Old 04-25-2019, 09:54 PM #1
hawaiianryan's Avatar
hawaiianryan hawaiianryan is offline
Real Name: Ryan
hawaiianryan is on a distinguished road
Real Name: Ryan
Front Windshield Washer Issue
Hey Guys,
I'm having an issue with my front windshield washers. When pulling on the lever, fluid comes out of the drivers side with normal pressure, but the passenger side is a very weak stream. The fluid barely trickles out and hits about 1" above the lower edge of the windshield.
My first thought was the nozzle was clogged. I removed the nozzle and soaked it in vinegar for 24 hours and retested with no luck. Second thought was to change the nozzle for a new OEM washer nozzle, still no luck.
Does anyone have any ideas of what could be the issue?
Thanks!
2015 SR5 Mag Gray // Bilstein 5100 at 1.75 // Cornfed 1" Rear Spacer // FN FX Pro Wheels // BFG KO2 265/70/17C // Morimoto XB Fog Lights // F1 Tint 35/15
hawaiianryan is offline   Reply With QuoteReply With Quote
Old 04-25-2019, 11:05 PM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Front windshield washer not working
Windshields washers not working
Washer Fluid Not Working
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 04-26-2019, 08:30 AM #3
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
remove nozzle and see if it blows out good .. could also be a hose kink / crush ..
catrains is offline   Reply With QuoteReply With Quote
Old 04-26-2019, 09:13 AM #4
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
open hood and work backwards from the problem nozzle, removing connections one at a time and running washer pump until you find the clog or loose fitting / hole.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 07-22-2023, 07:50 PM #5
ChoreRunnerIG's Avatar
ChoreRunnerIG ChoreRunnerIG is offline
ChoreRunnerIG is on a distinguished road
Bumping this! Same thing on my SR5P. Just swapped out the passenger nozzle today -- tho the old one looked fine and I kept it, no blockages or damage -- and I have a weak couple of droplets hitting the windshield, which was an improvement, but not great. At that point it was mid afternoon, I'd achieved a bunch of other stuff, it was 104 degrees, and I left it to Jedi Master Yota.
Electric's good, motor's good, driver side pressure is great -- just no joy on the other side. Gotta be a blockage down the passenger line somewhere, so I anticipate pulling the hoodliner one of these weekends and chasing the gremlin. Will update how it goes.
Otoh, having come from axle and trans problems on my last daily driver.. we should all have vehicle problems like suboptimal windshield spray...
2019 SR5P XP, loaded with dadmods for a dadbod
Pretty mechanically inclined, for an English major
Find me wasting time on IG
ChoreRunnerIG is offline   Reply With QuoteReply With Quote
Old 07-23-2023, 04:30 PM #6
T4RSnow T4RSnow is offline
T4RSnow is on a distinguished road
I fixed this issue yesterday actually. On mine the check valve where the driver and passenger split was the issue. It is under the hoodliner on the passenger side towards the bottom. Hoses pull right off and put a new one in. Just google search "windshield washer check valve toyota" and it should come up with a picture to reference. You can get them on amazon or at auto zone type stores. The ones at auto zone from Dorman say they do not fit but they seemed identical to the OEM ones.
T4RSnow is offline   Reply With QuoteReply With Quote
fluid , front , issue , nozzle , windshield
Front windshield washer not working Cow_doc.308 5th gen T4Rs 9 07-17-2022 06:46 AM
Front windshield washer question AuSeeker 4th Gen T4Rs 3 04-24-2017 08:15 PM
Windshield Washer Bay33saw 5th gen T4Rs 22 09-26-2012 07:29 PM
