Old 01-11-2020, 12:41 AM #1
NYRunner NYRunner is offline
NYRunner will become famous soon enough
Replacing the rack and pinion- the engine and transmission have to be removed?!??
A few weeks ago a guy hit my truck making an illegal u-turn and hit the front right side of my truck, messing up the suspension and axle along with my bumper cover and quarter panel. It left my steering wheel at around a 30 degree angle when going straight forward...
Got a call today that my truck won’t be ready for another week or so because when they got it back from the alignment shop and took it for a test ride the wheel (paraphrasing) would go out again, and that the rack and pinion are damaged and will be replaced. He’s said he’s going to use brand new Toyota parts and said that to replace the rack and pinion the motor and transmission have to be removed...
Is that true?!
Bonus question- is there anything I should have them check or replace while they have everything out?
Thanks everyone!
2010 Mag Grey Limited 4X4
NYRunner is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 01:20 AM #2
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
I suppose it's possible, but if so, it's a poor design. However, if true, I'd want to see what things look like with the engine and trans out. I'd be looking for evidence of leaks on the engine and trans and other things that don't look right in the engine bay and frame.
Might be other damage to look for from the accident, like cracks in the transfer case, engine and transmission. With them out you can see much better all around. Also take note of where things are grounded and that all ground straps are re-connected.
I'd still research if it's necessary though - it's a lot of work. Call around to other places or ask the dealer; as the procedure has to be in the manual.
Old 01-11-2020, 10:15 AM #3
johnbt's Avatar
johnbt johnbt is offline
johnbt will become famous soon enough johnbt will become famous soon enough
johnbt's Avatar
Steering rack replacement - Toyota 4Runner Forum - Largest 4Runner Forum
From post #6... on a 2011...
"Yup, been there done that. It's expensive because they have to lift the engine a bit (not right out) to replace the rack. Couple days in the shop and something like 10-12 hours of labour. My rack failure was more than likely off road related."
2023 TRD ORP w/KDSS. Red again.
This 2016 TEP w/KDSS is a big step up from the 1986 Subaru GL wagon I used on the Outer Banks beaches for 14 years. That thing would go anywhere in the sand on 185/70-13 tires. Dual range 5 speed, factory skid plate, 3 position manually adjustable rear shocks and armored exhaust. All factory, including the white spoke wheels. The front sub frame finally rusted apart.
johnbt is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 07:54 AM #4
Thank you @johnbt !
Apparently the insurance companies pay for 17 hours of labor for the job...
Old 01-12-2020, 12:10 PM #5
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Yup, I have heard it's easily a $2500 or $3k job.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
rack , removed , replace , transmission , truck
What PM can be done while the transmission is removed? repo 3rd gen T4Rs 22 02-13-2019 08:56 PM
WTB 3rd gen rack and pinion eatmorechickenx For Sale: T4R Items 0 06-06-2015 06:21 AM
Where to buy rack and pinion xcmountain80 3rd gen T4Rs 3 01-29-2013 11:27 AM
Rack and Pinion Brakeman 3rd gen T4Rs 13 10-20-2012 07:40 PM
Replacing Front Pinion Seal 401Jeeper Classic T4Rs 7 02-15-2010 05:26 PM
