Old 04-23-2019, 12:40 PM #1
Starsky Starsky is offline
Starsky will become famous soon enough
My Victory 4X4 Build
I just wanted to share some photos of my Victory 4x4 install. I really like their designs, and decided to stick with them for my major upgrades and make it a 'Victory Bulid'.
I'm usually traveling solo, or with one other person, so my approach is to do just a few key upgrades, carry my gear inside the truck, and keep my truck as simple and lightweight as possible. That means no add-on front or rear bumpers, roof racks, or skid plates. Definitely no RTTs, showers or awnings either. I prefer to drive more slowly and carefully, than to race across the desert tearing it up.
I went with their Blitz sliders (from the Jan. sale), the roof crossbars (4), and a Molle panel. I like the Molle panel so much, I've ordered a second one. The lights were wired to a dedicated switch in the center console.
The roof racks have four carabiner anchor points, four cargo loops, and two spots for my off-road whips (and a go-pro mount up front) On the roof, I plan to add a hi-lift bracket, and rotopack mounts for gas, as well as carry my rescue tracks. (My tires are standard size, so the spare is underneath.) The largest thing I plan to carry is a Kayak, but I'd like to be able to have a platform on top for stargazing too.
(FWIW, the lift is Bilsteins all-around, 1.75" up front, 1" Toytec rear spacer and a diff drop. Tires are standard size General Grabber AT/X - love 'em!)
Starsky is offline   Reply With QuoteReply With Quote
Old 04-23-2019, 12:47 PM #2
4runr4eva's Avatar
4runr4eva 4runr4eva is offline
4runr4eva will become famous soon enough 4runr4eva will become famous soon enough
4runr4eva's Avatar
Looking good. I wish the roof rails had a bit more clearance. If they flex at all, it would be very bad. Perhaps they are incredibly rigid and wont flex, but with two 60 lbs kayaks or RTT, I would be a little concerned. Can you confirm if that is an issue?
4runr4eva is offline   Reply With QuoteReply With Quote
Old 04-23-2019, 01:30 PM #3
Victory 4x4's Avatar
Victory 4x4 Victory 4x4 is offline
Official Vendor
Real Name: Cam
Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of
Official Vendor
Real Name: Cam
We were able to make them extremely low profile because of their strength. I ran a Free Spirit Recreation RTT with 3 of the crossbars (close to 300 lbs with myself and the tent/gear) with no issues. I would recommend 3-4 crossbars depending on the size of tent you plan on using.
17 SR5 - BDS | Falken | Mamba | Free Spirit | Warn | Factor 55
Offering quality steel and aluminum goods for Toyotas | Victory 4x4
@victoryrunner
Victory 4x4 is offline   Reply With QuoteReply With Quote
Old 04-23-2019, 01:32 PM #4
Official Vendor
Real Name: Cam
Official Vendor
Real Name: Cam
Looks great, thanks for the post! Looking forward to seeing more photos!
@victoryrunner
Old 04-23-2019, 01:56 PM #5
The crossbars are made of steel and are very rigid. There is absolutely no flex, so I'm not worried at all about the crossbars bending (the OEM rails might be a different story). I owned an 75 lb. Hobie fishing kayak, and I wouldn't hesitate to put two on the roof if I had to.
Edit: I should probably add that I'm super happy with the results! (I left that part out!)
Old 04-23-2019, 02:48 PM #6
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
I really like the sliders..On the roof rack, can you buy those anchor points separately?? I've got a different brand but those look like they would work.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 04-24-2019, 06:20 AM #7
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
How is the wind noise with the Roof Rack and Cross Bars?
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 04-24-2019, 10:38 AM #8
I just bought the climbing anchors and other mounting points on Amazon. The bars have a lot of places to mount things.
Old 04-24-2019, 10:42 AM #9
It hasn't changed a bit. I just replaced the crossbars tho. I expect to have some wind noise when I start to load it up with gear; but I bought these to keep wind resistance and weight down, and to avoid the need for carrying around a much larger roof rack.
Old 04-28-2019, 11:52 PM #10
Today I added skateboard grip tape to my Blitz sliders. I like it!
Before
After
Old 02-18-2020, 11:54 PM #11
lonest4r lonest4r is offline
lonest4r is on a distinguished road
Hopefully the OP sees this or someone has done similar.
I had the diff drop done when doing my lift. Now I am interested in the Victory Skids. Will I need a spacer just in the back. if so, what size spacer did you use? Thanks in advance.
2016 SR5
Shrockworks Sliders, 3" OME lift kit
lonest4r is offline   Reply With QuoteReply With Quote
carry , front , rear , roof , victory
Victory 4x4 New Products/Prototyping Victory 4x4 4th Gen T4Rs 149 05-18-2021 11:43 AM
Victory 4x4 5th Gen Build Victory 4x4 5th gen T4Rs 59 08-08-2020 07:37 AM
Victory 4x4 Molle Panel Install Bayou_Pro 5th gen T4Rs 26 11-25-2019 12:00 PM
Victory Toyota-Monterey, CA ran Dealers - Your Experience 0 10-17-2007 08:54 PM
