs the same height? Are both springs seated properly at the bottom?
yardsale is offline   Reply With QuoteReply With Quote
Old 03-31-2019, 04:14 PM #10
kdub351's Avatar
kdub351's Avatar
Cone bumper is there, installed springs are same height, and both springs are seated properly....
Old 03-31-2019, 05:16 PM #11
codyHTX's Avatar
codyHTX codyHTX is offline
codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light
codyHTX's Avatar
You should post some pics of the lean and then underneath to see shocks/springs/arms
Edit: those are 3” springs right? Maybe an adjustable track bar is in order, also, at droop you may even be needing adjustable/offset lower trailing arms
2015 Trail Premium
SCS/BFG, King/Dobinsons/JBA, Icon/Sonoran Steel, Hefty Fabworks, Shrockworks, RCI, XD HID, Gobi, FJ Toyman, GZila, Dog-Proofed
codyHTX is offline   Reply With QuoteReply With Quote
Old 03-31-2019, 07:33 PM #12
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Do you have KDSS?
Old 03-31-2019, 08:19 PM #13
kdub351's Avatar
kdub351's Avatar
Originally Posted by mtbtim View Post
Do you have KDSS?
No kdss
Old 03-31-2019, 08:22 PM #14
kdub351's Avatar
kdub351's Avatar
I’m working on the photos
Yes they are the tall springs... will the adjustable track bar help the lean When the truck is sitting level?
I plan to add the rear trailing arms eventually when I bend something, but for now I’m looking to remedy this lean
Old 03-31-2019, 08:48 PM #15
codyHTX's Avatar
codyHTX's Avatar
I don’t know exactly, I do run their 677v coils with adjustable track bar andtrailing arms without issue
The comment on track bar is mostly from doing coil swaps: the driver side has the track bar mount on the axle which makes that side feel tighter and more difficult to stretch out, could that maybe translate to excessive lean if the coils are fighting the geometry enough?
2015 Trail Premium
dobinsons , inches , lean , rear , stock
KDSS and spring selection-keep the lean or correct the lean? Catskill4RNR 5th gen T4Rs 22 11-10-2019 11:12 AM
Feeling Baffled. WeldTightFab 4th Gen T4Rs 1 07-27-2015 11:05 AM
My Mechanic is Baffled scrbear11 4th Gen T4Rs 17 07-28-2013 11:12 PM
Terrible noise has me baffled Outrider 3rd gen T4Rs 27 03-11-2011 07:26 PM
I'm baffled... 1995 4runner dwighter Classic T4Rs 1 02-07-2011 01:50 AM
