Old 12-30-2019, 04:05 PM #166
rotorwind rotorwind is offline
Real Name: Brandon
rotorwind is on a distinguished road
Real Name: Brandon
nice looking rack!
rotorwind is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 10:58 PM #167
idHawk idHawk is offline
idHawk is on a distinguished road
Does this work with a sunroof?
idHawk is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 12:56 AM #168
Danthefitman Danthefitman is offline
Danthefitman is on a distinguished road
I donít have a sunroof so I canít speak to it personally but looking at the top of the rack I donít think it would be a problem. Especially since the slots where the cross bars go allow for adjustability.
2020 SW ORP - King 2.5" suspension w/ adjusters | JBA Uca | Icon 2" rear springs | Diode Dynamics SL1 Led low beam | Baja Designs Squadron Sport Ditch lights | SCS F5 17x8.5 -10 | Nitto Ridge Grapplers 285/70/17 | Victory 4x4 full length rack
Danthefitman is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 02:06 AM #169
aesthetics aesthetics is offline
aesthetics is on a distinguished road
Originally Posted by Danthefitman View Post
Can you send a link to the security screws that you ordered?
1/4"-20 x 3/4" Spanner Drive Pan Head Grade 18-8 Stainless Steel Security Machine Screw
| Fastenal
or
McMaster-Carr
I'm using spanner drive screws, but you can get any that's 1/4"-20 x 3/4"
aesthetics is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 10:52 AM #170
agentcross agentcross is offline
agentcross is on a distinguished road
Yup. Iíve got it installed on my sunroof. I can send pics if needed
agentcross is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 04:28 PM #171
| Fastenal
or
McMaster-Carr
Thanks! Going to get some myself.
Hereís how he sits so far with my ghetto rigged L bracket awning mounts until my brackets arrive.
Old 01-06-2020, 01:23 PM #172
CementTruck CementTruck is offline
CementTruck is on a distinguished road
Just wanted to offer some advice to anyone mounting something to this rack that spans the entire length.
For reference, I have the full Victory 4x4 rack and mounted the ARB2500 (8.2ft) awning. This awning weighs 30ish pounds and is over a foot longer than the rack, so I chose my two mounting points to be the rear-most crossbar and the front-most crossbar. Everything installed perfectly! Then it was time to hit the trails where I instantly realized my mistake. Due to the front mounts of the rack NOT being bolted to the roof, on every bump I drove over, the front of the rack shimmied left and right, effectively rubbing the roof and making loud squeaking noises. This is due to there being lateral flex from the middle mounting point of the roof to where the rubber feet and fairing touch the car. So whenever I hit a bump, the heavy awning would shimmy and bring the front of the rack with it (again since I mounted the front of the awning to the front-most crossbar).
So here’s my advice. If you’re mounting something long like an awning, move the front mounting point closer to the middle crossbar (where the rack is bolted to the roof). I adjusted mine yesterday after the trails and so far it’s removed the rack shimmy, but I’ll know more once I get back off-road. Additionally, I’ll be bolting down flat metal bars (available at Home Depot) in an X shape on top of the rack to create triangular stability between the rear and front of the rack. This should make the entire thing solid, as in you wouldn’t be able to replicate the shimmy by hand like you can now.
On a side note, I used Victory’s awning mounts and they are pretty awesome. It’s such a clean install and they mount really well to the crossbars. Highly recommended.
CementTruck is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 01:43 PM #173
So hereís my advice. If youíre mounting something long like an awning, move the front mounting point closer to the middle crossbar (where the rack is bolted to the roof). I adjusted mine yesterday after the trails and so far itís removed the rack shimmy, but Iíll know more once I get back off-road. Additionally, Iíll be bolting down flat metal bars (available at Home Depot) in an X shape on top of the rack to create triangular stability between the rear and front of the rack. This should make the entire thing solid, as in you wouldnít be able to replicate the shimmy by hand like you can now.
On a side note, I used Victoryís awning mounts and they are pretty awesome. Itís such a clean install and they mount really well to the crossbars. Highly recommended.
Good advice. I have an ARB2000 awning. My Victory awning mounts have not been delivered yet, but I used 3 L brackets from Lowe's to secure mine until my mounts come in. I dont like the idea of only having 2 mounting points so I might rig up a DIY 3rd point to go with the two Victory mounts. How much higher do the awning mounts sit than the top of the roof rack. My concern is not being able to get into my 7ft garage with the awning mounts installed.
Old 01-06-2020, 03:04 PM #174
If you do only go with 2 mounting points via the Victory awning mounts, I think you'll be good. I'm currently on only 2 points and using the rear-most bar for the rear, and the next bar forward from the center rack, if that makes sense. Especially since you've got the ARB2000, I think those two points would be just fine since it works for my 2500. Also, compared to your pic from earlier, the Victory mounts are lower by an inch or two. I have pictures to share but I've been struggling to get my links/codes to post properly.
Old 01-07-2020, 12:13 AM #175
Please do! I'd love to see how it looks with the sunroof open.
Old 01-07-2020, 01:19 PM #176
dezertbomber dezertbomber is offline
dezertbomber is on a distinguished road
This again shows they need to move the front mounts into the rain gutter like the other racks do. If they use strong 3M adhesive in the gutter, it'd be pretty solid.
I finally got to spraying silicone lubricant under each contact point of the RTT's rails and the squeaking is FINALLY gone lol. It's a mess now though as I had to spray from the edge of the rack's side panels toward the middle and it got everywhere, plus it slowly makes it way to the bolts on the outside of the panel and runs down. I've wiped it like 3x and it keeps coming. Worth it though as the noise was ridiculous.
For their awning mounts, how does the mount attach to the crossbars? Could you take some pics of that please? Thanks
dezertbomber is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 02:19 PM #177
Finally got the image tags to work! Ok, first pic shows how the Victory awning mounts attach to the rack. These are solid, heavy, and fit nice and tight. There are four included pieces of hardware for each mount and they screw down to the side tracks of the crossbars.
Second pic shows how high the awning sits above the rack. Also note that it sits a couple inches away from the rack, which allows it to move further toward the back without hitting the tailgate in the open position; this also allows the long 8.2ft awning to not hang so far over the windshield up front.
Old 01-07-2020, 03:35 PM #178
Thanks!
Might not clear my RTT, but at least I have crossbar mounting ideas for something other than the L brackets that come with awnings.
Old 01-07-2020, 03:52 PM #179
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a jewel in the rough mynameistory is a jewel in the rough mynameistory is a jewel in the rough mynameistory is a jewel in the rough
This is the result of the design choice of using flat plane geometry for the side rails. Lots of companies are doing this because it's easy to manufacture, but there's no inherent ability to resist yaw torque when the side pieces are made of flat sheet aluminum.
The Ecotechne rack uses brake-bent side rails for added rigidity (like a beam). So even though it uses the same stock mounts (no additional mounting or drilling) it's extremely rigid and resistant to movement. I can grab the rack and shake the truck on its suspension.
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 09:49 PM #180
@mynameistory is 100% right. The flat planes of the side rails, plus no front mounting point creates a lot of play up front. You could actually grab the front of the rack and move it side to side, which is what I was getting with the awning mounted up there. Here are my solutions to create much more rigidity.
I picked up two of these flat metal punched bars from Home Depot. They're the longest ones they had at 72" and the punched holes make for easier bolting down to the cross rails.
https://www.homedepot.com/p/Everbilt...-204225774-_-N
Basically just created an X with them, and bolted them down to the front-most cross bar and angled it out to bolt down to the 3rd bar from the rear. Victory provided 4 screws and rail nuts with the rack so I used those, plus I purchased a few more to bolt them down at multiple points.
The lateral play is virtually gone. Well, seems to be gone with as much force as my 175lb frame can give it. Additionally I put the awning back on, this time using the 3rd bar from the front as the front mounting point. On the drive today with several dips and uneven pavement, so far it's silent up there. Actual trail time will tell the true story, but more to come one that.
aluminum , length , mounting , rack , roof
GOBI Toyota 4 Runner 5th Generation Stealth Roof Rack with sun roof opening jhollis716 For Sale: T4R Items 10 02-19-2016 03:46 PM
Wanna trade my roof rack for your roof rack covers? Qyota 3rd gen T4Rs 10 05-07-2013 10:23 PM
will a fj cruiser roof rack fit an older 4runner? or any newer style roof racks? jetfire Classic T4Rs 1 07-22-2012 01:27 PM
Roof cargo box on stock roof rack hits rear hatch when opened NathanOfSeattle 3rd gen T4Rs 7 04-10-2011 06:19 PM
TRADE: Silver roof rack for Black roof rack. trijicon Classifieds - buy & sell (no commercial ads please) 0 04-19-2006 02:38 AM
