Here is my situation:
I was trying to add a CALI Raised switch using the windshield wiper heater switch and I shorted something, the 7.5 amp fuse labeled "Panel"popped, I replaced it and noticed all the lights went off in the overhead panel, the stereo side lights, the ac lights, and the wiper lights, but i still get power to the green wire on the wiper switch, but the grey wire seems to not work.
When i ran a lead off the gray wire to a metal spot on the frame all the lights turn back on? any ideas?
Also the dimmer switch still dims the gauge cluster and the radio screen, but if I touch the lead from the wiper switch ground side to metal the lights turn back on but they wont dim now... Took apart the dimmer and its not burnt.
I am completely lost as to what happened and where. I went and looked at interior pictures on google to see if something wasn't lighting up trying to pinpoint where the short is but everything turns on when I touch the lead from the grey wire to metal, even the wiper switch still works.
Also after the fact I added a Add-A-Circuit to the tail light 10 amp fuse underneath and it popped soon as i turned the lights on. I took the underdash fuse panel out, all the connectors are fine.
I have no idea what happened
