Old 05-08-2019, 01:47 PM #31
TOTAL CHAOS TOTAL CHAOS is offline
TOTAL CHAOS will become famous soon enough TOTAL CHAOS will become famous soon enough
Originally Posted by VancouverRunner View Post
When you say these are KDSS compatible does that mean the LCA has mounts for the sway bar bracket?
Correct! The KDSS compatible models have the sway bar brackets on the lower arms.
Expedition Series - KDSS Lower Control Arm - Single Shock
Expedition Series - KDSS Lower Control Arm - Dual Shock
TOTAL CHAOS is offline   Reply With QuoteReply With Quote
Old 05-08-2019, 01:51 PM #32
Originally Posted by MTN4RNR View Post
Just as my LCA bushing are showing wear...
Let us know when you're ready to upgrade
Old 05-08-2019, 02:12 PM #33
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Originally Posted by baysta View Post
What shocks are available for the 5th gen 4R in that diameter?
Even if there isn't a formal sku for it, most vendors can make any shock in a custom length.
I would love a Fox 3.0 with a DSC adjuster for both high and low speed compression. Personally I would explore that route for myself before I went with King.
It would be expensive, but still cheaper than adding a secondary bypass in a 2.5 configuration which starts to enter the overkill for my needs area.
Old 05-09-2019, 04:10 PM #34
CAMP CHAOS at Overland Expo West
Stop by CAMP CHAOS at Overland Expo West for some special CC stickers and to see our Expedition Series LCAs in person.
We'll be in booths P11 / P21 near Baja Designs and SDHQ. Come check out our new project build and other goodies
5/17-5/19
See you there!!!
Ways to Attend WEST — Overland Expo
TOTAL CHAOS
TOTAL CHAOS FABRICATION
NEW Expedition Series Lower Control Arms from TOTAL CHAOS-img_8558-jpg
Old 05-09-2019, 09:11 PM #35
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
Having just slopped a bunch of new grease all over a set of these, then gently manipulating them into place, I can a test to their sexiness
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 05-10-2019, 11:57 AM #36
canadian bum canadian bum is offline
canadian bum will become famous soon enough
Do you have side by side with tape measure differences of how much of an improvement there is in ground clearance?
2016 ORP, OME 3" lift with 1/2" coil spacer, Modified Metal-Tech Bumper, 295/70R17 STT Pro, and a bunch of other stuff.
2005 Tacoma DCLB that is a bit ridiculous Build Thread
78 FJ45 and 79 BJ40 Land Cruiser never ending projects
IG @schultzy507
canadian bum is offline   Reply With QuoteReply With Quote
Old 05-10-2019, 02:23 PM #37
TOTAL CHAOS
Old 05-10-2019, 02:27 PM #38
We don't have any side-by-side ground clearance comparisons showing the Standard, Race, and Expedition Series. If we find a couple of vehicles at similar ride height we can definitely get a few pics and measurements
TOTAL CHAOS
Old 06-12-2019, 05:43 PM #39
Princess is rocking our Expedition Series Lower Control Arms!
Click the photos below for more info on these LCAs
Old 07-26-2019, 05:01 PM #40
Comment below if you have any questions about our Expedition Series Lowers!
Want to check them out in person? Stop by Rocky Mountain Overland Rally in Gunnison, CO 8/1-8/4
TOTAL CHAOS
Old 08-22-2019, 07:16 PM #41
TOTAL CHAOS on Instagram: “Soccer mom Saturday - "Hey look mom, I made the travel team" 😂⁣ This TC GX crew is Expedition Series LCA equipped. ⁣ ⁣ ⚡️⚡️Click the link…”
Old 08-27-2019, 12:33 PM #42
Originally Posted by Ruby Khan View Post
Hi,
Is it correct to think that a longer LCA and UCA is helpful for maintaining a neutral suspension travel position when lifting the vehicle and extending the suspension travel capabilities?
If so, why is it not routine to utilize longer arms with lifts, and more particularly, why aren't the expedition arms extended in length rather than produced in "stock length"?
What do I need to learn to understand this better?
Thank you!
Changing the UCA to something with built-in caster would be the only recommendation, if not requirement, when lifting the vehicle. You will be back in factory specs after an alignment
Going with longer arms (Long Travel) isn't for everyone. Sometimes it requires fiberglass and typically requires a little bit more maintenance. Many customers don't want to deal with the longer shocks, control arms, axles, tie rods, etc.
Old 09-25-2019, 08:03 AM #43
Old 12-19-2019, 08:02 PM #44
Any guesses as to what we're welding up?
NEW Expedition Series Lower Control Arms from TOTAL CHAOS-image1-jpg
Old 12-27-2019, 11:28 AM #45
TOTAL CHAOS on Instagram: “#tcequipped 🤣⁣ #chaosgames 🙈 #campchaosapproved 🤘⁣
🎥: @motomojave”
arms , control , expedition , lower , series
TOTAL CHAOS Upper Control Arms TOTAL CHAOS 5th gen T4Rs 77 03-18-2024 10:44 AM
Will total chaos stock length race series control arms fit my truck with 17x9 SCS f5? chrissurfr 5th gen T4Rs 2 03-13-2019 01:34 AM
anyone running total chaos stock length lower control arms? chrissurfr 5th gen T4Rs 3 09-17-2018 01:06 PM
Total Chaos Lower Control Arms (stock Length) schwari1 4th Gen T4Rs 10 07-28-2014 07:10 PM
