Old 03-07-2020, 08:10 PM #1
rhearne27 rhearne27 is offline
rhearne27 is on a distinguished road
Exclamation •HELP• Installing Manual Gauges
Hi guys! I’ve run into a quick issue here so I thought I would ask around in a place that people would understand what I’m talking about.
I am currently trying to install some manual gauges (not electric or digital gauges) and I can’t seem to figure out how to actually set them up. Mounting the visible gauge itself is not the issue, and quite frankly idc what it looks like on the inside. I do a lot of small changes to my engine and would love to see some small visible engine changes too!
I am trying to install water temp., and oil pressure but cannot seem to find where or how to install them. I am going to eventually post a semi private YouTube video explaining the problem and showing my engine so maybe you guys could help point it out. When I create the video, I will also be creating another post on here showcasing the current gauges and how I installed with lots more information, I just don’t have much time.
If anybody has any tips or tricks that would be very helpful! I am posting in the 5th gen section but just in case, I have a 2015 SR5 2WD 4.0 V6. Thank you guys so much!
rhearne27 is offline   Reply With QuoteReply With Quote
Old 03-07-2020, 08:12 PM #2
Exclamation Wait there’s more!!!
Just to be a bit more specific, I can’t seem to find where to install the actual metal temperate reading sensor in my engine. I’ve heard there’s ports and adapters for it but I’m not sure what they are called. I’ve also heard for oil pressure, it’s somewhere under the car and you can just adapt it but I have no idea!
Old 03-07-2020, 10:58 PM #3
Brownfaux Brownfaux is offline
Brownfaux will become famous soon enough
Most people buy a scangauge 2 and call it good. I doubt you’ll find anyone who has done it. The basics for this stuff are searchable.
Brownfaux is offline   Reply With QuoteReply With Quote
Old 03-08-2020, 01:17 AM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
In the old days, most engines had plugs you could remove to install the fittings for these gauges. Water temp plug in the water jacket of the block and Oil pressure usually in the block or in-line with the oil pump. The oil pressure line was usually a piece of tubing with a fitting on the end. Then these lines had to be routed to the gauge cluster through the firewall. Now as Brownfaux said, it's easier to get this info via a scan tool of some sort. I don't know if there are even external fittings on engines these days to connect to. I guess you'll have to research for the 4.0.
Old 03-08-2020, 12:24 PM #5
What is a Scangauge 2? Is it a digital gauge that you can mount somewhere? Is it just an easy OBB plug and play?
Old 03-08-2020, 02:35 PM #6
flyrv9's Avatar
flyrv9's Avatar
It plugs into the OBDII port. Here's a link. In a quick look I didn't see oil pressure listed, but it might be selectable. >> ScanGauge II
Old 03-08-2020, 03:21 PM #7
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
You realize that installing a manual oil pressure gauge requires you to run an oil line into the cabin of the truck, right?
llDemonll is offline   Reply With QuoteReply With Quote
Old 03-08-2020, 08:52 PM #8
4FL 4FL is offline
4FL will become famous soon enough 4FL will become famous soon enough
4FL 4FL is offline
Just mount the gauge outside like the old school street drag racers, lol.
2015 Trail Premium w/KDSS, nautical blue, tinted windows, factory running boards, Cooper Discoverer AT3 4S stock size.
4FL is offline   Reply With QuoteReply With Quote
Old 03-08-2020, 09:11 PM #9
TOYO74's Avatar
TOYO74 TOYO74 is offline
TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about
TOYO74's Avatar
Right next to the oversized tach!
TOYO74 is offline   Reply With QuoteReply With Quote
Old 03-08-2020, 10:09 PM #10
We were all there once OP. It’s like r/blunderyears but for cars.
Old 03-25-2020, 12:47 PM #11
Whippersnapper02's Avatar
Saw this on IG and it reminded me of this thread. No electronic oil pressure gauges in general...
-2d02fa26-52ee-4068-9de4-e0620943c9a9-jpg
Old 03-25-2020, 12:54 PM #12
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
If you are doing something in a 2WD that would require you to carefully monitor the oil pressure and water temp, don't do it.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 03-25-2020, 03:14 PM #13
Teamoatmealpie's Avatar
Teamoatmealpie Teamoatmealpie is offline
Teamoatmealpie has a spectacular aura about Teamoatmealpie has a spectacular aura about
You want to install manual gauges but yet seem unfamiliar with an OBD2 reader/scan gauge? Can't tell if you're kidding or not?
Teamoatmealpie is offline   Reply With QuoteReply With Quote
Old 03-28-2020, 12:43 PM #14
Yes hahaha but I meant, what does it offer. I’m assuming it’s an electronic screen connected to my obd that monitors what my cars computer reads. Personally, I’m in the process of trying to make my T4R look like a race car. Really the gauges are an atheistic.
Old 03-28-2020, 03:14 PM #15
Colorado 2JZ's Avatar
Colorado 2JZ Colorado 2JZ is offline
Colorado 2JZ is on a distinguished road
Banks Power 66560 iDash 1.8 Super Gauge This seems pretty cool.
Colorado 2JZ is offline   Reply With QuoteReply With Quote
engine , gauges , guys , install , small
3rd gen 4Runner indiglo gauges. Reverse Glow gauges Atomic6 Free 3 08-19-2016 12:48 PM
FS: 1995 Toyota 4Runner OEM Manual and Haynes Manual 20 shipped 3RDGENGuy For Sale: T4R Items 2 10-28-2015 02:13 AM
LED Gauges ehub1304 3rd gen T4Rs 1 09-17-2009 12:18 AM
[pictures]...SR5, Sport & Urban Runner Gauges vs Limited Gauges K.C. General Discussions 27 04-07-2009 11:35 PM
Installing Limited Gauges on an SR5? JP4RNR 4th Gen T4Rs 8 10-05-2006 10:13 PM
