Old 04-18-2019, 09:50 AM #1
Dianna's Avatar
Dianna Dianna is offline
Dianna is on a distinguished road
Dianna's Avatar
Issue with Neutral Safety Switch
Hey guys, my 14 TEP was having some issues with the shift lever feeling stiff, then "D" would not illuminate, and now a CEL on my way to work this morning. After reading the many posts on other people needing to replace their neutral safety switch because of corrosion, and the fact that a Toyota tech had to use a torch and 2 hours to do an alignment last week because of corrosion, I'm sure this is my issue as well. I have replaced this part on my Tacoma, and it was a huge PITA, so I was wondering if anyone has had any success in fixing their switch by lubricating it still on the trans.
If you haven't yet had any issues with your NSS, and you live where salt is prevalent, I highly suggest you crawl underneath your 4Runner, passenger side, and spray that MF-er with some Fluid Film, or the like.
2014 Trail Premium with KDSS
2006 Tacoma
2001 4Runner Sport
1977 FJ40
Dianna is offline   Reply With QuoteReply With Quote
Old 04-18-2019, 01:02 PM #2
Dianna's Avatar
Dianna's Avatar
I guess I'll be the first to try it, if nobody else has, lol. I have some Evapo Rust, I wonder if I can get a ziplock bag full of E.R. over the switch and fill it up overnight, then lube the crap out if it. Even if that doesn't solve my issue, it should at least make it easier to remove when it's getting replaced.
2006 Tacoma
2001 4Runner Sport
1977 FJ40
Old 04-18-2019, 01:13 PM #3
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Maybe you should pull the code before guessing? People prolly holding off from stating the obvious.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 10:28 AM #4
Dianna's Avatar
Dianna's Avatar
Decided to try spraying the NSS down with PB. My hard shift was immediately fixed, D was back to being illuminated, and S mode works again. I thought I would need to let it soak overnight at least to see this kind of improvement, I was pleasantly surprised. I'm adding this to my list of things to do when changing the oil. When a problem is obvious, why check codes when I spent less time just fixing it? You guys that are getting these huge repair bills for replacing the NSS, no reason not to give this a try first.
2006 Tacoma
2001 4Runner Sport
1977 FJ40
Old 01-11-2021, 07:42 PM #5
Globus2 Globus2 is offline
Globus2 is on a distinguished road
I started to get the P0705 (and flashing 4-low, cel, and trac off) on my 2016 4Runner (40k miles). Thankfully, I saw this thread. I was able to work through the gears about 10 times (car off) and this completely went away. I’ll get under there to soak down the NSS but wanted to say thanks and let others know this did the trick for me. You saved me a trip to the mechanics and a lot of $$!
Globus2 is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 09:10 AM #6
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Spraying mine with PB worked. For about a week.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
corrosion , issue , issues , neutral , switch
Neutral Safety Switch BltByKrmn 5th gen T4Rs 14 02-26-2021 08:34 PM
Neutral safety switch? Help!!!! mavrk12 3rd gen T4Rs 6 09-14-2016 07:02 AM
Neutral Safety switch help Kevin Martin Classic T4Rs 0 07-04-2016 02:25 PM
Neutral Safety Switch VolcanoT4R 3rd gen T4Rs 7 06-16-2014 04:02 PM
Neutral safety switch HELP blah blah Problems & Warranty Issues 1 01-06-2004 12:54 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
