04-26-2019, 12:06 AM
35x12.5R17?
Has anyone had success clearing a true 35" tire such as the 35X12.5R17 General Grabber A/T X for heavy offroad use, without a long travel suspension setup?
I have seen all the threads about fitting 315/70's which I know is possible (especially with 17x8" rims), but I'm curious if anyone has done true 35" on 8.5" rims? I know the passenger side firewall, pinch welds, and body mounts among the obstacles to overcome, but if cutting the firewall would be necessary, I may have to reconsider things.
2017 4Runner TRD Offroad Premium KDSS - SSO Trailgator Rear Bumper, Dobinson C59-727 rear coils, RCI Aluminum Front, Transmission, Transfer-Case, A-arm, and Fuel Tank Skids, RCI Steel Lower Link and Stock Bumper Filler Plate Skids, FJ Toyman Shock Skids, C4 KDSS Diff Skid, RSG Offroad KDSS Skid, RSG Offroad Angled Rock Sliders, Front/Rear Timbren Offroad Bumpstops, ARB Diff Breathers, ARB Safari Snorkel, Borla ProXS Muffler w/ side exit tailpipe, @LOLSNOW Interior LED Swap, Xenon Depot Xtreme Interior and Reverse light LEDs, Baja Designs S2 Reverse Lights
@nauty_blue4r
04-26-2019, 03:39 AM
I run a 35x12.50x17 toyo MT. About as true a 35 as you’ll get really. Run a lot of caster, more than average BMC done and high clearance bumper mod.
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
04-26-2019, 02:40 PM
Search button and Google are your friends. use them.
04-26-2019, 04:47 PM
Did, thanks. I noted in the post I have read many threads on this, none that I saw with true 35" tires. And to clarify, I mean measure 35" tall, not 34 and change.
@nauty_blue4r
04-26-2019, 05:15 PM
Real Name: Tony
Real Name: Tony
I will admit there is no clear recipe of adding 35s to our 4runner after doing research on the forum or google.
But
@ GX4SEVEND
is right. You can run 35's with an aggressive BMC, lots of caster, and high clearance bumper.
I have also seen people do a body lift or a shock strut and 3 inch spring in the rear.
04-26-2019, 06:19 PM
Real Name: Brett
Real Name: Brett
You've probably seen this Going Bigger - 5th Gen Tire Fitment Guide
or this: post#231
The regear is the deal killer on my 5th gen. The torque of the V8 in my 4th gen makes up for it some, but after a year of driving it, I'm already thinking hard about some 4:56s.
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
04-26-2019, 08:44 PM
Originally Posted by 4RunnerAquasport
Yep, I have, for me the re-gear isn't as bad, here in CO driving up the mountain passes on 70 is already a "struggle" (harder than I'd prefer it to be?) with 285/70s, so I was considering it anyway. I just don't want to have to any serious re-welding to things like the firewall etc. I'm aware that there will be lots of cutting/bending etc. to pinch welds and body mounts, but it seems like around ~34.7-8 may be the limits of what you can accomplish without LT. Again for heavy offroad use.
@nauty_blue4r
04-26-2019, 08:48 PM
I'm also not a fan of doing a body lift, so I realize that may limit me some as well, when it comes to measuring taller than that.
@nauty_blue4r
04-26-2019, 09:15 PM
Its not like you'll see much of a wheeling difference between the two. Just take the smaller one especially since you don't want to do the work of installing a body lift.
04-26-2019, 11:27 PM
Falken Wildpeak MT01 35x12.5x17 on 17x8.5 SCS Ray10's.
(sorry crap pic I know)
2015 4R TE w/ KDSS, Mag Gray, King coilovers, King shocks, Timbrens, Dobinsons 749V progressive coils, Dirt King UCAs, Full Rokmen rear arms and panhard, OPOR Sliders, Hefty Front aluminum bumper, rear C4 dual swingout bumper, Warn VR10000S, HeftyFab full skids, AVS Aero, Interior LED's, XenonDepot HID w/ Phillips 4300k, ARB twin compressor, Rear-diff Breather mod, TRD Pro front, Dometic 50, Frontrunner Slimline II Full, TrekBoxx System Alpha, Trekboxx sleep platform, BlueSea, and BajaDesigns lights (LP9's, S8 20", Squadron Pro's, S2's), McQueen Fiberglass Fenders...and a hatchet! 35" Falken Wildpeak MT01's wrapped around SCS Ray 10s, BORA 1" wheel spacers. ECGS 4.88's.
05-22-2019, 10:50 PM
Did you have to lower your bump stops? If so how far?
@nauty_blue4r
05-22-2019, 10:57 PM
excuse me sir!!!! why haven't you done a build thread yet...lol...
nice truck man
05-25-2019, 01:45 PM
Yes sort of...in the rear I have Timbren's, which are pretty tall bumpstops. They were about the same length as what I had before, which was the toytec bump stop spacer with the stock bump stop in the rear. In the front, I used Wheeler's superbumps, which are taller than stock.
05-25-2019, 01:46 PM
nice truck man
Haha, Thanks!
I half-assed started one back in 2015 on here, but got lazy. There were also so many cooler builds than mine...and at that time I was pretty tame.
