Old 04-28-2019, 12:01 AM #1
5Sport 5Sport is offline
5Sport is on a distinguished road
TE Rack - Old Style
I have an old style TE Rack (Black with two slits). How do I slide bolts into the side of it/ I want to mount a Yakima Basketcase rack between the rails.
Any advice or pics of how to would be appreciated?
Thanks
5Sport is offline   Reply With QuoteReply With Quote
Old 04-28-2019, 10:54 AM #2
williamlv282's Avatar
williamlv282 williamlv282 is offline
williamlv282 will become famous soon enough
You can buy the crossbars that fit that rack from Toyotas parts department or at a dealer. The cross bars from later model years are not compatible.
1987 Classic Silver 22re - Stock
2015 Classic Silver Trail Premium
Lift: Dobinson C59-314 Front Coils, C59-725 Rear Coils, Total Chaos Upper Control Arms
Wheels: 17x8.5" FN Overland Spec B Gunmetal
Tires: 285/70/17 Cooper Maxx S/T
williamlv282 is offline   Reply With QuoteReply With Quote
Old 04-28-2019, 10:55 AM #3
4runnerJDB's Avatar
4runnerJDB 4runnerJDB is offline
4runnerJDB is on a distinguished road
4runnerJDB's Avatar
Side note to the thread, but do you know the P/N# for the refreshed 5th gen crossbars?
2016 Trail
4runnerJDB is offline   Reply With QuoteReply With Quote
Old 04-28-2019, 10:58 AM #4
Unfortunately I do not. I had the local dealer look up everything for me. I just got rid of my original crossbars too or I'd offer them.
Old 04-28-2019, 11:24 AM #5
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice
blksubykid's Avatar
Thanks
2010-2013 TE roof rack?
blksubykid is offline   Reply With QuoteReply With Quote
Old 04-28-2019, 11:39 AM #6
Louisiana Overland's Avatar
Louisiana Overland Louisiana Overland is offline
Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough
If you were local to me I could give you the rack off my ‘17. Check the 5th gen classified here on the forum.
Louisiana Overland is offline   Reply With QuoteReply With Quote
Old 05-01-2019, 01:54 AM #7
Ok not sure how this thread got jacked. Not looking for the crossbars I'm looking for a way to mount a rack between the rails. I need some sort of bolt to fit into the side rails. Not sure how to do that or if there is some sort of trick to do that.
This is the rack. I pulled the pic off the internet
TE Rack - Old Style-yakima-baketcase-jpg
Old 05-01-2019, 07:34 AM #8
ToolUser1 ToolUser1 is offline
ToolUser1 is on a distinguished road
Look up "spring nut" on amazon - makes attaching accessories both the inside and outside tracks on TE racks super easy (home depot has them too if you have one close by). It's been awhile but I think I had to shorten the springs on some of them, just used wire cutters for that. I also shot them with some cold galvanizing compound and used a dab of anti seize to prevent future issues.
Best thing I used them for was to mount dock cleats to the outside rails. If you actually tie stuff to your roof frequently it makes it about as easy as it can be. Also at home depot for like $4 each (https://www.homedepot.com/p/Everbilt...1714/205883081). If the weather cooperates I'll get a picture up this evening.
The TE rack is freakin awesome for just this reason.
ToolUser1 is offline   Reply With QuoteReply With Quote
Old 05-01-2019, 09:02 AM #9
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
You have to remove the end cap to access the end of the channel, and slide in from there. Been a while since I did that or I'd tell you how. It wasn't difficult, I'm sure you could look up how somewhere on here or in the manual. good luck.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 05-01-2019, 11:57 AM #10
The point of the spring nuts is that you _don't_ need to remove the end caps. Just slip the spring nut in sideways, do a 1/2 twist, and you have a solid backing nut in the channel ready to mount whatever.
Old 05-01-2019, 01:06 PM #11
STX4Runner's Avatar
STX4Runner STX4Runner is offline
Real Name: Jonathan
STX4Runner has a spectacular aura about STX4Runner has a spectacular aura about
STX4Runner's Avatar
Real Name: Jonathan
You want these. I use them all the time to attach stuff to the inner track on my rack.
McMaster-Carr
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
STX4Runner is offline   Reply With QuoteReply With Quote
Old 05-01-2019, 04:11 PM #12
blksubykid's Avatar
blksubykid's Avatar
McMaster-Carr
Yep. These came with my LFD crossbars and havent had any issues
Old 05-01-2019, 10:26 PM #13
Ok, drop in fastener or spring nut. Decisions decisions....
Thank you. This is exactly what I needed.
Which one is stronger? Or the same?
Old 05-02-2019, 04:59 PM #14
808Keith's Avatar
808Keith 808Keith is offline
808Keith is on a distinguished road
808Keith's Avatar
McMaster-Carr
Perfect.. just what I need. Thanks!
2013 T4R |2014+ TRD Pro facelift | Rigid Armor Tire Carrier | Rago Fabrication KDSS Rock Sliders | Rago Fabrication Panels | Rago Fabrication Ditchlight brackets with ExtremeLED flood lights | Baja S2 Sports work lights | 5100’s | Wheeler T1 front springs | ICON rear springs | Marathon Seat Covers |
808Keith is offline   Reply With QuoteReply With Quote
Old 05-02-2019, 10:22 PM #15
Horsethief Horsethief is offline
Horsethief will become famous soon enough Horsethief will become famous soon enough
Awesome! This is helpful to me too, I recently got a 13 TE and was looking at the rack the other day thinking I should figure out how to utilize it.
Horsethief is offline   Reply With QuoteReply With Quote
basketcase , rack , rails , style , yakima
New style rack guide $50 plus shipping. SoCal. JBurt For Sale: T4R Items 1 08-03-2015 07:22 PM
New Style Steering Rack Guide Dous For Sale: T4R Items 5 05-01-2013 09:06 PM
Safara Style Roof Rack Maybe? spoiler900 3rd gen T4Rs 3 03-21-2013 07:42 PM
safari style roof rack for 2nd gen blackchild Classic T4Rs 4 07-10-2012 09:48 AM
wtb: tube style roof rack w2h0i0t5e Want to Buy/Trade 1 06-24-2010 09:58 PM
