04-03-2019, 01:25 PM
Muffler skid plate?
I'm working on installing my skid plates (full engine,trans,transfer & gas) and I am surprised that there are no skid plates available for the muffler. It seems like it hangs just as low as the gas tank and it looks fairly fragile. Do people ever have problems with damaging it?
15' Grey Trail Premium - My Build Thread
04-03-2019, 01:28 PM
Real Name: Krister
Real Name: Krister
It's soft and fragile enough it will form to the shape of the rocks that make contact with it. Yes, it is huge, best thing would be to look for an aftermarket replacement that is smaller in size or not worry about it.
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
04-03-2019, 01:31 PM
Banned
Real Name: Tobias Fünke
Banned
My guess is they don't do this for heat and fire safety. A skid could trap grass and brush a potentially set your truck on fire. I know of people getting theirs tucked up a bit higher.
04-04-2019, 01:12 AM
Real Name: Jonathan
Real Name: Jonathan
I've often wondered about it too. I've destroyed a gas tank skid, but the huge muffler at the same height 8 inches away is fine. I have no idea how this works. Does anyone make a smaller one that is not louder, or even a smaller one at all?
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
04-04-2019, 01:37 AM
I assume you destroyed the gas skid in the Golden Crack because you approached with the driver side first? Not that I have been there in person...but it occurred to me. Isn't the gas tank front edge a bit further forward and closer to the BO angle?
Mine seems to have a couple minor dents or it may be like that from the factory.
I second the concern with heat above. I would not worry about destroying it. If it happens, then I will look for options.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
04-04-2019, 10:18 AM
Like others have said you don't want to put anything there that could trap combustible material next to the smoking hot muffler.
Also worth noting that as far as damage goes a punctured muffler is pretty minor.
04-04-2019, 09:45 PM
Real Name: Jonathan
Real Name: Jonathan
I don't think I destroyed it specifically on the Golden Crack. That just beat up the driver's side of the front bumper a little. It was just the constant pounding it took that day on Poison Spider/Golden Spike/Gold Bar Rim, particularly on Golden Spike.
The gas tank skid was an RCI one. They make great stuff and I'm not trashing it at all, but the edges are not fully boxed and it essentially tore at the front driver's side corner. Got a C4 one after that as it's fully boxed all the way around and it's been fine since then.
04-04-2019, 10:12 PM
Yeah, thats why I got Shrock. After seeing your photo.
04-04-2019, 11:52 PM
I've beat my skids up and still haven't touched my muffler. I agree about the fire hazard of putting a skid on the muffler. I've seen all the sticks, leaves, and brush that gets caught in my skids. If that stuff was next to the muffler it would turn into a bonfire for sure.
Ghost towns, mines, and more: www.raydunakin.com
2016 silver Trail Edition w/KDSS; BudBuilt sliders w/full tread plate; upgraded rear hatch lift struts;
BFG KO2 265/70/17; Gobi "no-rise" Stealth rack w/ladder; MetalTech front bumper;
King coil overs, upgraded springs, ~1.5" lift; RCI skid plates.
Megaweapon's build/adventure thread
04-05-2019, 08:50 PM
Damaging a muffler doesn’t generally make the vehicle in-op or drop gasoline everywhere. Replacement muffler is ~$180 at autozone. If you were crushing them every weekend, then get a skid fabricated, otherwise don’t lose sleep over it.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
