Thread Tools Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
Old 02-06-2018, 04:13 PM #1
XenonDepot XenonDepot is offline
Real Name: Caleb
XenonDepot will become famous soon enough XenonDepot will become famous soon enough
Real Name: Caleb
Xtreme LED Pro Kit Review - 5th Gen Toyota 4Runner
Are H11 LED kits brighter them the stock H11 halogen?
Check out this install of the H11 Xtreme LED Pro kit in our 2018 Toyota 4Runner TRD Pro and see how well it really performs. The review shows beam pattern photos, and LUX measurements of the OEM H11 halogen bulb (baseline) vs our H11 LED headlight kit. Here are some pics from the review:
Full Review: 2018 Toyota 4Runner TRD Pro H11 LED Headlight Review
Before - H11 Halogen Bulbs:
H11 Xtreme LED Pro Kit:
After - H11 Xtreme LED Pro Kit:
Check out the 2018 Toyota 4Runner TRD Pro H11 LED Headlight Review for the results -- More pattern pics & LUX measurements.
XenonDepot is offline   Reply With QuoteReply With Quote
Old 02-06-2018, 08:14 PM #2
davem's Avatar
davem davem is offline
davem is on a distinguished road
davem's Avatar
I just did those 9005 in the 4Runner Hi beam and they are awesome !
'14 4Runner SR5 Premium Bilstien 1500's, Airlift bags, 275 70R 17 Cooper AT3's,Power Stop rotors & brakes, Xenon Depot 9005 Extreme Pro LED, Morimoto H11 2Stroke 2.0, AEM dry flow filter, Magnaflow exhaust, Sprint Booster
'19 Tundra Limited CM, 2.5/1 Bilsteins 5600's, Cooper AT3 275 70 18 on Method NV305's
'12 Subaru Legacy Limited
davem is offline   Reply With QuoteReply With Quote
Old 02-06-2018, 08:35 PM #3
_DCX_ _DCX_ is offline
_DCX_ is on a distinguished road
How do these compare to an H11 HID kit?
On the fence on which to go with, LED or HID. Do the LED's not require cutting into the dust cap (potential condensation issues as others have mentioned from HID kits)
Cost difference could sway me towards LED's if they're easier install and minimal difference in performance vs HID kit. But still leaning towards HID ...
_DCX_ is offline   Reply With QuoteReply With Quote
Old 02-06-2018, 09:34 PM #4
transistor's Avatar
transistor transistor is offline
transistor is on a distinguished road
transistor's Avatar
Nice review. After driving last night and wondering if my headlights were even on (they were), I think it's time for an upgrade. I'm going to order a pair.
Are the high beams worth upgrading to LED too?
transistor is offline   Reply With QuoteReply With Quote
Old 02-06-2018, 09:58 PM #5
mustangr2 mustangr2 is offline
mustangr2 will become famous soon enough
Everyone says to go hid in the stock headlights because you get brighter output. I have the extreme kit which is different than the pro. I am happy with them but I think if you want the best output everyone says to go with xenon depot hid kit with the Phillips bulbs from my understanding.
mustangr2 is offline   Reply With QuoteReply With Quote
Old 02-06-2018, 10:09 PM #6
That's what I keep hearing too.
I just checked out their site - 15% coupon currently for Valentines day... will pull the trigger for the XD HID Kit with Philips Update.
Old 02-06-2018, 11:16 PM #7
RajjyP RajjyP is offline
RajjyP is on a distinguished road
What are my options for low beam fog and drl in a 2013 trail if I don’t want delays, battery drain issues or hums or other odd things? How hard is install?
RajjyP is offline   Reply With QuoteReply With Quote
Old 02-07-2018, 04:23 AM #8
davem's Avatar
davem's Avatar
Look up at post #2 and i posted a review on forum also.
Sent from my SM-G892A using Tapatalk
Old 02-07-2018, 10:10 AM #9
I have xenon depot leds for my fogs and drl. I like them both. I am pretty impressed with the led fogs especially.
Old 02-07-2018, 12:56 PM #10
Real Name: Caleb
Real Name: Caleb
Hi, Guys.
Thank you for taking the time to post up feedback!
As per your questions/concerns:
(1) HID is brighter then LED -- no comparison. However, the Xtreme LED pro kit is a fantastic option as it provides more light output then stock, but not too bright. Some people are concerned about HIDs being too bright - so this is a happy medium There is a common misconception that LED kits produce less light output then stock (because so many LED Kits in the market don't). We did this review to prove that our kits work better then stock...LED kits are not all the same.
(2) Highs / DRL -- The 4runner uses a pulsing signal to create a lower voltage in DRL mode. If you plan on installing an LED kit for this application then the light will flicker extremely fast. If you use our CANbus / PWM module then it will eliminate the flickering -- but it will cause the light to function at full / regular intensity.
Hope this helps,
Danny
Old 02-07-2018, 01:41 PM #11
delgadtn's Avatar
delgadtn delgadtn is offline
Real Name: Taylor Noelle
delgadtn is on a distinguished road
delgadtn's Avatar
Love them
Before I even re-filled the gas tank on my 2018 Truck I replaced the hi and low beams with the H11 HID kit and the XTREME LED Pro kit with the CANbus modulator from Xenon Depot. I am super stoked on them. Soon I am going to replace my fogs with some Yellow Phillips H16's, also from Xenon Depot.
2018 TRD ORP: RCI sliders and full skid package/ King 2.5 Front & Rear with RR / Total Chaos UCA / Gamiviti Rack / ARB Safari Snorkel/ Shrockworks Dual Battery / SPOD SE touchscreen / BFG KO2s 275/70/17 / ARB dual compressor / ARB diff breather / Xenon Depot HID/LEDs / Extreme LED / Pedal Commander
delgadtn is offline   Reply With QuoteReply With Quote
Old 02-07-2018, 02:12 PM #12
Real Name: Caleb
Real Name: Caleb
@delgadtn - Nice!! Would love to see some pics
Old 02-07-2018, 03:54 PM #13
ksj0823 ksj0823 is offline
ksj0823 is on a distinguished road
Quick question. XenonDepot only have 35w hid kit for 4runner which is around $154.99, Am I correct? First time buyer here, I have seen a lot of great review about XenonDepot HID kit for 4runner, I just want to make sure I bought the correct HID kit last night.
ksj0823 is offline   Reply With QuoteReply With Quote
Old 02-07-2018, 04:41 PM #14
Real Name: Caleb
Real Name: Caleb
@ksj0823 - The 2017 4Runner uses an H11 bulb for the low beams, which means that you'll need to get an h11 Xtreme HID kit.
Make sure to check out our promotions page though, as you'll find a coupon code to help you with the price.
Steve
Old 02-07-2018, 04:43 PM #15
Steve
Great. That's the one I ordered last night.
4runner , led bulbs , led headlight , led kit
Motor Week's Review of the 1985 Toyota 4Runner (video) 89FourRunner Classic T4Rs 7 11-06-2014 08:42 AM
My honest 2011 Toyota 4runner Review... JJMAC 5th gen T4Rs 28 06-06-2011 07:40 PM
2010 Toyota 4Runner Trail Edition: Review and Pics (TruckTrend) tx 4runner 5th gen T4Rs 320 02-09-2010 02:34 PM
Does Toyota's product managers review this site? magnumfan 4th Gen T4Rs 23 03-07-2008 11:21 PM
Toyota Corolla (2003-2006) Review Thai All Other Vehicles 2 08-17-2006 09:21 AM
