Old 05-15-2019, 09:26 AM #31
CLO T4R CLO T4R is offline
CLO T4R is on a distinguished road
I placed a Wizgear Magnet on my old Pitaka Mount that is mounted on my Buddy Dock. lol. The Pitaka Mount only really works with the Pitaka cases but my case broke so i just added the magnet i already had over it.
I'm sure this Wizgear mount would work just as well.
Originally Posted by DavidR1 View Post
What mount are you using for your phone?
CLO T4R is offline   Reply With QuoteReply With Quote
Old 05-15-2019, 09:30 AM #32
The maestro wire harness links up to the OBDii scanner and gives off the readings to the headunit, as long as its capable of showing that information.
Originally Posted by 1jzgte View Post
wow nice.. what extra hardware was required for the vehicle speed, temp etc etc??
Old 05-15-2019, 09:30 AM #33
Originally Posted by LFG.RNR View Post
I plan on going this route too, just wondering if they’ll add wireless car play to it for next year’s model. Looks really good.
I wish they did. If they do, I hope its available as a firmware update.
Old 05-15-2019, 09:32 AM #34
Originally Posted by Paragon1 View Post
Still waffling over getting a sub, definitely wanna see how your install goes. If you don't mind could you post some pics when its installed?
Sorry, I never got a chance to take photos but the install was pretty easy. Took me quite a bit longer cause i like to keep things clean and cables tucked away. The sub definitely helps fill the sound more on the low end.
Old 05-15-2019, 11:14 AM #35
QwikKotaTx's Avatar
QwikKotaTx QwikKotaTx is offline
QwikKotaTx is on a distinguished road
QwikKotaTx's Avatar
Take a look at the second pic, just uploaded it to show the difference between mounting in the upper and lower DIN slots. The Metra kit comes with brackets that let you mount it on the lower one. makes a HUGE difference, I'm currently living in central GA, we get all the heat you guys do.
That looks great, did you use the Maestro for steering wheel control? On our JVC head unit to change the up/down button from seek to preset you just tap auto1 or auto2 on the screen when the tuner is on. Probably different on yours though.
I lived in Atlanta for several years and Houston is definitely worse with slightly higher temps but a lot more humidity. Don't take that from us Texans, hah.
QwikKotaTx is offline   Reply With QuoteReply With Quote
Old 05-16-2019, 06:32 AM #36
jthoms1's Avatar
jthoms1 jthoms1 is offline
jthoms1 will become famous soon enough
jthoms1's Avatar
I have the steering wheel control adapter installed, pushing up/down scrolls thru the channels. right left scrolls thru the mode options. Center button to access your phones recent call list. I havent figured out how to do presets yet, but will update as soon as i do.
Here's a quick clip... YouTube
I’m not sure if anyone answer this yet for you, but if you’re using the maestro are our presets are press and hold.
Current - 17’ TRD ORP KDSS/Bilstein/Chaos UCA’s/TRD PRO/KO2 285s/Rigid Fogs
Former - 14’ TEP - too much to list
Former - 11’ SR5
jthoms1 is offline   Reply With QuoteReply With Quote
Old 05-16-2019, 06:39 AM #37
jthoms1's Avatar
jthoms1's Avatar
I actually had the F309 installed. I kept it for about 3 months before switching to the ILX-107. I just couldn’t get over the resolution on the F309. Plus I wanted wireless Apple CarPlay. In addition the user interface on the radio is pretty strange. As the original poster mentioned the floating unit does grow on you and my issue wasn’t the aesthetics of the way it looked installed. Just thought I’d add my two cents for anybody that might be interested.
Former - 11’ SR5
Old 05-16-2019, 10:57 AM #38
jdpiz jdpiz is offline
jdpiz is on a distinguished road
Any installed pics to share?
jdpiz is offline   Reply With QuoteReply With Quote
Old 05-17-2019, 08:18 AM #39
jthoms1's Avatar
jthoms1's Avatar
Of which radio? I assume the 107 since there are pics of the 309 in the thread.
Former - 11’ SR5
Old 05-17-2019, 10:13 AM #40
The 107
Old 05-17-2019, 07:38 PM #41
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
Any Pros or Cons to offer on the 107?
Was the screen really that bad on the 309?
Any issues with the wireless car play?
Any installed pics?
Thanks!!
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 05-17-2019, 07:38 PM #42
mrblah mrblah is offline
mrblah is a splendid one to behold mrblah is a splendid one to behold mrblah is a splendid one to behold mrblah is a splendid one to behold mrblah is a splendid one to behold mrblah is a splendid one to behold mrblah is a splendid one to behold mrblah is a splendid one to behold
the more i see this the more I want!!!!!!!!!!!
WANT IS HIIIIIGHHHHHH
2016 sr5 2x4 Mall rated edition:
Current peasant build: spacer lift 3 inches, lots of plastidip, sr5 wheels w/ 265s, lots of LED lights, and lots of overlanding stickers and sponsored stickers. faking it with the IG crowd since 2016.
Old 05-18-2019, 05:58 AM #43
jthoms1's Avatar
jthoms1's Avatar
The 107
I’ll post some up.
Former - 11’ SR5
Old 05-18-2019, 07:37 AM #44
arehman11 arehman11 is offline
arehman11 will become famous soon enough arehman11 will become famous soon enough
Any installed pics?
Thanks!!
I looked real hard at the 107, it doesn’t have an xm tuner built in and it doesn’t have any kind of nav if that matters as you’d have to use your cell data for maps always. I use xm almost exclusively as my audio source and the maps are handy on the oem system to show traffic congestion.
2017 MGM TRD Off Road Premium
arehman11 is offline   Reply With QuoteReply With Quote
Old 05-18-2019, 09:05 AM #45
jthoms1's Avatar
jthoms1's Avatar
Any installed pics?
Thanks!!
I wouldn’t say the screen was terrible but if you’re the kind of person who would appreciate the screen resolution difference between an iPhone 5s and an iPhone Xs it will bother you. It REALLY is noticeable on the backup camera. Also, the user interface is different than on the 107. Not in a good way...now that I’ve used both. With all of that said I really wanted wireless Apple CarPlay and didn’t learn it was a thing until after I had purchased and installed the 309. Wireless CarPlay works great. Here are some pics.
Alpine ILX-F309 Installed-4893f217-cc50-4cfd-b65f-49ad763e8213-jpg  Alpine ILX-F309 Installed-32b48185-8ec5-4060-92ab-f457683ea846-jpg  Alpine ILX-F309 Installed-774196bd-1f2c-488f-afe2-bdcf478dcd8e-jpg
Former - 11’ SR5
clean , installed , keen , seat , setup
PICS* Alpine S 6x9 and Dual Subs Installed swisscheeze29 Engines / Suspension / Wheels / Tires / Audio / Accessories 13 01-13-2010 12:04 AM
NE1 Have a Pic of an Alpine IVA-W200 installed?? RamThis Engines / Suspension / Wheels / Tires / Audio / Accessories 3 07-08-2007 09:26 PM
installed Pics of AVN6610 & Alpine RSE package holzapfel Engines / Suspension / Wheels / Tires / Audio / Accessories 0 03-25-2007 07:03 PM
Alpine 9857 installed with iPod cable and Sirius radio.... kickinasphalt Engines / Suspension / Wheels / Tires / Audio / Accessories 1 02-17-2007 11:01 PM
