Old 04-05-2019, 08:52 AM #1
Dianna's Avatar
Dianna Dianna is offline
Dianna is on a distinguished road
Dianna's Avatar
TPMS help please
Hi guys, I know there are a million threads, and I just spent an hour trying to find the information I need.
I have an early 2014 Trail, I am going to put new tires on new wheels, and it doesn't seem to make any sense to pay for the sensors to be removed from my old wheels and put on my new wheels (am I wrong here?)
I can't seem to find information on what part numbers I need. I have found that any will work with 315 mhz, some say they can't be installed on aluminum wheels, Denso? OEM? Please help!
2014 Trail Premium with KDSS
2006 Tacoma
2001 4Runner Sport
1977 FJ40
Dianna is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 10:38 AM #2
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
How much is the shop charging you to swap the sensors over with new "service packs" (rubber o-ring, washer, and nut basically)?
I put TRD pro wheels on mine. Had the shop take the OEM wheels and tires off, pull the valve core out to deflate, pop the bead of the tire just enough to get in there to remove sensor and just throw in a standard rubber valve stem.
Then swap the sensors with new service packs over to the TRD Pro wheels before mounting new tires. It was like $80 in labor. I bought the wheels and tires online and brought them to tire shop. Costco FTW
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 11:11 AM #3
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
42607-33022 *confirm your fitament
2014 Toyota 4Runner Parts - Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 12:22 PM #4
Dianna's Avatar
Dianna's Avatar
Thanks for the reply, but that's my dilemma, I don't think I want to pay $80 to remove the old TPMS when I can just spend a bit more and get new ones. I live where the salt the roads 8 months out of the year, lol, takes a toll on everything. I would hate even more to pay to have the old sensors removed and get destroyed in the process. The last time I had new tires put on at Costco (on a Tacoma) 2 of my sensors didn't survive.
2006 Tacoma
2001 4Runner Sport
1977 FJ40
Old 04-05-2019, 12:44 PM #5
Warpkor's Avatar
Warpkor Warpkor is offline
Warpkor is on a distinguished road
Warpkor's Avatar
TPMS sensors
I upgraded my TRD Pro rims with some SCS Ray 10s. Since my wife wanted the TRD Pro rims for her Runner, I had new sensors installed on the Ray 10s.
Part #: 4 of Toyota Genuine 42607-33021 Tire Valve Sub-Assembly for my 2016 Runner. I bought these via Amazon.
I had to buy the signal scanner and programmer for the Runner brain to accept the new sensors. Now I can swap out sets of tires and rims between the two Runners on my own without having to pay a tirechimp to do it for me.
Good luck!
Reactor breach...
2016 TRD Pro - Super White, SCS Ray10s, 2" Toytech Lift, AllPro Sliders, RCI skids (oil, trans and transfer), ARB Diff Breather (multi-plumbed)
2016 Midnight Black Limited - gonna leave this one be
Warpkor is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 02:31 PM #6
pDubs's Avatar
pDubs's Avatar
The $80 included mounting and balancing the tires on the wheels. It was like $15 to swap the sensors over with brand new service packs.
You are going to spend somewhere near $200 to get all new sensors, for no reason at all. There is no reason "sensors didn't survive" when you have new tires put on. The person dismounting or mounting the sensor must have had the sensors in the wrong spot when doing so and broke it. If they do that, it's a guaranteed free sensors replacement.
2014 SR5P
Old 04-07-2019, 08:27 AM #7
Dianna's Avatar
Dianna's Avatar
Thanks for the responses guys. I will take your advice and just reuse my old sensors. Warpkor, can you tell us which tool you purchased to do the reset?
2006 Tacoma
2001 4Runner Sport
1977 FJ40
find , information , put , wheels , wrong
Did you DISABLE TPMS? I want TPMS control module/receiver Ventil8 4th Gen T4Rs 10 03-01-2021 05:59 AM
TPMS (4th gen) - flat spare tire, no TPMS light pipspeak Engines / Suspension / Wheels / Tires / Audio / Accessories 1 04-17-2018 11:31 PM
Tpms Johncmng 5th gen T4Rs 6 04-17-2018 09:56 PM
No TPMS, TPMS light on LandCruiser General Discussions 7 02-17-2016 01:52 PM
Tpms hbrooke28 4th Gen T4Rs 9 01-27-2010 02:15 AM
