04-15-2019, 01:22 PM
#16
Originally Posted by Jetboy
I don't understand. What is the function of these? Is the area not covered prone to some sort of problem? Or is this a cosmetic product?
You have a point. I think it depends on the model. The 4runners clearly have good coverage with the OEM plastic. As you can see from the earlier pics, the RCR liner covers a good portion of the frame if that constitutes any benefit.
Originally Posted by Jesse1983
I'd consider these just to not have my flaps hanging on for dear life by a bunch of busted/missing clips
Agree. My truck has 200k+ miles. The liners aren’t doing much at this point as you stated, hanging on for dear life. Lol
Originally Posted by WhiteRunner10
I think we'd all agree that airflow is important. Just left the vented hood thread and realized this mod should decrease airflow through the engine and brakes, possibly increasing temps.
This mod looks cool, but has anyone thought about temps?
Good question. Another member brought this up and hence fabricator is considering adding vents at the top for those individuals concerned. Similar to the one pictured below.
Originally Posted by GX4SEVEND
None of the pics show rigs with extended travel coil overs with the mounting bracket for the remote resi. Will it still work?
Will ask the fabricator. Let me get back to you.
2002 Thundercloud | TRD Supercharger | TRD Headers | URD 2.2 Pulley | Toytec | Addicted Offroad | 4xinnovations | Icon | SCS | BRIDE
BUILD THREAD
04-15-2019, 01:26 PM
#17
That’s a Jeep and doesn’t have remote resi.
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
04-15-2019, 01:39 PM
#18
Sorry that response was meant for the post prior. I will need to ask the fabricator regarding your question. Let me get back to you.
BUILD THREAD
04-15-2019, 01:41 PM
#19
Oh ok gotcha. Yeah keeps us posted please
‘14 SR5 in white
Full RCI skids
04-15-2019, 03:48 PM
#20
I’m going to ask for mesh covering with some sort of Trd or off-road lettering
Mike
04-16-2019, 09:39 PM
#21
Please post some pics of your setup. Fabricator is pretty confident he can make it work.
BUILD THREAD
04-16-2019, 10:14 PM
#22
Engine bay temperatures, maybe minimal change. The area change is pretty minimal from the rubber versions though, and most of the air will flow goes out the back of the engine bay past the transmission anyway. If you really want to lower temps, put some hood vents near the top front of the engine to let the air that comes out of the radiator escape.
As far as brake temperatures, there's nothing to worry about. You get enough airflow to the wheel wells under the car, especially in a lifted application. Also, unibody cars and SUVs don't have any openings like that in the wheel wells and none have brake cooling issues because of it. Also, it's really hard to get your brakes hot enough to run into issues unless you're towing downhill or doing repeated panic stops from freeway speeds.
04-17-2019, 12:05 AM
#23
I'm interested in this. My fender liners are destroyed.
1987 Classic Silver 22re - Stock
2015 Classic Silver Trail Premium
Lift: Dobinson C59-314 Front Coils, C59-725 Rear Coils, Total Chaos Upper Control Arms
Wheels: 17x8.5" FN Overland Spec B Gunmetal
Tires: 285/70/17 Cooper Maxx S/T
04-17-2019, 12:18 AM
#24
Yeah I don't see how these are going to flex as much as the stock covers. Don't think the body and frame should be connected with a metal plate but maybe I am missing something here. Mall crawling mod???
-2016 7%'er---RCI aluminum skids; C4Fab sliders; Rago Fab modular storage panels; Complete 3M ceramic tint; The Ultimate Camping Mod; Xenondepot HID kit; BFG KO2's
-1967 Stephens M416 military trailer---slow build
04-17-2019, 12:29 AM
#25
About the best one I have at the moment
‘14 SR5 in white
Full RCI skids
04-17-2019, 01:07 AM
#26
The body and frame don't move that much with respect to each other. A little oversize on the mounting holes and some rubber, and it's no problem. It's also <1mm thick sheet metal for the steel version, so if anything is going to break, it will be the fender liner. I assume the aluminum will have similar thickness.
04-20-2019, 09:04 AM
#27
Liners
Keep us updated
09-04-2021, 10:41 PM
#28
is this being sold for the 4th gen 4runner?
09-04-2021, 11:30 PM
#29
They do if you leave pavement. My front bumper had 3/4" clearance from my front fenders and would routinely hit the fenders.
That sheet metal in the wheel wells is 24ga (0.6mm) and cracks from the weight of the battery if you spend any time on bumpy roads.
09-05-2021, 12:10 PM
#30
Real Name: Derek
Real Name: Derek
Inv4drZm did a full coverage set in aluminum last year, he wheels hard.
Seems like he didnt attach it to the frame, so no problems with body/frame flex.
Pg.54 post#804...and that would be in his build thread.
He sells some stuff, dont know about the liners though.
I have had full coverage in the rubber and no increase in engine temperature according to
the Scan Gauge 2.
...4th gens both.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
