04-11-2019, 12:10 PM
Real Name: Chris
Real Name: Chris
LED turn signals
Has anyone had any success finding good quality LED turn signals with built in load resistors?
There are a few that I've come across that look like they work fine, but are 1000-2000 lumens which is insane for a turn signal. I am not trying to blind people.
Diode Dynamics has a few different LEDs ranging from ~250-500lm which make more sense, but they do not offer LED bulbs with built in load resistors. I'd rather not use splicers on my factory wiring.
2018 TRD ORP w/ KDSS: King extended travel coilovers & shocks w/ adjusters - Icon tubular Delta Joint UCAs - Icon 2" rear springs - 17x9 -38 offset Stealth Custom Series stealth blue F5 wheels - 305/70R17 Nitto Ridge Grappler tires - C4 Fab Lo-Pro bumper - Baja Designs 30" S8 - Baja Designs Squadron Sport fogs - TRD Pro grille and rear bumper valance - Full custom audio system w/ CarPlay - URD MAF calibrator - Sprint Booster - RCI skid plate - Shrockworks angled sliders - Front Runner roof rack and Maxtrax mount - Xenon Depot Xtreme HID Philips 4300K low beams - ARB on-board air compressor w/ Rago Fab mount - Wifey 4-corner air system - Warn VR10-S winch w/ Factor 55 fairlead and Ultrahook - Odyssey 34R-PC1500T battery - Voltage booster - T4RPAM with Yaesu FTM-400XDR radio and Android tablet running Backcountry Navigator and APRSdroid
04-11-2019, 12:43 PM
On my Tacoma I used VLEDs V6 Triton turn signals. Output is 500lm per bulb. Their wiring harness accepts their plug in resistor but it is extra. I was very happy with their products but haven't replaced anything on the Runner yet.
V6 TRITON AMBER 7443 7440 - AMBER - Standard - 7443 - Turn Signals Front - Shop Application
04-11-2019, 12:45 PM
$160.00/PAIR
Holy Jesus' Resurrection next week. For turn signals?! Ya'll have too much money.
2016 Trail + KDSS | Kings 2.5 w. Adj + Ext Travel Front & Rear - JBA High Caster UCA - Icon 3" "Overland" Springs - Proline 4x4 Rear Elite Dual Swingout Bumper - Demello Offroad X-Wing Sliders - SCS Ray 10 - Falken Wildpeak MT01 285/70/17 - Dirty Pants
04-11-2019, 12:57 PM
Originally Posted by ayeyothisiskyle
$160.00/PAIR
10% off right now. Also worth the cost when the face of the person behind the entire car in front of you lights up in amber so they know where you are going. It's definitely needed here in Derpifornia.
04-11-2019, 01:00 PM
04-11-2019, 01:04 PM
True, but I've always though the rears were fairly bright. However, I do like switchbacks for the fronts.
04-11-2019, 02:25 PM
Real Name: Chris
Real Name: Chris
I used these form my rear
7440 7441 CAN-BUS Anti Hyper Flash LED Turn Signal Lights, Amber Yellow - Lasfit Auto Lighting
And these for my fronts
7443 7444 CANBUS Error Free Dual Color Switchback LED Turn Signal Light - Lasfit Auto Lighting
They are super bright, but they work with no hyper flash, no bulb out warnings and no need to tap any wires with resistors. They can be found cheaper on Amazon and Ebay
I highly recommend them
04-11-2019, 05:43 PM
i run lasfit also...mudaafkers are bright. Highly recommended.
04-11-2019, 11:00 PM
Will any of these non flicker led options being given work for the turn signal/DRLs on the 2010-2013 models without fear of overheating if in DRL mode?
04-12-2019, 01:11 PM
Bump for not wanting to melt my shiz by buying one of these options.
04-12-2019, 02:01 PM
My VLEDs didn't melt anything. Actually, the OEM bulbs melted the OEM housing in my Tacoma. It because a TSB so they replaced the entire headlight.
04-12-2019, 02:16 PM
Originally Posted by 97BlackAckCL
^THIS
LASFIT is the best of all the light brands I toyed with, I took 97BlackAckCL recommendation and I'm very pleased with them. On the preface 2012 the front amber DRL/turning lights really are bright but when I signal they are very noticeable. It give is that JDM appeal.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
04-12-2019, 11:58 PM
Did you get the Standard socket or CK socket for the front turn signal?
04-13-2019, 04:13 AM
$160.00/PAIR
LOL!
On our first-gens we just modify the blinker module or replace them with plug and play after-market ones that work with LED's
Really? After 35 years, 4Runners still don't have a blinker module that accommodates LED bulbs?
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
