12-23-2019, 12:36 AM
#106
Thanks man! That’s good to hear.
01-11-2020, 06:13 PM
#107
Just want to make sure I'm getting the right stuff, so could someone provide links for switchback LEDs for the front turn signals and amber LEDs for the rear turn signals?
Also, what are the downsides for having switchbacks vs constant amber for the front?
2020 TRD ORP - Silver / TRD Pro Wheels - Black / Continental TerrainContact A/T - 265/70R17 / ARB Diff Breather / XenonDepot XTR HID Philips XV2 48K - Low Beams / XenonDepot Xtreme LED Pro - High Beams
01-11-2020, 06:29 PM
#108
Real Name: Chris
Real Name: Chris
I've posted these several times, but here ya go
Front switchbacks
https://www.amazon.com/LASFIT-Switch...8781591&sr=8-4
Rear amber turn signals
https://www.amazon.com/LASFIT-Resist...8781628&sr=8-8
Your corner driving lights will be white when not blinking and not amber
01-12-2020, 12:37 AM
#109
Real Name: Zach
Real Name: Zach
Originally Posted by tristero
In the rear, I tapped the yellow on LH and light blue on RH for +, as these are the only wires that read on the meter.
Important info for anyone using a load resistor on the rear turn signal circuits.
01-12-2020, 10:13 AM
#110
Has anyone else had issues with the bulb falling out of the socket due to its now off centered weight? I have some VLED switchbacks for the front headlights, but got fed up fishing for the bulbs with a magnet stick.
01-12-2020, 11:07 AM
#111
Originally Posted by 97BlackAckCL
I appreciate the links.
Any trouble with yours since installing them?
01-12-2020, 03:45 PM
#112
Real Name: Chris
Real Name: Chris
Nope, the Lasfits snap in nicely and don't fall out
01-12-2020, 03:46 PM
#113
Real Name: Chris
Real Name: Chris
Nope, I have ambers in the front and rear and haven't had any issues
02-08-2020, 12:03 AM
#114
Got the rears installed just a bit and y'all weren't lying. Damn they're bright haha. Will be installing the switchbacks in the front tomorrow.
02-10-2020, 05:18 PM
#115
I had a set of Unique Style Racing in the rears with similar brightness as the Lasfits. In my opinion they are just too bright when it is dark. Blinding to people behind you.
I removed them and replaced them these and am much happier. Not much brighter than OEM and still do not require resistors to prevent hyperflash.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
10-23-2020, 04:41 PM
#116
Digging up some history here, but wanted to ask the Lasfit crowd how their LED's have held up. I drive a lot with parking lights on and curious if anybody has had any heat/blink issues with the front bulbs while doing this?
10-23-2020, 04:49 PM
#117
No issues after a year here
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
10-23-2020, 05:27 PM
#118
Real Name: Jason
Real Name: Jason
No issues with my switchback turn signals
10-23-2020, 06:50 PM
#119
Full time DRL driver here, flickering only happens to me when I offroad slow in the convoy in 95+ degree weather. If I turn them off and let them cool down they are fine. Lasfit stands by their warranty, their eBay store replaced mine no questions asked and it was ordered well over past 2 years.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
01-07-2021, 08:23 PM
#120
Those with the lasfit canbus front or rear turn signals do you find them too bright? I don't want to annoy other drivers. 1200 lumens each bulb seems very bright for turn signals. Has anyone found another less bright option led turn signal which doesn't require installing resistors, etc?
