Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 04-25-2019, 10:48 AM #1
notoriouslyKEN notoriouslyKEN is offline
notoriouslyKEN will become famous soon enough
My $45 Door Seal Mod
I don't think I've seen this done specifically on our 4Runners but I saw a youtube video with this mod on an f150 (video here) and thought it would work for us too.
It turns out it does. Basically you are just reinforcing the door seal. This is purely anecdotal as I don't have a decibel meter, but the perceived wind noise when driving down the highway is definitely lower than before. I am not great at taking pictures while working, but tried to document a few things for you guys.
Materials Needed:
  • Latex Tubing - 50 continuous feet of 1/4" ID x 3/8" OD x 1/16" W ($42 ebay purchase)
  • Lube - I used a Silicon Lubricant ($4 hardware store purchase)
  • Scissors
  • Electrical Tape
  • Fish Tape
  • Clamp or additional person
Instructions:
Pop off the molding at the bottom of your door. The molding is held on by 3 plastic clips (noted in the image). I found it best to pry from the center on the interior side. The molding easily popped off using just my fingers, but a trim removal tool would work great too. This gives you access to the door seal.
Grab the door seal and give it a gentle tug to pull it off. Keep track of the orientation of the door seal, as putting it in the same way it came out will make install easier.
If you are working with a helper, now is the time for them to assist. Have them hold the door seal while you feed the fish tape through the large opening on the door seal. If you are working solo, clamp the flat part of the door seal to your workbench. Hold the other end and feed the fish tape through the larger hole.
Slide the latex tubing over the end of the fish tape and use the electrical tape to help secure it. Once it's secure, give the tube/tape a spray with the lube. I also sprayed the tube that was still on the reel, figuring that it would be lubed as I pulled the tape through. If you have a helper, they could probably spray as you pull.
Then simply pull the latex tubing through the door seal. If you are solo and have a portable bench, you'll need some weight on top of it.
Once pulled through, I tried to push some of the latex tube back in the seal.
It stretches as it pulls and this helped alleviate some of the stretch. Then, when cutting the tube, leave an extra 3-6" on each side. I found the tube still retained some of the stretch and as I moved the seal around installing, it would retract more into the seal.
Reinstall by simply pushing the enforced door seal back on its track. Keep the big hole with the latex tube facing the exterior door.
Now the rear doors are super simple, but the front doors have a piece of trim covering the door seal.
With the driver side door (the first door I attempted), I completely pulled off the trim. With the passenger side door, i was able to gently pry it up enough to remove and reinstall the door seal.
I did the trunk seal as well, but it is one solid piece from the factory so you will have to cut it in half to proceed. My trunk seal had slipped off the track a little and I closed my trunk on it, so it already had a small tear. That made me a lot less cautious on cutting it open to thread the tube through. Reinforcing the 4 doors + the trunk left me with about 3 feet of tubing from the 50 foot roll.
And that's basically it. I was surprised at how easy this mod was. I wish I had picture of the front door's extra trim removed for y'all and the extra tubing I left when cutting the seal, but as I said I'm no good at taking pictures. It is simple enough that I may pop off the trim and add pictures later. I do feel like it's made a solid difference in reducing the amount of wind noise while driving. Anyone else try this?
notoriouslyKEN is offline   Reply With QuoteReply With Quote
Old 04-25-2019, 11:09 AM #2
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
following this thread
1jzgte is offline   Reply With QuoteReply With Quote
Old 04-25-2019, 11:28 AM #3
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
interesting! following
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 05:23 PM #4
Breadman03's Avatar
Breadman03 Breadman03 is offline
Breadman03 is on a distinguished road
Breadman03's Avatar
Well this thread just got bookmarked. I'll have to do this sometime this year.
Breadman03 is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 08:10 PM #5
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
looks like a great idea. seems like this mod makes the seal fatter ? will this make it harder to close the door as well?
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 06-03-2019, 09:23 PM #6
It doesn't change the size of the seal, just the firmness. It will make the door slightly harder to close, but it's not really noticeable. I do notice a difference with the trunk requiring effort to shut. There has been 2 times where I thought I closed the trunk and started to drive, only to see the info bar light up and beep telling me the trunk was still open.
Old 06-03-2019, 09:58 PM #7
SnowYeti's Avatar
SnowYeti SnowYeti is offline
SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough
SnowYeti's Avatar
Great idea, following
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
SnowYeti is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 07:14 AM #8
jsun_2k's Avatar
jsun_2k jsun_2k is offline
jsun_2k is on a distinguished road
jsun_2k's Avatar
great, following especially after dash speakers and crossover upgrade
jsun_2k is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 06:19 PM #9
Tuc4R's Avatar
Tuc4R Tuc4R is offline
Tuc4R is on a distinguished road
Tuc4R's Avatar
subd
2018 TRD ORP W/KDSS & Sunroof - ADS C/O's and rear RR, TC UCA's, Icon 2' springs, SSO bumper, Smitty X20, Nitto RG, FX PRO wheels, AVID sliders, RCI Alum skids, Bussmann RTMR, Canvas backs, Accessorides remote start, Rago Molle’s, HID low's, LED high's, Morimoto XB fogs, Ceramic window tint, Ecotechne roof rack, ARB diff breather, Indel B TB51, Ellis shift knobs, Plastics Guy bump stops, ARB twin comp., Pedal Comm, X2 Power G27
Tuc4R is offline   Reply With QuoteReply With Quote
Old 06-08-2019, 09:14 PM #10
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
My next mod, hope it helps with the wind tunnel effects.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 04:30 PM #11
Charlievee's Avatar
Charlievee's Avatar
Looking at this closer today. Would it not be more effective to do the weather strip attached to the door? It would need to be cut, but it's a continuous seal, unlike the one posted above that start/stops at the trim threshold.
Old 06-11-2019, 04:41 PM #12
teotwaki's Avatar
teotwaki teotwaki is offline
teotwaki is just really nice teotwaki is just really nice teotwaki is just really nice teotwaki is just really nice
teotwaki's Avatar
For my 2018 I don't think the door seals are letting much dust in. Where I see evidence of dust getting in is right around the lever/handle for opening the door and also the U-shaped slot where the door latches on the stud.
Jim _ My Adventure Blog:http://suntothenorth.blogspot.com
ARB on-board compressor - RadFlo coilovers & rear suspension - Engel freezer-fridge - All Pro LCAs - African Outback roof rack, RCI skid plates
teotwaki is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 06:07 PM #13
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Do you happen to have a link to the tube you bought from ebay?
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 05:13 PM #14
Charlievee's Avatar
Charlievee's Avatar
Playing with this today and it does nothing for the wind noise I'm experiencing.
Old 06-15-2019, 05:19 PM #15
rushrunner rushrunner is offline
rushrunner will become famous soon enough rushrunner will become famous soon enough
Who cares about wind noise? Does it really matter when you have ALL windows down.
Past:1991 Lumina Euro 3.1, 1994 Cutlass SL 3.4, 1999 Intrigue GL, 2003 CTS, 2006 Saab 97x, 2009 4Runner SE (should of never traded it in), 2012 SRX, 2015 Charger Rallye. Current: Mine: 2018 4Runner Limited (glad to be back), Wife's: 2020 4Runner Limited (glad she finally joined the club).
rushrunner is offline   Reply With QuoteReply With Quote
door , seal , tape , trim , tube
Door seal failure? oldsweng 5th gen T4Rs 7 05-10-2022 11:22 PM
96 door weather stripping / seal Dezerts10 3rd gen T4Rs 4 10-20-2017 10:20 PM
Back door window seal Yotaway 4th Gen T4Rs 9 08-08-2015 04:18 PM
Which glue for door seal SJC General Discussions 4 07-23-2012 11:08 PM
Replacing door seal - how to? crooper 4th Gen T4Rs 1 02-28-2011 11:10 PM
