04-25-2019, 09:01 PM
Caster not even after alignment - any ideas?
I have the Bilstein 5100 lift all around and my technician had a hard time adjusting the caster today. He said he could not get the right side adjusted. The guy at the front desk said it might be due to the lift. The left front caster is 3.2° and the right side is 2.1°. Everything else is within spec. Any ideas what could be causing this? Is this anything to worry about or will I be fine? Will be driving across the country within the next month so want to make sure everything is good. Thanks for any help.
04-25-2019, 09:14 PM
If the caster is not the same the truck may pull to one side or the other, the more caster you can get equally the better the truck will track.
04-25-2019, 10:11 PM
Does your truck pull to the right?
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
04-25-2019, 10:18 PM
Real Name: Justin
Real Name: Justin
Pic of the eccentrics?
You got the spec sheet? Stock UCAs?
2010 4Runner SR5 Magnetic Gray: Radflo / Icon + Metaltech / Total Chaos / Dirt King / SCS Stealth 6 / BAMF Sliders + Pelfreybilt Bumper / PRINSU / Indel B / 2014+ IS 350 Retrofit
2012 GX460 Premium Black Onyx: Stock af
04-25-2019, 11:23 PM
Imgur: The magic of the Internet
Sorry can't figure out how to post the picture in here there is a link.
04-25-2019, 11:24 PM
Yeah it pulls right which is why I took it in in the first place. I will be moving across country in 3 weeks and wanted it fixed.
04-26-2019, 12:30 AM
It is pulling to the right because it has less positive caster than the left. You want equal caster on both sides to go straight.
Sometimes techs put a little more positive caster on the right to compensate for road crown.
You probably need aftermarket upper control arms now to help give it more caster.
TRD Pro wheels
04-26-2019, 12:44 AM
Real Name: Justin
Real Name: Justin
You have stock UCAs? More details about the setup you're running would be helpful. Put it in your sig.
Upload a pic of the eccentrics (cam bolts) if you can. Your camber and caster are linked, and you will lose caster when you increase the ride height.
The way it works is the front cam is camber adjust. The rear cam is caster adjust. You want the tech to set the cam first and get that in spec, then max out the caster—so front cam should be forward as much as possible, set, then adjust the caster, and toe last.
See the below chart from a 3rd gen, it's the same concept.
04-26-2019, 02:00 AM
Real Name: Doug
Real Name: Doug
@ BigT42
Not sure what your setup is but I would say that you should get a second look.
While not the same, I ran my 2005 4Runner with 35" Tires, Full suspension lift and ran it WITHOUT aftermarket UCAs for a few years and never had an issue getting the right alignment.
I use the same guy for my 5th gen and while he loves that its easier he still gets perfect alignment. I could get it for free from toyota but I chose to pay for a proper alignment.
Get a second look. Dont tell the 2nd guy whats going on, just get a 2nd look and compare.
EDIT: Just looked again at your numbers and noticed your are going to Firestone. Go somewhere else. They overwhelm themselves with clients and never spend the correct time with customers. I had a toyota friend who worked for Firestone tell me to "never come to his or any firestone store."
04-26-2019, 05:31 AM
Real Name: Brett
Real Name: Brett
FWIW I have gone to the same Firestone for years, but I'm lucky because I followed the Tech from another store. He has adjusted both my 4th and 5th. I gave him the Total Chaos instructions they have for adjusting their arms and he dialed both of them right in. Added the weight of a bumper and winch on my 5th, the angle changed which created a rub on the body mount. So he moved the caster fwd like everyone suggests and eliminated the rub. There are good techs out there but this is a lazy, time driven world we live in, so they're hard to find, and there are thousands of incompetent techs to weed through. A 2nd look and opinion is the way to go first of all.
Also a question to the folks that have more knowledge about the subject, why are the caster numbers identical from before and after? If he actually really tried wouldn't they be a hair different?
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
04-26-2019, 07:41 AM
Originally Posted by A10MileHusker
@ BigT42
^This.
I've run 5100s on both my 4Rs and never had a castor issue. Definitely go to another shop to get a second look.
2021 JGC Trailhawk (waiting for the 6th Gen 4R
2015 Silver TE: (SOLD) KDSS, ICON stg 2, Magnuson, Victory Blitz sliders, Fuel Blitz DDT 18x9 w/ -12o/s, 275/65/18 Nitto TGG2, ARB skids, Spidertrax spacers, Alpharex Luxx, Rigid 40” Stealth LED bar & 360 fogs, Switch Pro 9100 w/ Mount Tray, KC Flex Dual Ditch Lights, KC Cyclone Rock Lights, LED interior, SSS hybrid winch bumper, 30" Rough Country single row LED, Alpine ILX-F308/R line speakers, 8" Alpine Powered Sub. Prinsu Full no-drill roof rack.
04-26-2019, 08:26 AM
so what model year ?
when lifts are made many did have to replace the bushings.
I spray those bushings with silicone so they can be adjusted .
go to another alignment shop because it pulls so the tires will be damaged and MPG will drop.
04-26-2019, 09:06 AM
This is dead on correct and explains why your vehicle is pulling like it is to the right! And some techs do add more positive caster on the right to keep your vehicle from wandering off the road from the crown. With that said, I think its a technician error or a frozen cam bolt that the tech doesn't want to deal with or mention for whatever reason. My advice would be like others have said and take it somewhere else and get the alignment done. I am not sure how much lift you have, but it's really not that hard to get above your 2.1 caster on the right. I think it's an easy fix if you just take is somewhere else and get a technician that's willing to put in a little work.
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
04-26-2019, 09:26 AM
Thanks everyone. The Bilstein 5100 lift all around I think it was around 1.5 inch left in the front and 2 inch lift on the back. Stock UCA’s and stock size tires. It is a 2018 offroad model. I want to fire stone because they have been good in the past and I have a lifetime alignment through them so it’s free every time. I Will take it elsewhere To get it fixed.
