12-10-2019, 03:29 AM
#91
Originally Posted by tomb_rnr
i run those in my rear...
they are insanely bright....i like them alot
12-10-2019, 06:58 AM
#92
I did go with the LasFits out back and, as mentioned, are incredibly bright. I had originally gone with another GTR bulb that needed a resistor for the rears, but ultimately went with the LasFits as I didn’t like tapping into the wires.
12-10-2019, 10:34 AM
#93
Real Name: Chris
Real Name: Chris
Isn't the switchbacks white and then turn amber when blinkers are on?
I'm looking LEDs that stay amber and blink amber.
Lasfit 7443 all amber is what I'm running, they work great
Amazon.com: LASFIT 7443 7444 T20 LED Turn Signal Light Blinker Bulbs with CANBUS Anti Hyper Flash, No Load Resistor Need, 2019 Upgraded Intelligent Temperature Control Version- Amber Yellow (Pack of 2): Automotive
12-10-2019, 03:45 PM
#94
Originally Posted by 97BlackAckCL
But as mentioned the LasFits won't turn on when headlights are on.
2019 4Runner TRD Off-Road Premium
12-10-2019, 04:32 PM
#95
Real Name: Chris
Real Name: Chris
In the front corners? Yes they will. The 7443's are dual amber and will work as corner marker lights as well as turn signals.
12-10-2019, 07:41 PM
#96
ORLY? Thanks for confirming!
12-13-2019, 07:01 PM
#97
HELP! Anyone from this great thread: I have only just started trying to replace my front turn bulbs, but when I pulled the OEM socket out and re-inserted it (just a prelim check on wire lengths and accessibility), I got the damn socket inserted and rotated about 90 degrees TOO FAR! Apparently don't know my own strength. Now it wiggles CW & CCW a few degrees, but in the wrong position and I cannot get it out! Sooo, WHAT NOW?
Should I try forcing it back Counterclockwise (about 90 degrees), against the detents that I already forced it past?
Or should I keep forcing it Clockwise (210-270 degrees), with the hope of blowing past all the other detents?
Or, should I eat crow and take it to the dealer (ouch)?
12-13-2019, 07:23 PM
#98
Real Name: G.Jenkins
It happens at times... It would be better to go forward and let the bulb plug pop out of the socket. I feel it may get more damaged reversed,that is if it has passed the locking detents. I'm certain if the dealership gets this they will force it out and tell you it needs a new light assembly and plug socket.( $$$ for them) Just give it a twist,should just pop loose.
12-13-2019, 09:58 PM
#99
Thanks for the input. I can't believe how easily the bulb adapter just went in wrong and got stuck - I would have thought it would only go in right and stop where it should. On the other hand, it IS Friday the 13th! I will see if I can get a consensus on this...
12-13-2019, 11:31 PM
#100
Do they hyperflash as side marker lights?
12-14-2019, 11:52 AM
#101
This may be a dumb question, but are they so bright that they cause headlights to look amber when driving at night? Just wondering what what impact they'll have.
2020 TRD ORP - Silver / TRD Pro Wheels - Black / Continental TerrainContact A/T - 265/70R17 / ARB Diff Breather / XenonDepot XTR HID Philips XV2 48K - Low Beams / XenonDepot Xtreme LED Pro - High Beams
12-16-2019, 02:32 PM
#102
Real Name: Chris
Real Name: Chris
Nope
12-16-2019, 02:33 PM
#103
Real Name: Chris
Real Name: Chris
No, the ones I recommend have built in resistors to prevent hyperflashing
12-22-2019, 12:03 PM
#104
Will these bulbs hyper flash if you have the front turn signal bulbs and rear turn signal bulbs both installed? (The Lasafit ones)
12-22-2019, 11:54 PM
#105
Real Name: Chris
Real Name: Chris
Nope, I have both. They're anti-hyperflash with resistors built in
