Old 04-25-2019, 05:17 AM #16
808leo 808leo is offline
808leo will become famous soon enough
Originally Posted by 83Mule View Post
I'm on stock springs and it rides mellow.....I would go stiffer but the wife likes the ride as is.
I know what you mean. I liked how my truck rode, but the boss hated it fml
2018 SR5 Premium Silver 4WD
808leo is offline   Reply With QuoteReply With Quote
Old 04-25-2019, 09:04 AM #17
SoFloT4Run SoFloT4Run is offline
SoFloT4Run is on a distinguished road
Originally Posted by yotanut View Post
Got it all done over the weekend. Took me about 10 hours by myself. Posted my Before and After photos. The nose dive and body roll is completely gone. Rides like a dream!
2.5" Bilstein 5100 Front
1.5" Cornfed Rear Spacer w/ Bilstein 5100 Rear
JBA UCA STD
BFG KO2 275/70/17
Alignment After Install
Caster is at 3.9
Toe/Camber ~ 0.0
Looks great! Can you please post some hub to fender measurements? Thanks
2WD-2014 SR5
JBA UCAs
Front - Bilstein 6112
Rear - Dobinsons GS59-705 and C59-505 rear coils
18x9 VTX Outlaw Wheels - P275/65/18 Wildpeaks AT3W
SoFloT4Run is offline   Reply With QuoteReply With Quote
Old 06-26-2020, 11:58 AM #18
Ctready Ctready is offline
Ctready is on a distinguished road
Originally Posted by davem View Post
Have mine at 1.75" and stock rear with 275 70 17 Cooper AT3
Does this run at all? Did you have to trim?
Ctready is offline   Reply With QuoteReply With Quote
Old 06-26-2020, 11:59 AM #19
Originally Posted by 06HAOLE View Post
Just installed a set of Blistein 5100’s at 1.75” this weekend with stock rear suspension and 275/70R17 BFG KO2’s and it is perfect.
Does this rub at all? Did you need to do any trimming?
Old 06-26-2020, 01:16 PM #20
davem's Avatar
davem davem is offline
davem is on a distinguished road
davem's Avatar
NO trimming and NO rubbing at all.
'14 4Runner SR5 Premium Bilstien 1500's, Airlift bags, 275 70R 17 Cooper AT3's,Power Stop rotors & brakes, Xenon Depot 9005 Extreme Pro LED, Morimoto H11 2Stroke 2.0, AEM dry flow filter, Magnaflow exhaust, Sprint Booster
'19 Tundra Limited CM, 2.5/1 Bilsteins 5600's, Cooper AT3 275 70 18 on Method NV305's
'12 Subaru Legacy Limited
davem is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 04:35 PM #21
Chubbypanda Chubbypanda is offline
Chubbypanda will become famous soon enough
Front: 37"
Bilstien 5100 set at max 2.5 with stock coils
Rear: 38.25"
Bilstien 5100, with bilstien 1.5 rear coils (part# 36-281817), and OME correct rear lean trip packer 0.4 (10mm).
Bilstein 5100 2.5" with 275/70/17-20200627_092736-jpg  Bilstein 5100 2.5" with 275/70/17-20200627_092720-jpg  Bilstein 5100 2.5" with 275/70/17-20200627_092622_copy_2977x1634-jpg
Chubbypanda is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 05:27 PM #22
jay35 jay35 is offline
jay35 is on a distinguished road
Originally Posted by Chubbypanda View Post
Front: 37"
Rear: 38.25"
What wheels & tires on it? Any rub or cutting needed with that setup? Thanks.
jay35 is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 06:28 PM #23
SCS Ray 10 17x8, BFG 265/75/17
I had rubbing but shaved the lower front bumper and moved the fender well forward slightly. It was very easy/minor to fix.
Old 06-28-2020, 05:11 AM #24
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
Just for reference: First Pic. I started out on my TRD PRO without any mods and updated to 275-70-17’s. Pros sit 1” higher and have the fender liner/bumper cut done prior to sale. No issues or rubbing at full articulation. Second Pic, with 1.5/1” Cornfed spacers. Nice and level. Nose dive reduced noticeably. Third pic. Same suspension mod with 285/70-17’s. No rubbing so far at slight to moderate articulation. Have not tried out full articulation yet. Also, measure from the center of the hub to the top of the fender arch for the more accurate height dimension, which, eliminates the tire size variable. Measure the outside of the wheel and divide by 2, if you don’t have a proper way to gauge the center. Mine is 22.5” front and 23.25” rear.
Bilstein 5100 2.5" with 275/70/17-cb1f44dc-aae7-4b38-8072-a1278c3948db-jpg  Bilstein 5100 2.5" with 275/70/17-8b017918-d0ae-45b7-a689-4aa5d5c478f4-jpg  Bilstein 5100 2.5" with 275/70/17-fca508f9-53b2-41da-8cc4-98b40721e228-jpg
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 12:38 AM #25
rclangelan's Avatar
rclangelan rclangelan is offline
rclangelan is on a distinguished road
rclangelan's Avatar
Panther, is it a noticeable performance loss when going up to 285s from 275s? And how did you like the KO2s vs Wildpeaks? I think the KO2s look better (personal preference), but folks seem to think Wildpeaks ride smoother and have less balancing issues. What was your experience? Thanks.
Current: 2019 T4R TRD ORP - stock
Past: 2010 T4R Trail Edition - Black w/KDSS & Navi, 285/70/17 Geolander A/T-S, 2" Toytec Spacers (front), 1.5" Toytec Spacers (rear), WeatherTech Floorliners | 2005 Tacoma Sport | 2012 Tacoma Baja Edition
rclangelan is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 01:06 AM #26
I noticed a very small initial starting off the line difference at first, which, you quickly forget about in a couple days. I find the overall performance is very good and did not lose any mileage between the two. The ride quality is nicer/smoother with the SL 285’s as compared to the E load KO2’s. I would not go back from a 285. I personally slightly prefer the KO2 tread pattern myself also. The Wildpeaks balanced well, track smooth, no steering wheel shutter and held up well deflated to 22psi over rocks, sand, salt and silt on a 128 mile trip through the desert three weeks ago.
Old 01-12-2021, 09:57 AM #27
rclangelan's Avatar
rclangelan's Avatar
Thanks. I didn't realize you could get Wildpeaks in SL load. Tire Rack doesn't list them. What do they weight in at?
Old 03-20-2021, 02:00 PM #28
territory_ranger's Avatar
territory_ranger territory_ranger is offline
territory_ranger is on a distinguished road
5100s all around
Got 5100s all around, front cranked to 2.5", also replaced rear springs to add 1.5" which leveled it out. Running 285 KO2's which DID rub and DID need trimming and alignment, still might rub with steering at full crank, loaded down, in reverse. Rides nice, definitely smoother than stock, rips through sand and woods and what not, but still wishin I went for the 6" lift.
Bilstein 5100 2.5" with 275/70/17-4runner-jpg
territory_ranger is offline   Reply With QuoteReply With Quote
bilstein , cornfed , rear , running , spacer
Bilstein 5100 kit with sotck spring, 2.5" lift up fron 1.5" daystar spacer in rear jb24dolphins 5th gen T4Rs 13 02-26-2020 08:21 PM
Overextending Bilstein 5100 rears with my 3" lift, which Bilstein 5125 part? str8flexed 5th gen T4Rs 20 02-22-2019 12:45 AM
Bilstein 5100 at 2.5" and a TRD Pro jb24dolphins 5th gen T4Rs 2 04-18-2017 09:32 PM
Rear Bilstein 5100 0-2" $125 SKINUM For Sale: Suspension/Wheels/Tires 7 08-27-2015 10:22 AM
