Old 10-25-2022, 05:36 PM #1
BlueEyedDevil's Avatar
BlueEyedDevil BlueEyedDevil is offline
BlueEyedDevil will become famous soon enough
2020 TRD Pro Wheels/Tires/Lift Project Questions…..
I’m looking at making my 2020 TRDP a little more like I always envisioned it. That primarily includes bumping tires to 285/70/17, adding a small lift to accommodate those tires and hopefully just keeping the OEM wheels. I understand that is not optimal given the 285 wheel specs, but plenty have done that without issue. I also live in FL where 4x4ing doesn’t involve any real articulation. Think mud, beat up roads and trails and thats about it.
A while back I bought the Eibach TRDP lift kit. It seemed to get solid reviews, just haven’t had it installed yet, but it’s what i plan on using.
PRO-LIFT-KIT TRD PRO (Front & Rear Springs)
The tires will probably be some BFG flavor, KO2’s or maybe something slightly more aggressive. Open to other options, but used them on my 13 Trail and they seemed to work well.
Given the above, curious as to any thoughts about that set up.
I haven’t ruled out new wheels entirely. I’d much prefer to save the money and just keep the OEM wheels, but there are others that have caught my attention. I had FN wheels on my Trail and they were fine, no issues, and i liked the look. I’d probably angle towards something like them again. These were the wheels i had on the Trail….(Six shooters)
17″ Konig Six Shooter Flow Formed – Set of Four Wheels | FN Wheels Store
Those were a simple swap from the OEM wheels, given i don’t know much about how wheel specs affect fit/ride and so on. That “plug & play” fit would be great with my Pro.
If i were to go with new wheels, I’m a little apprehensive as the specs of various wheels would need to match up correctly for things to not be wonky in some way. That’s part of the reason i want to keep the OEM Pro wheels.
I have my eye on a few other brands, but how they’ll actually fit my Pro is tough to nail down with any real confidence or certainty. This always brings me back to stuffing 285’s on my OEM wheels, at least in part.
Anyone deal with this (I’m sure I’m far from the first) and any feedback on any aspect of this plan of mine?
Thanks in advance, very much appreciated.
BlueEyedDevil is offline   Reply With QuoteReply With Quote
Old 10-26-2022, 12:21 AM #2
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
You will have no problems with the TRD Pro wheel. I have 285/70-17 Wildpeaks in a SL rated tire. Nice, smooth ride and only weigh 51 lbs. I had BFG KO2's prior. I have had them down to 18-19psi for 130 miles off road for 3 days straight and other situations. I think Wildpeaks are better in rain and ice. Not sure about mud. Everything out this way is dry. Unfortunately
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 10-26-2022, 06:51 AM #3
Thanks for the reply.
See any issues with the Eibach lift I mentioned above having everything fit without any trimming for the 285’s?
Old 10-26-2022, 07:13 AM #4
No. The Pro comes with the fender trim from the port and combined with the +4 offset, 7” Pro wheel you will not contact anything. I initially added a 1.5” front and 1” rear spacer to my Pro and never had any issues off road. You may have to do some minor lower fender trim and push the fender liner forward. An easy mod. I didn’t do anything. I even kept my mud flaps. Post up pics when it’s finished.
Old 10-26-2022, 08:16 AM #5
Thank you. I’ll definitely update with pics.
Here’s a question. The wheels below look a lot like the FN six shooters, which I had on my 13 Trail and liked a lot. These are my 1st choice for considering outside of keeping the OEM TRDP wheels. These are Motegi Trailite’s.
My concern is that I just don’t know if dimensionally they’d work. My lack of a complete understanding of offset and other considerations has me a little hesitant. Love the look, have no confidence they would be a clean swap without other considerations being factored in.
Old 10-26-2022, 08:29 AM #6
I personally like the Pro wheel. Drive it first for awhile and see how you like it. There is plenty of information on the web describing offset. Here’s one:
https://m.tirerack.com/tires/tiretec...t&gclsrc=aw.ds
Pic with 285’s on my Pro when I had the 1.5/1” spacer lift.
2020 TRD Pro Wheels/Tires/Lift Project Questions…..-ef39b429-0dfd-4b87-b178-e3d300daebc1-jpg
Old 10-26-2022, 04:16 PM #7
Thank you, you’ve been super helpful.
Old 10-26-2022, 05:31 PM #8
ToDesi ToDesi is offline
ToDesi is on a distinguished road
I plan on getting the same springs, looking forward to seeing the stance
ToDesi is offline   Reply With QuoteReply With Quote
i’m , oem , pro , tires , wheels
New Wheels and Tires for 2020 TRD ORP bzizzi 5th gen T4Rs 8 08-15-2021 07:09 PM
FS: 2020 TRD ORP Tires and Wheels, Santa Fe, NM KDMcD For Sale: Suspension/Wheels/Tires 5 07-14-2021 03:29 PM
Wheels, Tires, Lift questions/advice watson6505 4th Gen T4Rs 3 02-11-2018 11:48 AM
A few Questions about my Lift/Wheels/tires Javelin 4th Gen T4Rs 7 11-27-2011 05:46 PM
lift/tires/wheels help and questions theeGORDITO 3rd gen T4Rs 5 11-18-2010 12:47 PM
