04-10-2019, 03:56 PM
SCS Ray10 17x9 and 285s-Whats required?
04-10-2019, 11:56 PM
Looks great. I love those wheels, I may be ordering them soon. Where did you order from? How much did SSO charge for the BMC work?
04-11-2019, 07:16 AM
I ordered directly from scs(stealth custom series) website.
BMC- depends on their labor time involved.
04-11-2019, 08:47 AM
I'm local to the area as well and SSO has done work on my rig in the past, great shop. How much room do you have between your tire and UCA? Considering same rim with slightly wider tire, if I can stuff it in there. 305/65/17 cooper
Also could you ballpark what you paid for BMC?
04-11-2019, 10:22 AM
I have the F5 in 17x9. I was really hoping I wouldn’t need to do a bmc when I switch over to 285s but I guess I will have to plan ahead! Thanks for posting this up!
04-11-2019, 10:24 AM
Most shops in Southern California that I have spoken to, do the BMC in the low 200 range. Maybe a little cheaper if you supply the plates.
04-11-2019, 11:04 AM
Shop in Ft. Worth quoted me $150. Fortunately with the -10 SCS Ray10 and SPC UCA I didn't need one.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
04-11-2019, 05:50 PM
3.5” at sidewall. 4” to tread. I ended up with over an inch clearance at full lock between tire and body mount. And thats at only 2deg caster. Good luck!
05-17-2019, 10:47 PM
Finally got these wheels mounted today with 305/65/17 cooper STT Pros, they rub ever so slightly at full lock on the lower fender caps, behind where the mud flaps were. Gonna trim some of that plastic and hopefully clear the tires. I can see how the 285's would clear perfectly. Looks and rides great!
05-18-2019, 04:46 PM
I have 17x9 Mamba's and a BMC but retained my flaps setting the SPC's at 4 degrees ....
05-18-2019, 10:49 PM
What size tires?
05-19-2019, 09:30 AM
Originally Posted by Louisiana Overland
Was this pic taken when the plate was test fitted? Looks like top was just pot welded.
2010 Trail - First mod-Right fender dent, Dobinson 3" F+R lift, Diff drop, American Racing Wheels 17x8-0 offset, Generic 1.25 Wheel Spacers, Nitto Ridge Grapplers 285/70/17, Fender liner mod, BMC. To Be Continue...
05-19-2019, 07:40 PM
I dont remember but they welded all edges of the fill plate/gussett and dressed the welds with a grinder.
05-21-2019, 03:28 AM
OP - was there another motivation factor to go with the 9" -38mm offset vs the 8.5" -10mm offset?
Curious to know what (if any) is the advantage to running a 9" wide rim vs 8.5".
Also, what (if any) is the advantage to running a track width 2" wider.
I'm asking as I'm on ray10's myself - but of the 8.5" wide flavor (meaning -10mm offset). I have been contemplating ordering the 9" ones as I do like the much more aggressive look. Can't say I'm thrilled with doing a BMC but if the benefits are significant enough, might as well LOL.
05-21-2019, 08:42 AM
Well... I guess MAYBE its arguable that the wider track offers more stability??? But... i wanted a wider rim for the 285s than the 7.5” factory wheel. The 8.5 would meet that requirment. I looked at so many photos on IG trying to decide. I was afraid to make the bmc plunge also. But in the end every single photo of an scs 8.5” wheel that i liked was also using a wheel spacer. I like the look, and THAT is what sold me. Its not for everyone but I must say...in my opinion...it is a baaaadassss combo.
