Old 08-27-2019, 09:57 AM #16
scarpozzi scarpozzi is offline
scarpozzi is on a distinguished road
Originally Posted by 97BlackAckCL View Post
But Noah wasn't in Bill and Ted
I was talking about the big guy in the sky.
scarpozzi is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 01:59 PM #17
dangitzin dangitzin is offline
dangitzin is on a distinguished road
Originally Posted by Narat_524 View Post
I'm replacing all the speakers.
Dash: Infinity REF-3022CFX 3.5"
Front Door: Infinity REF-9620CX 6X9" with 1" component tweeter
Rear Door: Infinity 50.11CS 5.25" with 1" component tweeter
Rear Hatch: Hertz HCX165 6.5" coaxial
Sub: Kenwood KSC-SW11 under passenger seat
These will be powered off two Kicker KEY 180.4 amps on a Tacotunes plate under the driver seat.
It's front and rear door placement of the tweeters that's freaking me out!
Narat
TBH, I don't think you really need the second pair of tweeters at the front as the image from aftermarket tweets in the dash already sounds good especially when tuned properly and the fact that you're putting 3.5" tweets there. But if you must, you can place the other pair on the sail panel. As for the rear doors, you'd have to cut a hole on the door panels, probably close to the handle.
dangitzin is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 03:10 PM #18
Narat_524 Narat_524 is offline
Narat_524 will become famous soon enough
Yeah, I debated the extra tweeter up front, but I do appreciate being able to hear every tippy-tap of a drum stick on the high hat, so I kept at it.
The sail panel on the 5th gen is no good for tweeter placement. That was the natural go-to spot, but they changed the dash and door interface, and the sail panel is basically right up against the side of the dash board when closed. I've found a spot about 4" above and directly inline with the 6X9 speaker cut-out where the front tweeter will fit.
The rear door has a spot about 2" above and slightly behind the speaker cut-out where it will fit, depth-wise, but it's basically pointed at the passengers' leg. I will rarely, if ever, have passengers, so it works for me.
If I had to do it all over again, I would just put coaxials in and skip the drilling holes part. Major props to the Japanese engineers; they filled every friggin' useful millimeter behind those panels with something!
Narat
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
Narat_524 is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 12:54 AM #19
Didn't realize the placement of the sail panel and its small size until now. No way to fit any tweeters there.
You are one brave soul to be drilling your door panels... Pillar-pods and plastic trims wouldn't hesitate, but damn. Good stuff!
Old 09-12-2019, 02:57 PM #20
flyfishin flyfishin is offline
Real Name: Mark
flyfishin is on a distinguished road
Real Name: Mark
Focal Speakers
I went a similar route as Louisiana Overlander. Focal IS 690 Toy front, Focal IC 650 Toy passenger doors. I saved some and went with a Hertz coax in the rear hatch. Also put dynamat in the doors. This made a big difference but I knew it needed an amp.
Added JL audio XD700/5, audio control LC 7i, and JL audio 10" ported micro sub. It took some tweaking but I am happy. Getting the gains and the crossovers right on the amp has a big impact on the sound. It's crystal clear and will thump well beyond what I need. Many could probably go without the sub and use the XD500/4 which is a good bit cheaper but I hated to go down that road and then think I needed a sub and an additional amp. The xd700/5 fits under the driver or passenger seat easily and drives everything. You would never know its even there without looking under the seat. IMO it's a technological marvel.
2019 Trd OR Premium Silver, KDSS, Focal/JL Audio upgrade, all LED lighting interior, xtreme LED Pro low, fog, and high beams, RSG Rock sliders, Pro grille and valance, Bilstein 5100s at .85 w/10mm ome spacer.
1999 Limited Imperial Jade Mica. Still in the family. 275 k.
flyfishin is offline   Reply With QuoteReply With Quote
door , gen , location , panel , pics
Crossover mounting for component speakers? fourfive 3rd gen T4Rs 19 02-24-2021 12:28 AM
Speakers: 2 way vs Component - What do you recommend? tekstrand 3rd gen T4Rs 32 07-26-2015 02:29 AM
6x9 Component speakers set BNIB$100 Victor_inox For Sale: T4R Items 4 05-21-2012 03:43 PM
Alpine Component Speakers 4x4Runner09 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 07-16-2007 08:09 AM
What Component Speakers Do You Have In Your T4R? undying_reverie Engines / Suspension / Wheels / Tires / Audio / Accessories 14 05-30-2006 12:59 AM
