Old 01-13-2020, 11:09 PM #181
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a jewel in the rough mynameistory is a jewel in the rough mynameistory is a jewel in the rough mynameistory is a jewel in the rough
Now there's an interesting fix. Nice work and hopefully it doesn't reduce your item-holding capacity!
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 10:46 AM #182
Danthefitman Danthefitman is offline
Danthefitman is on a distinguished road
Originally Posted by CementTruck View Post
@mynameistory is 100% right. The flat planes of the side rails, plus no front mounting point creates a lot of play up front. You could actually grab the front of the rack and move it side to side, which is what I was getting with the awning mounted up there. Here are my solutions to create much more rigidity.
I picked up two of these flat metal punched bars from Home Depot. They're the longest ones they had at 72" and the punched holes make for easier bolting down to the cross rails.
https://www.homedepot.com/p/Everbilt...-204225774-_-N
Basically just created an X with them, and bolted them down to the front-most cross bar and angled it out to bolt down to the 3rd bar from the rear. Victory provided 4 screws and rail nuts with the rack so I used those, plus I purchased a few more to bolt them down at multiple points.
The lateral play is virtually gone. Well, seems to be gone with as much force as my 175lb frame can give it. Additionally I put the awning back on, this time using the 3rd bar from the front as the front mounting point. On the drive today with several dips and uneven pavement, so far it's silent up there. Actual trail time will tell the true story, but more to come one that.
Curious as to why you didn't install the flat metal bars on the underside of the rails.
2020 SW ORP - King 2.5" suspension w/ adjusters | JBA Uca | Icon 2" rear springs | Diode Dynamics SL1 Led low beam | Baja Designs Squadron Sport Ditch lights | SCS F5 17x8.5 -10 | Nitto Ridge Grapplers 285/70/17 | Victory 4x4 full length rack
Danthefitman is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 12:29 PM #183
CementTruck CementTruck is offline
CementTruck is on a distinguished road
Actually hadn't considered it, and tbh completely forgot that there's a track down there. I think if I can find an Allen key that'll fit between the bar and roof, then I'll move it in the future. Thanks for the tip!
CementTruck is offline   Reply With QuoteReply With Quote
Old 03-20-2020, 11:35 AM #184
proptied proptied is offline
proptied is on a distinguished road
It looks like you guys updated the front mount on this rack to sit in the channel, is that true?
Anything we should be concerned about with the original style? If so, can it be swapped out or did the side rails change too?
proptied is offline   Reply With QuoteReply With Quote
Old 03-20-2020, 11:51 AM #185
Victory 4x4's Avatar
Victory 4x4 Victory 4x4 is offline
Official Vendor
Real Name: Cam
Victory 4x4 is a splendid one to behold Victory 4x4 is a splendid one to behold Victory 4x4 is a splendid one to behold Victory 4x4 is a splendid one to behold Victory 4x4 is a splendid one to behold Victory 4x4 is a splendid one to behold Victory 4x4 is a splendid one to behold
Official Vendor
Real Name: Cam
Yes, they have been updated. There is nothing to be concerned about. I have run this style and a RTT offroad with no issues. We had a customer with a very large RTT who had some movement from side to side at the front of the rack so we updated the front mounts to eliminate that possibility. If you are concerned that your gear setup might cause some movement, give Tech a call and we can get you updated mounts! (The side rails have not changed)
17 SR5 - BDS | Falken | Mamba | Free Spirit | Warn | Factor 55
Offering quality steel and aluminum goods for Toyotas | Victory 4x4
@victoryrunner
Victory 4x4 is offline   Reply With QuoteReply With Quote
Old 03-20-2020, 11:57 AM #186
Ok, thank you for the peace of mind. I don't run much weight up front and haven't seen an issue so I think I'm good.
Old 03-31-2020, 06:31 PM #187
wesinatl wesinatl is offline
wesinatl is on a distinguished road
looking for a FLAT roof rack
Has anyone ever seen a flat roof rack? Something that would sit between the factory rails like a flat piece of steel? Maybe with some strategically cut holes to tie stuff down? This would be super low profile and spartan.
wesinatl is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 07:21 PM #188
kelkins kelkins is offline
kelkins will become famous soon enough
Originally Posted by mteolus View Post
Looks damn nice, but regarding the lower weight, perhaps the cross bars aren't as sturdy? The LFD Off Road cross bars at least look more sturdy, not sure if they are or not.
I have the rack and the crossbars are pretty sturdy.
kelkins is offline   Reply With QuoteReply With Quote
aluminum , length , mounting , rack , roof
GOBI Toyota 4 Runner 5th Generation Stealth Roof Rack with sun roof opening jhollis716 For Sale: T4R Items 10 02-19-2016 03:46 PM
Wanna trade my roof rack for your roof rack covers? Qyota 3rd gen T4Rs 10 05-07-2013 10:23 PM
will a fj cruiser roof rack fit an older 4runner? or any newer style roof racks? jetfire Classic T4Rs 1 07-22-2012 01:27 PM
Roof cargo box on stock roof rack hits rear hatch when opened NathanOfSeattle 3rd gen T4Rs 7 04-10-2011 06:19 PM
TRADE: Silver roof rack for Black roof rack. trijicon Classifieds - buy & sell (no commercial ads please) 0 04-19-2006 02:38 AM
