Old 01-24-2020, 02:19 PM #1
Matteblack's Avatar
Matteblack Matteblack is offline
Matteblack will become famous soon enough Matteblack will become famous soon enough
Matteblack's Avatar
10 offset to 15 offset "will it rub"
I am looking to sway a 17x8 wheel with 10 offset to the same size but with 15 offset. I have a 3" lift with 285/70/17 tires and I'm wondering if the tires will rub on the UCA's? Thanks in advance!
2010 TE
Matteblack is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 05:38 PM #2
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
I think you'll just have to measure and see. Do you have 5mm between your tires and your UCA? If not you'll rub. If you do all good
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 06:04 PM #3
Matteblack's Avatar
Matteblack's Avatar
Great, yeah I have about an inch. The place that will do the wheel swap said they are still 50/50 on whether it will fit. Something about how the tire will fit on the new wheel is unpredictable.
2010 TE
Old 01-24-2020, 08:47 PM #4
Matze's Avatar
Matze Matze is offline
Real Name: Matt
Matze will become famous soon enough
Matze's Avatar
Real Name: Matt
This tool might be helpful: Reifenrechner, Felgen- und Reifengrosse automatisch berechnen. ET Rechner - Reifen-Grossen.de
No worries about the german domain, it’s in English as well.
When you measure the distances the calculator should work well for you!
But keep in mind there is always the tolerance between theory and practice;)
2020 black ORP
Matze is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 12:01 PM #5
Matteblack's Avatar
Matteblack's Avatar
Thank you, fascinating tool! Yeah it looks like it will be fine in theory.
2010 TE
285/70/17 , offset , rub , tires , ucas
FN 8" w/ 0 offset + Spidertrax 1.25" + 285's +Dobinson 2" or Toytec 2" on Pro. Rub? michalik.piotr6837 5th gen T4Rs 3 11-21-2017 12:34 AM
16" Wheels With Big Offset? SCHUNTER1969 General Discussions 7 11-28-2016 03:35 PM
285's? Or "Streched" 265's on offset rims? decker1 5th gen T4Rs 8 09-06-2015 06:29 PM
17" x 8" Rim with 265 Tire 0 or -10 Offset? NinetwoNine 5th gen T4Rs 2 06-21-2014 07:56 PM
