Originally Posted by T4R_KAI
Couldn’t find a definitive answer on this.
Do I need the PWM module for the HID low beams?
Also, for the LED high beams, do I need both the PWM module and the DRL LED driver or just the LED driver?
No for HID.
Yes for high beams unless you do the DRL driver to eliminate the flicker. If you run a PWM without the DRL driver, it will run your DRL at full blast making a bit too bright for a DRL.
