Old 04-10-2019, 03:49 AM #1
Jan777 Jan777 is offline
Jan777 is on a distinguished road
need some help: fault code P0174
When I start the engine the yellow lights go on. The search for the fault codes gives me this:
P0174 - Powertrain
System too Lean (Bank 2)
I can deleted the fault codes and switch off the yellow lights. But when I start the engine the next time I get the same again. I do not see any difference in power, fuel consumption, sound or behavior of the engine.
What's the problem? Anyone got experience with fixing this?
thanks
Jan
need some help: fault code P0174-fault-code-jpg
Jan777 is offline   Reply With QuoteReply With Quote
Old 04-10-2019, 09:27 AM #2
bigmace bigmace is offline
bigmace is on a distinguished road
Check / clean your MAF. Make sure there are no vacuum leaks. Maybe a bad fuel injector?
bigmace is offline   Reply With QuoteReply With Quote
Old 04-11-2019, 02:09 PM #3
rwrobs777's Avatar
rwrobs777 rwrobs777 is offline
Real Name: Rob
rwrobs777 is on a distinguished road
rwrobs777's Avatar
Real Name: Rob
If this was just a Bank 2 specific DTC it would NOT be a vacuum leak or MAF sensor...a vacuum leak for instance after the MAF sensor would affect the whole engine...BOTH banks !!...you MAY also have a P0171 but that DTC might have not set yet because the fuel trims on Bank 1 haven't reached the limit to set that code...if you have a scan tool I can have you look at some numbers and possibly diagnose it for you...it can be a "no spark" or no "injector pulse" or a bad injector but that usually sets a misfire code P03XX-030XX. I'm usually on the Corvette forum but these 4Runners never have driveabilty issues...LOL !!...I spent this past Saturday helping a Forum member who had "rich" codes instead of the lean ones you are experiencing...found out 4 injectors were bad !!
rwrobs777 is offline   Reply With QuoteReply With Quote
Old 04-25-2019, 04:01 PM #4
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
i have the same problem, my LTFT bank 2 is 37%, and LTFT bank 1 is 17%, i have only p0174, no pending p0171, though sometimes if i accelerate aggresively i sometimes get p0430 - catalytic converter code, cleaned maf and TB, no change. thinking it may be the fuel pump, but want to do a pressure test first, cannot seem to locate the service port
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 04-26-2019, 05:55 PM #5
rwrobs777's Avatar
Real Name: Rob
rwrobs777's Avatar
Real Name: Rob
I don't know what percentage the LTFT will throw a DTC but Bank 1 is high and bank 2 is WAY high...anything over 10% is no good...I'm assuming you have a scan tool....what does the stft's do when you run the RPM at 3000 RPM ??...if short terms go negative...towards zero you most likely have a vacuum leak somewhere...it takes the long terms a little longer to come down...if long terms and short terms increase you have a fueling issue (fuel pump) OR a MAF sensor issue...I have a 2016 and unfortunately I don't think I have a Schrader valve on my fuel rail like on my 2001 Corvette !!...does your scan tool show "freeze frame" info...it may also be in mode 6...at least you can see if the 0171 set at idle or a higher RPM !!
Old 05-09-2019, 03:41 AM #6
below is my freeze frame data.
Freeze frame report generated by Torque for Android
Vehicle VIN: JTEBUXXXXXXXXXXXXXX
Vehicle Manufacturer: Toyota
Vehicle Calibration ID: 33535000
Freeze frame information:
Fuel Trim Bank 1 Short Term = -1.562 %
Fuel Trim Bank 1 Long Term = 14.062 %
Fuel Trim Bank 2 Short Term = 0.781 %
Fuel Trim Bank 2 Long Term = 37.5 %
Engine RPM = 875 rpm
Speed (OBD) = 7.456 mph
Timing Advance = 15 °
Intake Air Temperature = 123.8 °F
Mass Air Flow Rate = 6.62 g/s
Throttle Position(Manifold) = 17.255 %
Run time since engine start = 133 s
O2 Sensor1 Equivalence Ratio = 1.004
O2 Sensor5 Equivalence Ratio = 0.995
Distance travelled since codes cleared = 1.243 miles
Barometric pressure (from vehicle) = 14.504 psi
Catalyst Temperature (Bank 1,Sensor 1) = 839.3 °F
Catalyst Temperature (Bank 2,Sensor 1) = 839.3 °F
Catalyst Temperature (Bank 1,Sensor 2) = 247.64 °F
Catalyst Temperature (Bank 2,Sensor 2) = 247.64 °F
Voltage (Control Module) = 13.164 V
Engine Load(Absolute) = 18.824 %
Commanded Equivalence Ratio(lambda) = 1.005
Relative Throttle Position = 0 %
Absolute Throttle Position B = 49.02 %
Accelerator PedalPosition D = 16.078 %
Accelerator PedalPosition E = 32.157 %
End of report.
Old 06-27-2019, 03:14 AM #7
@3000rpm, the LTFT2 goes down a couple of digits to about 32%, nothing serious happenes to the other parameters, noticed a few times after disconnecting the battery, i get a p0304 misfire error, i cclear it with the scan toool, and it doesnt come back.
what do you think?
Old 06-27-2019, 07:52 AM #8
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Maybe some tips/suggestions in these 4th Gen threads:
P0174
P0174, Rough Idle & Strong Exhaust Smell
Help needed- Fuel pressure test persistent p0174
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 06-28-2019, 08:57 AM #9
Deep_palancar's Avatar
Deep_palancar Deep_palancar is offline
Deep_palancar will become famous soon enough
what do you think?
35% Longtrim is the threshold for code set. One sided lean with an occasional misfire calls for injector cleaning. Real remove and clean or renewed swap-out. Miracle in bottle might help but it will take time.
IAT of 123.8° ?is that right?
FWIW there is no fuel pressure test port. You have to Y-fitting in somewhere. As others have said, pressure problems are not going show one-sided DTC and tend to show up power demand related.
Deep_palancar is offline   Reply With QuoteReply With Quote
Old 08-23-2019, 11:15 AM #10
been running mobil injector cleaner for a while now, no change.
oem injectors are quite pricey, and am unsure if remanned injectors are worth buying....and now it throws p0430 code on highway drives
real PITA!
Old 08-23-2019, 11:28 AM #11
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
What year? How many miles? Just for data's sake.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 08-23-2019, 03:18 PM #12
05, V6, 4WD. About 170k miles
Old 08-23-2019, 09:10 PM #13
4R4Trout's Avatar
4R4Trout 4R4Trout is offline
4R4Trout will become famous soon enough
4R4Trout's Avatar
I have seen similar codes on a 2006 GMC Yukon after installing a K&N drop in oiled filter. Fuel mileage tanked in addition to the code. I re-installed the stock air filter, cleaned the MAS and never got the code again. Fuel mileage came up too. Never again K&N.
2012 TE~Shoreline Blue~KDSS~Nav
ARB Diff Breather, Dobinson 302/700, 327/701, Yokohama Geolandar MT G003 255/75R17, ARB CKMA12 onboard air, IndeFlate, Arclight LED, Victory 4x4 Strike rear bumper, Kenwood TM D710GA Ham Radio, Engel MT-45, Method 701 (Black) UpTop Overland Bravo, 38” Extreme LED lightbar, Dobinson UCA
4R4Trout is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 12:17 PM #14
I have stock air filter, never messed with it, for some years prior to this, LTFT1 has been 8%, LTFT 2 18%, no cel, the cel just came up a couple of months ago, fixing to remove the injectors and service, trawled youtube and the forum, no detailed video or picture of the process.
have you come across any?
Old 11-22-2019, 08:48 AM #15
swapped all the injectors with ebay remanns, CEL gone, fuel trims ok now. am super stoked!!!
codes , engine , fault , lights , yellow
Fault code p2714 2005 V8 SR5 Jackkill1 4th Gen T4Rs 14 06-12-2023 10:00 PM
Ignitor circuit fault bank 1 code p1300 Kevin91 3rd gen T4Rs 3 06-22-2019 06:55 PM
P0174 AND P0430 code on my 2004 V6 4runner PTPT2002 4th Gen T4Rs 1 05-08-2019 12:46 PM
Code 71 EGR fault. Ahlem Classic T4Rs 3 02-10-2015 09:25 AM
Fault Code rjschmitty Classic T4Rs 9 03-09-2011 05:37 PM
