11-16-2015, 12:05 AM
Entune Bluetooth failure
I have a 2015 Trail Edition that I bought in February.
It has the Entune with navigation system
It has worked fine since I bought it, with the occasional hiccup.
But starting yesterday, I have what looks to be a total bluetooth failure.
Nothing shows up, no bluetooth symbol.
It says Bluetooth unavailable.
When I try to pair or check setup it says looking for or waiting for bluetooth.
Nothing.
Ive restarted it a dozen times. Ive de-paired all devices from the device settings. Ive restarted all the devices.
Seems like a total failure.
Everything else seems to work with the Entune: navigation, radio, satellite radio and playing an ipd via the USB port.
Anyone have any suggestions before I go to the dealer?
2020 4Runner TRD OffRoad Premium
2017 BMW R1200GS Rallye
11-16-2015, 07:19 AM
Real Name: Corey Jane
Nothing.
Not saying you haven't tried this, but make sure that the bluetooth is actually turned on, on your smart phone.
That's all I've got.
If you go to the dealer they will likely update your software. Hopefully it helps.
11-16-2015, 07:30 AM
Banned
Banned
did you try the entune update?
11-16-2015, 09:36 AM
There is no access to any bluetooth feature in the Entune. Nothing, regardless of whether the devices are turned on or not.
Thanks
11-16-2015, 09:37 AM
Im pretty sure it is up to date.
But without Bluetooth functioning, there is no way I can update it.
11-16-2015, 11:29 AM
Thanks
I'm not talking about the Entune Application... I'm talking about the phone itself. Smart phones can have the bluetooth either turned on or off, usually in the phone settings menu. If the bluetooth feature is turned off... the vehicle will not be able to find the phone and connect to it.
Sometimes mine will not connect and I will turn the blue tooth off on the phone, turn off the truck, turn the phone bluetooth back on, wait a few seconds and turn on the truck.
11-16-2015, 11:32 AM
Yes I understand. But no bluetooth function exists at all.
Not add device, remove device, no bluetooth settings, nothing. There is no access to any Bluetooth feature, setting, list, edit at all in the Entune.
Regardless of the status of the bluetooth in the portable devices, which have all been switched on a nd off, restarted, bluetooth turned on and off.
Regardless of any device that is present or not, wherthjer their blue tooth is on or off, the Entune should at the very least allow you to view or edit settings, and add or remove a device.
Those functions are completely independent of the status of any device, present or not.
Thanks
11-16-2015, 01:59 PM
Real Name: Greg
Real Name: Greg
Nothing.
Hi mrt,
I remember some time ago I had to Cycle the blue tooth feature (turn bt off-turn bt back on) on my phone (daily) for entune to pair with my cell. If I didn't, I would get: "There are no phones set-up for this feature"! And like you said, No BT icon on the screen. This was when I got the 3.2 update a few years ago. The problem actually fixed itself; don't know why though!
Cheers
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
11-16-2015, 02:08 PM
Real Name: Greg
Real Name: Greg
Thanks
Don't you have a 'Set-up' or 'Phone' button on the HU? In my limited w/Navi, you hit > set-up> Phone> "Pair a device", "Make this system discoverable"...etc(?).
11-16-2015, 02:25 PM
-Did you purchase a new phone recently?
-Have you updated your phone recently? (If not, have you updated the phone and tried to pair again from scratch?)
-Does the vehicle display a MAC address when it is trying to connect/pair/search for a Bluetooth device; if so, what is the MAC Address legitamate? (i.e is it all Zeros like 00.00.00.00.00.00 or does it look more like this: 00:0a:95:9d:68:16)
-Also what is the Software Version? (Found under Setup -> Software Update)
In any case I would probably run it to the dealership regardless, best case scenario they just have to update then Headunit Software. Worst case it needs either a new extension box and/or headunit which will be covered under warranty. In either case they're going to start with the headunit software update first.
11-16-2015, 02:28 PM
Originally Posted by rigtec
Hi mrt,
Cheers
It doesn't pair or even show any buttons to pair or impair or even allow access to any Bluetooth setting at all
11-16-2015, 02:29 PM
No. The phone and Bluetooth setup buttons are grayed out or inactive.
No access to any Bluetooth setup or function
11-16-2015, 02:32 PM
No new phone
Phone was updated a couple weeks ago but it worked perfectly since then
The entune doesnt allow any pairing of any kind or impairing. It's unrelated to the phone or device.
The entune will not go into pairing mode nor allow any Bluetooth related function.
I'll check the sw version when I get back to the vehicle
11-16-2015, 02:53 PM
Sounds f----ed to me. Dealership.
Might want to get somebody else's phone just to make 100% sure, or someone else to look at it, to make sure you aren't doing the 'dumb thing'.
11-16-2015, 03:16 PM
Real Name: Greg
Real Name: Greg
Maybe you don't have the buttons that I'm talking about; see the 'Set-up' button on the right-hand side:
