04-27-2020, 09:46 PM
#16
So, what did the op come up with? His last update was May 2019. Thread has been dead since Dec 2019. Kind of makes one hate cliff hangers. Would be good to know if they are the "stock" or high caster arms also.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
04-28-2020, 01:38 AM
#17
Originally Posted by SnowYeti
Looks like the OD of the JBAs bushing housing is larger. Might be a better comparison to run the bolt through them next to each other.
I researched them a lot and never found this issue
I can take a pic. What do you mean by “run the bolt through them” ?
04-28-2020, 10:42 AM
#18
Here’s the response I got from JBA.
Fernando,
Jack your vehicle up without JBA UCAs, have your suspension hang at full drupe, If you have a lift kit on your vehicle now your factory UCAs will hit the factory style springs. (Fox, King & Icon coilovers have smaller diameter springs and at full drupe there is no contact.)
Out test vehicle: with the factory style spring on a Bilstein 5100, spring perch on the highest setting, the factory UCAs vs JBA UCAs, you will get 3/4" to 1" more down travel before hitting the spring with the JBA UCAs vs the Factory UCAs.
Our Goal is more down travel just with replacing the UCAs, and giving a great front end alignment with the UCAs!
The envelope for the suspension is only so big, there is a give and take to make it all work.
We moved our guest out farther to give more spring clearance, more spring clearance but less tire clearance with oversize tires on factory wheels. We recommend this wheel and tire combo for that reason, LT285/70R17 (32.7" x 11.2") tire on 17 x 9 wheel, -12mm offset (4.50" backspace)
So plan your build!
To eliminate spring contact use a racing style coilover and small diameter spring.
I hope this makes sense and answers your question.
Thanks
Marlin Gehman
K.M. Gehman Inc.
DBA: JBA Offroad
704 Forman Road
Souderton Pa 18964
Ph: 855-533-7437
Fax: 215-822-7735
04-28-2020, 11:20 AM
#19
Fernando,
So plan your build!
Thanks
Marlin Gehman
K.M. Gehman Inc.
DBA: JBA Offroad
704 Forman Road
Souderton Pa 18964
Ph: 855-533-7437
Fax: 215-822-7735
Seems like a lot of constraints to run these UCA's. I'm not sure I see the benefit of running JBA's over the other aftermarket brands.
Is this information clearly indicated on their website?
04-28-2020, 11:59 AM
#20
Yes there are constraints posted on there site.
04-28-2020, 12:02 PM
#21
I also asked another question :
Marlin,
I have the 2018 Bilstein TRD Pro suspension. I’ve added the Cornfed 2/1.5 spacers. The total lift I now have in the front is 2.75” (0.75 stock and 2” from the spacer).
Do you think my suspension will rub on the JBA std high caster UCA ?
Thanks,
Fernando
JBA response :
Yes, all stock springs will hit the UCAs at full droop of the suspension.
The only time your suspension goes to full droop is when you are articulating it offroad at slow speeds, or jump over a railroad crossing, the arms touch for a split second and back to ride height.
How many time have your arms you have now touched the spring?
JBAs UCAs will touch the springs even less!
Thanks
Marlin Gehman
K.M. Gehman Inc.
DBA: JBA Offroad
704 Forman Road
Souderton Pa 18964
Ph: 855-533-7437
Fax: 215-822-7735
04-28-2020, 03:10 PM
#22
It sucks, but it makes sense. The limiting factor before was the UCA, now you have more down travel. The control arm doesnt have the travel of the aftermarket strut. A shorter travel strut or a limiting strap would be the only option in this case. But when you want to articulate you want some travel.. I'll still end up with JBAs due to the fact that i wont wheel mine hard enough to chip or weaken the spring if it hit. should we have to worry about it? NO! Will there always be a trade off of some short.. yes..
05-07-2020, 11:55 AM
#23
I just had someone else in another thread talking about these. I think the clearance problem is that the JBA ball joint area is very close to the same size as stock (shown with the yellow lines), from these side by side photos from an earlier post. There doesn't appear to much additional clearance there from the back of the ball joint where it can contact the spring (1/4" maybe?), which is the same thing that happens with stock arms.
You can see where they gained clearance on the left curve of the arm, shown in the yellow circle.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
05-07-2020, 03:34 PM
#24
If anyone wants to sell their used JBA UCAs I’m in lmk
Mike
05-07-2020, 04:18 PM
#25
That's a good pic. The problem I see is that the bend where they gain some clearance isn't where the clearance is needed. It might useful for clearing remote reservoir hose, but that generally isn't a problem that I've come across.
I have JBA arms and have never had an issue - but I also have Fox suspension. I was not aware that the coils were enough narrower to make a difference.
The JBA ball joint is a GM OEM product design that has a lot of good features, but it also has some drawbacks - namely that the bolt flange is pretty big and hard to fit into the space that works on the Toyota setup. The GM that they come from is a torsion bar design IIRC. So clearance was never a design issue.
11-11-2020, 06:03 PM
#26
I just had someone else report to me today their JBA's are making coil spring contact. I guess they haven't added any clearance to them yet. I guess they really can't unless they change to a different ball joint.
11-11-2020, 07:01 PM
#27
Real Name: Ron
Real Name: Ron
If it bugs you and you have JBA's I would jack up the 4runner as JBA says, find out exactly where the arm/spring make contact, take a short section of rubber hose that will fit diameter of coil, slit it, fit it over coil and secure with a couple of zip ties, or goop some RTV inside the slit hose as you fit it over coil and at least you have some coil protection if that is a concern.
12-27-2020, 05:28 PM
#28
Real Name: Max
Real Name: Max
I'm surprised you got a response from Marlin because I never did. My experience with JBA wasn't a good one. I purchased the standard high caster set of UCA, NOT the OEM ones.
I had contacted them the 1st time when my ball joints started to rust. They allowed me to purchase their new and improved "Cerakote H Series Oven Cure coating" ball joints. I had to remove my old rusted one and ship them in order to receive a refund.
Shortly after that exchange I contacted Marlin about my issue with contact at full drop. I emailed the specs and photos of my setup and never got a response after 3 emails. I never noticed an issue until i started to rotate my tires and witnessed that contact with the spring. After my issues and no response, I decided to let it go. I have run the UCA for about 2 years and thought maybe that is why i was getting the 3rd degree.
My plan is to remove the JBA UCA and put them on my 4th gen runner that i care less about spring contact and purchase some ICONs for the 5th gen.
I would not have purchased these UCA if I had seeN a response from Marlin stating contact at full drop like daytonaviolet email.
02-13-2021, 09:53 PM
#29
Real Name: Matt
Real Name: Matt
Curious as to which groove you have the circlip set. I have a similar set-up in my 4th gen. My 5100’s were in the 3’rd groove. The only time I ever saw contact with the spring at full droop was after my passenger side 5100 came apart. The shaft separated from the internal valve. When I first lifted my T4R in 2015 I had stock UCA’s and 5100’s on the bottom groove with Toytec coils and the uca rubbed the coil. I replaced the uca’s with the JBA High caster units a year or so ago. I was able to correct my alignment and run a larger tire without rubbing.
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
04-23-2021, 12:42 PM
#30
I found this 5th gen thread very helpful and it addresses the same issue I have currently. I wanted to post and add my info so others may be able to compare later.
I have a 2008 4th gen 4Runner with the following:
JBA UCAs w/ Moog ball joints
1.5” wheel spacers
1.25” strut spacer lift
Splindle gussets
Cam tab gussets
33” BFG ATs
Body mount chop
Tacoma coils that have more lift than stock 4th gen coils.
Just got it aligned and the JBA UCA ball joint contacts coil at full droop when I jack the tire off the ground.
I am waiting on King Suspension and hope their coil solves this issue.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
