Old 04-25-2019, 03:00 PM #1
FamousAv8er's Avatar
FamousAv8er FamousAv8er is offline
FamousAv8er is on a distinguished road
Question Gas pedal grind/vibration 1k - 1500
I’ve been noticing a grinding feeling through my gas pedal at about 1000-1500 rpm. Feels like something rotating around and scraping. Usually occurs while turning.
I recently did a power steering fluid change but not sure if it came about before or after the change.
Anything I should check or is this normal?
Daily Driven '17 T-Force T4R - Baja Flat Rack - 5100s
odo: 80,000
FamousAv8er is offline   Reply With QuoteReply With Quote
Old 04-25-2019, 10:55 PM #2
skinny420 skinny420 is offline
skinny420 is on a distinguished road
See this post Front Diff Grinding/Groaning Cyclical Noise
skinny420 is offline   Reply With QuoteReply With Quote
Old 04-26-2019, 01:44 PM #3
Originally Posted by skinny420 View Post
So I cant hear any noises but I can feel the grinding/rubbing while turning at low speeds.
odo: 80,000
Old 04-26-2019, 01:50 PM #4
I forgot to mention Im in a 4wd SR5. The rubbing I feel is in 2wd and havent attempted 4wd
also this is occurs only when turning
odo: 80,000
Old 04-26-2019, 01:59 PM #5
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
original brakes? it could be something as simple as worn brakes, worn out pads can make a scraping sound when turning even when the brake isn't applied.
jhguth is offline   Reply With QuoteReply With Quote
Old 04-26-2019, 02:33 PM #6
Seems I’m having trouble duplicating the issue today. It’s about 80F here so could be similar to the needle bearing issue.
If it was the needle bearing would I be hearing a sound? Could I hear it parked?
If my bearing is out, what issues can I expect if I’m not able to diagnose or address it right away?
odo: 80,000
Old 04-26-2019, 03:18 PM #7
yes original brakes, I will check those out as well but just 6k ago the dealership said they had plenty of life left
odo: 80,000
Old 01-25-2020, 01:10 PM #8
MTBT4RTrail's Avatar
MTBT4RTrail MTBT4RTrail is offline
MTBT4RTrail is on a distinguished road
Have you discovered the issue? I've had this same issue for quite some time now. Vibration through the gas pedal only and only while turning at low speeds such as making a turn from a stopped position. I can't hear it, I can only feel it through the gas pedal.
2016 4Runner Trail Edition Premium w/ KDSS - Interior: Husky Weatherbeaters front/rear, Toyota cargo liner, Salex organizer, Painted shifter Exterior: jrandom Trail badge, FN FX Pro, Nitto Terra Grappler G2s, Amber marker lights
Instagram: @jayparrington
'18 Yamaha MT07
MTBT4RTrail is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 04:02 PM #9
760Runner 760Runner is offline
760Runner will become famous soon enough
Ive had rare occurrences of the same situation in my 5th gen, I'm pretty sure its the rotors or brakes on mine, so it probably may be your braking system.
760Runner is offline   Reply With QuoteReply With Quote
change , gas , pedal , power , recently
Gas Pedal Vibration 4Runner4TW 3rd gen T4Rs 7 02-01-2019 09:54 PM
2016 SR5 4WD with Grind/Moan Vibration Bode210 5th gen T4Rs 40 11-24-2018 12:33 AM
1st gen 4runner tranmission squeal/grind/vibration Eugene13 Classic T4Rs 0 02-16-2018 12:59 AM
Gas Pedal Vibration Martin8 4th Gen T4Rs 0 05-02-2006 12:45 AM
Bad vibration at 1500 rpm in high gear Lotta Problems & Warranty Issues 9 01-24-2006 03:16 AM
