Old 04-18-2019, 11:36 PM #1
Gstick Gstick is offline
Gstick will become famous soon enough
rubber brake lines ?
Could someone Please give me the OEM part #'s for the LR & RR rubber caliper lines ?
This would be for a 2010 SR5 4x4.
I also need the part # for the CENTER rubber brake line. (above the rear differential)
Thank You !
2010 4R SR5, "best 4 wheel vehicle that I've ever owned" TRADED !
2019 4R TRD Off Road
Gstick is offline   Reply With QuoteReply With Quote
Old 04-18-2019, 11:53 PM #2
WhiteRunner10 WhiteRunner10 is offline
WhiteRunner10 will become famous soon enough
Are the 2010-2013 brake lines the same as the 2014+ models? I read someplace they wernt and that the 2014 and up have a firmer brake feel. Was thinking of replacing with steel brake lines when I do my brakes.
OP why not just buy aftermarket steel lines if your gonna replace the stock ones anyway?
Toyota Parts Center Online | Genuine Toyota Parts & Accessories just put in your location. Select shop online and select your car, then click Brakes and use the search function -brake lines. You should get your answer there along with a pic.
WhiteRunner10 is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 06:54 PM #3
Thank You !
Old 04-19-2019, 08:33 PM #4
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Not sure we can put steel lines in those locations. They need to flex when turning or hitting a bump.
Are there upgraded tougher lines for the 2014+ that will work and help reduce the soft feel?
BobsTrail is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 09:28 PM #5
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
I think they meant braided stainless steel hoses instead of factory hoses. There’s debate as to whether they help, but I can attest from having installed them on various vehicles that they do improve the pedal feel.
Crown would be an industry leader, but depending on where you are you may be able to have them made locally. Hope that helps.
Crown Performance: Stainless Steel Brake Lines - Braided Hoses for Cars, Trucks & SUV
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
4x4 , brake , lines , part , rubber
Rear brake lines exploded while bleeding brake fluid benztech82 4th Gen T4Rs 3 08-11-2017 08:16 PM
Dirty brake fluid resevior, but clean brake lines BDow 3rd gen T4Rs 2 07-04-2015 01:08 AM
Rear Heater coolant lines, can I use rubber? Draayer 3rd gen T4Rs 8 11-17-2014 02:36 PM
Metal ATF lines spliced to rubber hose, what should I do? (Trans. Cooler Install) dbsoundman 3rd gen T4Rs 7 11-26-2012 10:35 AM
Shouldnt any brake job also bleed the brake lines? Muti007 3rd gen T4Rs 10 04-23-2010 10:39 AM
