05-19-2019, 05:57 PM
#31
Originally Posted by MAST4R
1/ What are you running in the back? The Pro version of 5160?
Yes just the stock Pro Shocks.
2/ Would you say the front vs the rear feel differently on washboard, as in better/worse? You have 2.5 lift up front and then also 20% stiffer rear springs that are still newish so I wonder if that is part of it.
I really couldn't say on if it's different front to rear. The front rate was increased about 15%. I'm not sure on the rate of the factory rear springs but they are supposed to be good for only another 100# of load, so 20% may be a good guess.
3/ Aren't sway bar spacers necessary in the front? I mean, you have a Pro, so is that something that came standard from the factory? Or are sway bar spacers something only KDSS vehicles running 2.5 front shocks need to do?
I noticed Radflo 2.5 coilovers come with such spacers as do the Toytec ones (which maybe are just rebranded Radflos anyway).
Yes all of the 2.5" CO kits come with swaybar spacers. Since the Pros already have 3" CO springs then I guess they are not needed. That's a good question. Can't say that I even look at the SB clearance though.
The Toytec 2.5" Boss shocks are Readflos for sure.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
05-19-2019, 06:02 PM
#32
Thanks!
I emailed Toytec to see who makes their rear reservoir shocks in the same kit since they look like nothing I have seen but they have not yet responded. It would make sense that they be Radflo but there is nothing like them on the R website. The coilovers do look the same sans the color even on pictures.
If they offer Radflo front and rear I may have to look more closely into them as they are also cheaper than Radflo branded shocks. Not sure I can get over the red and the huge BOSS lettering though LOL Also not sure if they come with customer-specific valving like Radflo branded shocks can.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
05-19-2019, 06:29 PM
#33
Thanks!
No Problem.
Yeah I'm not sure who makes their 2.0 shocks either. I doubt Toytec offers them in custom valving though. That you probably have to go to Radflo directly, maybe a local radflo dealer or someone like Accutune. SSO is local to me and they really push Radflo as well. I came close to getting that Boss kit as well.
Paul
05-21-2019, 02:28 PM
#34
Remeasured today before heading to the tire shop to get the 285s installed.
Front has settled about 1/2" driver front and 1/4" on passenger. Rear has settled 0".
Paul
05-21-2019, 07:58 PM
#35
Paul
06-06-2019, 06:41 AM
#36
Originally Posted by Icantdrive55
Late to this party, but are you running spacers with those wheels?
Yes I'm running 1.25" SpiderTrax spacers. Main reason I had to do the BMC and some aggressive bumper mods. Plus the Duratracs are pretty wide and aggressive on the outside edges.
Paul
06-06-2019, 07:25 AM
#37
Looks pretty awesome. Looks like the 599s give you a perfect stance.
2017 Toyota 4runner TRD Pro
2012 Toyota Highlander
06-06-2019, 07:41 AM
#38
Thanks! Yes they did. I'm glad you gave them up.
Paul
06-06-2019, 11:06 AM
#39
BayOO, are you going to sell fresh mudbuds at FJ Summit
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
06-06-2019, 11:10 AM
#40
Man wouldn't it be cool if I could do a crawfish boil at the Summit!!! I'd need to put all of my equipment on a trailer though. LOL
Are you going?
Paul
06-06-2019, 11:18 AM
#41
Sorry Bro my vacations are already planned for the year. Disney trip is traumatizing me
08-25-2019, 02:52 PM
#42
Did this install myself a few days ago. Swapped out springs same way. Super easy and feels safe once you see it in action. Ended up at exactly where you are in the front. 22 5/8ths. For the rear springs I did the Bilstein B12 1.5-2”. Got slightly over 2”. Sitting 1” higher in the rear and looks perfect to me. Also put on some of the SPC UCA’s and got 4.5 caster. Those have to be the easiest UCA’s to install. It drives great! No Offroad yet but doesn’t feel any different than my 1” front and rear cornfed spacers. I’ll try to get a pic uploaded soon. Thanks for your advice btw. Definitely the way to get the most out of the Pro Suspension without spacers. 255’s or 285’s up next.
08-25-2019, 10:39 PM
#43
Glad it worked out for you. I have some SPCs that I need to put on a well, just haven't had time. What setting did you use for caster on the arms themselves?
Paul
08-26-2019, 02:23 AM
#44
I did setting D which added 2 degrees. That addition put me exactly where I wanted to be. Just over 4. You can easily hammer it out in an hour. 2 max.
08-29-2019, 10:27 PM
#45
So..
@ Akkording
Did you ever measure your down travel stock? Or later? Or up travel?
I think stock non-Pro is supposed to be 8 total (7.8 to be precise) but I am not sure how it is split between up and down.
@ Bayou_Pro
, did you ever measure your up travel stock? Or now?
Stock Pro is supposed to get 0.75" of extra down travel (though most outlets round it up to 1").
I am getting 4.5" down travel in the front with 6112 at 2 and 4 and I am emphatically too lazy to measure up travel right now but I will update when I do.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
