Old 10-25-2019, 07:21 PM #61
tristero's Avatar
tristero tristero is offline
Real Name: Justin
tristero will become famous soon enough tristero will become famous soon enough
tristero's Avatar
Real Name: Justin
Originally Posted by Jeffy View Post
Just use normal LED bulbs (nothing fancy, no canbus stuff) and put a resistor in the rear turn signals.
If your rear bulbs are also LED, you'll need to either put two resistors per side, or one resistor with twice the resistance. But this way the resistors aren't constantly on with the front DRL bulb.
Thanks @Jeffy
I'll try this out and follow up
Originally Posted by ElectroBoy View Post
As @Jeffy recommended, try lower power LEDs that can run constantly. If you need to add resistors to prevent hyperflash, use high wattage ones and mount them on a metal surface. They will get quite warm if powered On all the time. Or go back to a standard 7443 incandescent bulb.
Yeah but the 7443 incandescent blew both sides after 2 months, replaced and got another 1 month from the bulbs and sockets. I'm on socket #3 hahaha.
I appreciate your help here, really. I'll give his method of no CANBUS and add a rear resistor.
Returning the lasfit which sucks since they are in fact very bright.
2010 4Runner SR5 Magnetic Gray: Radflo / Icon + Metaltech / Total Chaos / Dirt King / SCS Stealth 6 / BAMF Sliders + Pelfreybilt Bumper / PRINSU / Indel B / 2014+ IS 350 Retrofit
2012 GX460 Premium Black Onyx: Stock af
tristero is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 07:41 PM #62
4Regrets 4Regrets is offline
Real Name: Ben
4Regrets will become famous soon enough
Real Name: Ben
Just thought I would follow up on these guys. I installed the LED reverse lights and the driver's side rear blinker. The blinker bulbs are a huge pain to install. I've been working on the passenger side one for hours, and have yet to get it installed, despite buying a variety of tools along the way. I've dropped the bulb into the taillight housing three times now, where it currently sits. At this point, when I get it out of there again, I think I'll put the stock ones back and return the Lasfit LED's. If you're going to use them, keep in mind they're more than twice the length of the stock blinker bulb, which is what leads to the ordeal described above.
What a nightmare of contortionist antics for nothing. They're really bright, but they sure don't seem worth hours of stress and frustration.
The reverse lights were a piece of cake, but the blinkers are damn near a form of torture to try to install.
2019 Midnight Black Limited with Beige Interior
275/70R17 Nokian Hakkapeliitta LT3 on FN FX Pro -- Winter
275/70r17 BFG KO2 on stock Trail wheels for summer/shoulder seasons
H11 to H9 low beam conversion
4Regrets is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 08:43 PM #63
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
You need to pull on the wiring. There’s slack in the line and you’ll need it to install the lasfit. Took me 10 minutes for both sides.
Just give it a slow pull. Not like starting a lawn mower. But yes the lasfit bulbs are a lot bigger
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 08:51 PM #64
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
can you take a picture of this
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 09:21 PM #65
tristero's Avatar
Real Name: Justin
tristero's Avatar
Real Name: Justin
Are you trying to install these while still on the vehicle? There are 2 bolts holding on each side, I think 8 or 10mm deep socket, just pop the light housing off and install the bulbs. Then bolt 'er back up. Should take 10 min tops for both sides. If you didn't pop em off wear some gloves, since there's some sharp metal in there.
Old 10-31-2019, 09:58 PM #66
GX4SEVEND's Avatar
GX4SEVEND's Avatar
I did mine without removing anything. It’s a lot easier but yeah you can detach them if you want
‘14 SR5 in white
Full RCI skids
Old 10-31-2019, 10:02 PM #67
BigCountryT4R's Avatar
BigCountryT4R BigCountryT4R is offline
BigCountryT4R will become famous soon enough
Lol. Took me 5 minutes to install both my rear lasfit bulbs. Without removing the lights.
Sent from my SM-N975U using Tapatalk
2019 4Runner Limited in Magnetic Gray Metallic, w/Redwood Interior, and 3rd row. Mods: Lastfit 7440/7443 Led Blinkers | JDM ASTAR LEDs throughout the interior and backup/license plate bulbs | OEM Tundra LED Fog Lights | Morimoto Elite HID 5500k 35w | Xenon Depot Led Pro 9005 w/LED Driver for DRL / XPLORE OFFROAD USA Flag rear windows | Adams Polishes UV Ceramic Paint coating
BigCountryT4R is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 01:30 AM #68
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Go look at post #32. I was having the same problem. Not enough slack in the wire harness. You gotta remove the whole tail light assembly.
Old 11-01-2019, 02:07 AM #69
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
ive installed the rear blinkers twice already and I have done it both ways. If you have big paws, its easier to remove the taillights....its really easy.
Old 11-01-2019, 08:26 PM #70
tristero's Avatar
Real Name: Justin
tristero's Avatar
Real Name: Justin
No way you're installing longer bulbs on mine without pulling the lights, I'm pretty jealous that anyone has enough slack to do that.
So I did what @Jeffy said. Installed rear resistors and rear LED. Here's the outcome:
1. LED turn signals work without hyperflash, but I have to use the Lasfit bulbs in the front
2. the nothing fancy, non-CANBUS bulbs hyperflash when put into the front turns
2. DRL no longer works at all with any bulbs
In the rear, I tapped the yellow on LH and light blue on RH for +, as these are the only wires that read on the meter.
Old 11-01-2019, 08:49 PM #71
You do not need to remove the tail assembly. The wires can stretch just enough to get it in there.
Old 11-03-2019, 10:10 AM #72
Whoknows's Avatar
Whoknows Whoknows is offline
Whoknows will become famous soon enough
Whoknows's Avatar
Originally Posted by GX4SEVEND View Post
I’m running the lasfit as well with zero issues. Only the turn signal bulbs not the DRL. No hyper flash and I run them all the time because I have them hookup up to the “raptor lights” so they’re always on and then ridiculously bright when you hit the turn signal.
Using the DDM Saber led lights for the DRL. Super bright as well. No flicker until you take a video of it or try to snap a pic then you can see them pulsing. The naked eye can’t see it.
how do u like ddm sabers? Do they work as true DRL - not on as high beams in drl mode? did u need the additional modules? can u link to specific bulb?
19 TRD ORP w/KDSS
Super White
Whoknows is offline   Reply With QuoteReply With Quote
Old 11-03-2019, 10:47 AM #73
GX4SEVEND's Avatar
GX4SEVEND's Avatar
I like them a lot. They’re very bright even in DRL mode. I literally just plugged them in and walked away. They don’t “pulse” like some other bulbs do but when you take a video of it, like my iPhone takes 4K at 60 frames per second, then you can see them pulse.
DDM Tuning: HID and LED Lighting
‘14 SR5 in white
Full RCI skids
Old 11-03-2019, 07:37 PM #74
Whoknows's Avatar
Whoknows's Avatar
Thanks. Do you find the DRL mode too bright? Just wondering if they truly dim enough in DRL mode. Most on the market are in full high beam mode in DRL, which is no good if u like using DRLs.
19 TRD ORP w/KDSS
Super White
Old 11-03-2019, 08:24 PM #75
GX4SEVEND's Avatar
GX4SEVEND's Avatar
They’re not fully on like they are in high beam mode but they’re a lot brighter than stock. I’ve only had one person flash me in a lowered civic so I gave him the light bar too. I don’t think they’re too bright. Plus I liked the two year warranty
‘14 SR5 in white
Full RCI skids
built , led , load , resistors , turn
FS: 4th gen OEM TURN SIGNALS w/ DRL lshishido03 For Sale: Non-T4R Items 0 07-23-2013 04:52 PM
Turn signals skoppit General Discussions 1 12-09-2010 11:21 PM
Turn signals OUT!?? HELP danny4runner 3rd gen T4Rs 6 09-04-2009 10:47 AM
turn signals honda4trx Classic T4Rs 4 02-09-2006 07:56 PM
Turn Signals a3fnqpjw Engines / Suspension / Wheels / Tires / Audio / Accessories 2 10-04-2005 12:18 PM
