Old 03-31-2019, 06:10 PM #1
Tejas Tejas is offline
Tejas is a jewel in the rough Tejas is a jewel in the rough Tejas is a jewel in the rough
TRD Pro Bilstein spring swap
I am still running the factory Bilstein's that came on my TRD Pro in conjunction with a 1.5" two-piece spacer up front. I plan to install an ARB Summit bumper and winch up front here in the coming weeks to get me by until I can get around to King's or BP-51's later this year. I know this bumper and winch combo is quite heavy so it'll undoubtedly cause the front end to sag. Can I swap out the factory springs for a heavier spring, say something closer to 700lbs in order to better handle the load and if so which make and model spring should I buy? Thanks for any help!
Tejas is offline   Reply With QuoteReply With Quote
Old 03-31-2019, 06:12 PM #2
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
From what I understand 700 pound springs are not a good idea on the 6112 shocks. Put's too much load on the lower spring seat.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 03-31-2019, 07:26 PM #3
So can I get away with a lower spring rate? If not, what do you suggest?
Old 03-31-2019, 07:46 PM #4
Real Name: Chris
Real Name: Chris
I would contact Bilstein about it, they know a lot more than I do. If what I have heard about the 700 pound springs is correct, there really isn't anything you can safely do besides upgrade the shocks at the same time as the bumper and winch.
Old 03-31-2019, 08:47 PM #5
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
You have a couple of options here depending on how you want to go. The stock Pro spring rate is like 13" 520ish# spring.
1. Go up to a Eibach or equivalent (manufacturer almost everyone's springs) 13"x 3" coilover 600# or 650# springs and you your spacers that you have now.
2. Go with a 14"x3" 650# spring, ditch the spacers and use the oem TRD Pro lower perches. This will give you about 2" of lift over a stock Pro setup and plenty of weight to carry your bumpers. If go option #2 myself.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 06:59 PM #6
T4Ronner T4Ronner is offline
T4Ronner is on a distinguished road
Are you still on stock UCA’s? Are you running the 600 or 650lb springs? Looking to get 2.5”ish out of my Bilstein TRD pro suspension. The 600lb Bilstein springs are hard to come by. But Kings 14x3 600lb can be had from wheelers at a decent price. Hmm
T4Ronner is offline   Reply With QuoteReply With Quote
bumper , front , pro , spring , winch
Bilstein 5100 and Old Man Ema Spring CT_NGO 5th gen T4Rs 15 03-21-2017 05:14 AM
How come no FJ spring swap on 5th gen ? 8086bruce 5th gen T4Rs 18 09-06-2016 07:14 PM
FJ Cruiser Bilstein 5100/Coil Spring Swap chips2002 4th Gen T4Rs 5 12-31-2015 06:55 PM
Bilstein and spring ideas backi00 5th gen T4Rs 8 10-27-2014 01:57 PM
Bilstein 1.75/FJ spring measurement? SlvrV8Rnnr Engines / Suspension / Wheels / Tires / Audio / Accessories 0 10-13-2013 10:48 PM
