Old 04-08-2019, 08:53 AM #1
OrionA1414's Avatar
OrionA1414 OrionA1414 is offline
OrionA1414 is on a distinguished road
OrionA1414's Avatar
Toytec Radiator Support Kit Issues
Good morning Ladies and Gents, has anybody had any problems with the radiator support kit? It is supposed to be part of the Ultimate/Boss Lift Kit for non-KDSS 4runners. Long story short, I installed mine yesterday and while the sway bar spacers do help alleviate contact of the sway bar from the coil-overs, they push the sway bar into the radiator support brackets, which is where this kit comes into play. The only issue is that the spacers provided are not large enough to push the driver side bracket out of contact with sway bar. I had to add several washers in addition to the spacer in order to achieve maybe 1/4" of clearance. Also, the tabs on the factory skid are no longer able to be used. I had to hammer mine out of the way in order to bolt the skid plate back on. This was not mentioned anywhere in the instructions. Anyway, just taking a poll / throwing this info out there for anybody purchasing this Toytec lift.
For reference: https://www.toyteclifts.com/pub/medi...e/r/s/rsdk.pdf
(I searched before posting this, didn't find any dedicated threads.)
2019 TRD Offroad Premium MBM. Toytec Boss Complete Lift w/ 285/70/17 Falken Wildpeak AT3Ws.
Rigid D2 floods and hyper spots: KC C3 fogs: Spidertrax 1.25 spacers. More to come...
OrionA1414 is offline   Reply With QuoteReply With Quote
Old 04-08-2019, 09:20 AM #2
tstevens tstevens is offline
tstevens is on a distinguished road
Check and make sure your sway bar drop brackets aren't on backwards. If you have them on backwards it will push the swaybar forward towards the radiator support.
I just did the Toytec lift with sway bar drop and radiator support and do not have any contact with the swaybar. Same here with the skid plate tabs, had to smash them down with a hammer.
tstevens is offline   Reply With QuoteReply With Quote
Old 04-08-2019, 09:21 AM #3
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
Its actually not a radiator support but a structural element of the front suspension. Never had luck with spacers to clear the swaybar and ended up buying the full on ARB replacement brace. Arb sway bar rub fix!!! Bp-51 fit kit
That cured any clearance issues.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 04-08-2019, 01:22 PM #4
OrionA1414's Avatar
OrionA1414's Avatar
I'll be looking into these for sure. The spacers are not on backwards, that was the first thing I thought as well.
Old 01-19-2020, 01:55 AM #5
sjbill17 sjbill17 is offline
sjbill17 is on a distinguished road
Ok fellas, I've been combing the threads in this forum for this exact reason. Now, keep in mind that at this time I do not actually have my front suspension components installed.
With the above being said here is my situation, or question regarding how to avoid a situation. However ya wanna look at it.
I own a 2015 Trail Premium - NON KDSS. Just received my ICON 2.5 Extended Travel Front Coilovers w/ RR & CDCV. Not installed yet. Waiting on rear components. I read a lot about sway bar contact with the radiator support brackets. Not sure if it is worse with the ICON setup or not, or worse with the remote resi setup or not, or is an across the board issue with all the different systems ie. King, ICON, Toytec. Anyway, I've purchased ICON so that's what I'm looking at. Looking at several install images and videos, I've noticed that the resi mounting bracket mounts between the sway bar relocation spacer and the frame. Now with that being the case, can we assume that the additional thickness of the bracket along with the sway bar relocation spacer aggravates the contact issue with the sway bar and radiator support bracket? And if so, what if the lower portion of the resi bracket were cut off and and instead mounted to the side of the frame with 4 self tapping screws ( or something to that effect )???
Any thoughts??? Ideas??? Or just tell me I'm effing crazy and it would not make any difference. Just an idea.
sjbill17 is offline   Reply With QuoteReply With Quote
bar , kit , radiator , support , sway
Need advice: Rotted radiator frame support DaveK22 4th Gen T4Rs 7 07-27-2021 10:41 AM
Replacing Radiator support CVELD77 3rd gen T4Rs 3 10-09-2015 05:35 PM
1st gen radiator support Justin_W Classic T4Rs 1 08-11-2014 07:43 AM
radiator core support mounts Kenjan 3rd gen T4Rs 2 06-18-2012 06:00 PM
1995 4runner core support/radiator support bolted vs. welded into frame jlfindley74 Classic T4Rs 3 12-28-2010 05:59 PM
