Old 04-20-2019, 06:19 PM #1
555R's Avatar
555R 555R is offline
Real Name: Jonas Garcia
555R is on a distinguished road
MY GARAGE
555R's Avatar
MY GARAGE
Cure for fogging headlights
How do we fix the condensation in the headlights. Last nights storm made them super foggy with condensation. Itís reakky bad. And how can I clean the insides.
555R is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 06:25 PM #2
555R's Avatar
MY GARAGE
555R's Avatar
MY GARAGE
It shouldnít be happening to my 1 year old truck.
Old 04-20-2019, 06:45 PM #3
lyodbraun's Avatar
lyodbraun lyodbraun is offline
lyodbraun is on a distinguished road
lyodbraun's Avatar
Check to make sure the dust covers are on first then make sure your bulbs are properly seated in the housing, I had a isssue with my Tacoma fog light and used air to blow it dry and then mad sure bulb was seated right so it made a seal, hopefully this will help which one is it both high and low beams areas ?
lyodbraun is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 11:28 PM #4
Axix23 Axix23 is offline
Axix23 is on a distinguished road
since its only 1 year old, you might want to swing by the dealership to see if they can replace them for brand new ones. Hopefully you didn't drill through the dust covers for HIDS. lol
Axix23 is offline   Reply With QuoteReply With Quote
Old 04-21-2019, 12:22 AM #5
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
Agreed. Bring it back to the dealer and have them replaced under warranty!!
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 04-21-2019, 09:48 AM #6
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser is a jewel in the rough LandCruiser is a jewel in the rough LandCruiser is a jewel in the rough
Real Name: Sparky
If factory, go to your dealer and get it fixed.
If HID retrofit, well that's why you don't take the headlights apart.
Throw yourself a dip son!
LandCruiser is offline   Reply With QuoteReply With Quote
Old 04-21-2019, 11:40 AM #7
555R's Avatar
MY GARAGE
555R's Avatar
MY GARAGE
I put a HID kit from TRS on the low and high beam so yeah I had to cut the covers. But I used the gasket and gorilla tape to seal it up. Anyone have a place to order new rear caps to see what they will do. Itís not hard to remove the hid setup anyway.
Old 04-21-2019, 12:09 PM #8
Saker's Avatar
Saker Saker is offline
Saker has a spectacular aura about Saker has a spectacular aura about
MY GARAGE
Saker's Avatar
MY GARAGE
Hello @555R
More than likely it is the seal on the bulbs not properly seated.
Check to see if the bulbs are loose in the sockets.
I have never had any issues using items from TRS, but had an issue with some high beam LED bulbs from another manufacturer and had to put an oversized "O" ring on the bulb, loosen the 3 screws at the high beam socket on the housing, place the bulb in the socket and retighten the 3 screws.
Condensation issue solved. The bulbs dried the lens out completely and I have not had any condensation issue since.
I can assure you it has nothing to do with the dust covers. They are designed to keep out splash and dust. The bottom of that fixture has a hole in the bottom where the wires run through to the low beam bulb.
If your bulbs are tight, this is what I suggest...... put the OEM bulbs back in, buy some new dust covers and them take it to the dealership and tell them there is condensation forming in your headlights.
Oh, no need for gorilla or any other tape..... Just sayin'
Best Regards,
Saker
2014 T4R *BLACK* SR5 PREMIUM 4X4 | Sakerís Midnight Build | Scuba Mod | LED LIGHT BAR INSTALL | Disabled DRL Easily | Saker's EBRs Photos Updated 05-21-16| Saker's Previous 2013 FJ TT/SE
Old 04-21-2019, 02:34 PM #9
Shadytype Shadytype is offline
Shadytype is on a distinguished road
I had condensation in one headlight. With only 5k miles. Turns out there was a compromised seal. They swapped it out under warranty.
Shadytype is offline   Reply With QuoteReply With Quote
Old 04-28-2019, 09:09 PM #10
555R's Avatar
MY GARAGE
555R's Avatar
MY GARAGE
Besides the stealership any other thoughts where I can get oem caps for the low beams. The condensation has gotten really bad after all this rain too.
Old 04-28-2019, 10:05 PM #11
Saker's Avatar
MY GARAGE
Saker's Avatar
MY GARAGE
It's not your caps, stick your hand under your light assembly, you will feel the hole where the wires run thru. Moisture would still come thru there!
Online from camelback Toyota.....
8113524160 - Socket cover
2014-19 Left or right
MSRP $18.45 ////// Online Price $13.53
Best Regards,
Saker
Old 04-28-2019, 11:17 PM #12
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton has a spectacular aura about nglayton has a spectacular aura about
MY GARAGE
nglayton's Avatar
Real Name: Neal
MY GARAGE
$12.00 on amazon with free shipping of you are a prime member....
$10 on ebay....
nglayton is offline   Reply With QuoteReply With Quote
Old 04-29-2019, 08:10 AM #13
555R's Avatar
MY GARAGE
555R's Avatar
MY GARAGE
Care to elaborate on the oversized o rings. Where did you get them. Part number etc. I did notice this was after I added 50watt hid high beams. They are seated tightly however.
Hello @555R
Old 04-29-2019, 09:32 AM #14
97BlackAckCL's Avatar
Real Name: Chris
97BlackAckCL is a name known to all 97BlackAckCL is a name known to all 97BlackAckCL is a name known to all 97BlackAckCL is a name known to all 97BlackAckCL is a name known to all 97BlackAckCL is a name known to all
MY GARAGE
Real Name: Chris
MY GARAGE
I had condensation in one of my headlights, it turned out that I didn't have the dust cover seated properly and there was a gap between the gasket and the headlight housing.
2017 Nautical Blue SR5 Premium - Black Emblem Overlays, AFE TB Spacer, AFE Momentum GT Intake, URD MAF Calibrator, Borla Touring Cat-Back Exhaust, Morimoto HID Headlights, Auxbeam LED Highs, Morimoto Black XB LED Fogs, Fyre Flys LED Interior, Lasfit Amber LED Turn Signals, Smoked Amber LED Raptor Lights, Odyssey 34 Battery, 32" LED Bar with Rago Hidden Brackets, Rago Molle Panels, CaliRaised Low-Pro Ditch Brackets w/ Side Shooter LED Pods, Anti-Dark Underhood LED kit, sPod w/ PowerTray Mount, Raceline Matte Bronze Wheels w/ Cooper Discoverer RTX, N-Fab Side Steps, Satin Black Roof Rails, MB Quart Speakers in all 6 door locations, JBL 3.5" in dash, JL 8w3v3 in JBL Enclosure, Husky Weather Beaters, CanvasBack Liners, ScanGauge
Old 04-29-2019, 01:58 PM #15
Saker's Avatar
MY GARAGE
Saker's Avatar
MY GARAGE
The oversized "O" Rings came with the bulbs....(wonder why).
I did put some "O" ring grease, (non-hardening clear/whitish stuff)
But that cured my condensation issue....
Try putting the OEM bulbs back into your assemblies. Park your vehicle facing the sun if possible and allowing the condensation to dry (disappear), this may take a few days depending on how muck moisture has been sucked into the assemblies.
The sun will heat up the lens and force the moisture out thru the bottom vents that have a Gore-Tex-like material in them.
If the moisture continues to develop with the OEM bulbs w/ OEM "O" rings, then take it back to the dealership and have them replaced under warranty with your new dust caps installed!
Now, if the moisture disappears with he OEM bulbs installed.... you have just pinpointed your issue!
PM me, I have an extra pack of the "O" rings. I can drop them in an envelope and send them to you...my help, may not.
Hope this helps...
Best Regards,
Saker
clean , condensation , cure , headlights , super
Keep headlights from fogging? Inv4drZm 4th Gen T4Rs 15 09-24-2016 10:03 PM
For those with Hella Micro DE's and fogging. SKIDMRK 3rd gen T4Rs 3 11-05-2013 06:19 PM
99 4-Runner Window's Fogging? Icemanmn General Discussions 1 04-23-2013 01:21 PM
Headlights fogging up KoNEJO 4th Gen T4Rs 3 04-03-2012 11:15 PM
Windows fogging up Mark Elliott General Discussions 12 01-26-2010 02:02 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
